mkdir_p: command not found
Patricia Lopez-Cueva Patricia.Lopez-Cueva at scisys.co.uk
Tue Feb 13 11:16:31 UTC 2007
Hi all.
It's the first time I install rtems and I have problems.
I have installed all the toolsets needed and configured and compiled
rtems. The problems becomes in the instalation. The target si
sparc/leon2 and I have used the following command:
../rtems-4.6.5/configure --prefix=/opt/sparc-rtems-4.6.5
--target=sparc-rtems --enable-rtemsbsp="leon2" --enable-tests
make
make install
In the installation I get the following error:
test -z "/opt/sparc-rtems-4.6.5/sparc-rtems/leon2/lib/include/libchip"
|| @mkdir_p@
/bin/sh: line 1: @mkdir_p@: command not found
gmake[5]: *** [install-include_libchipHEADERS] Error 127
gmake[5]: Leaving directory
`/home/lopez-cueva_p/rtems465/build-rtems/sparc-rtems/c/leon2/libchip/ne
twork'
gmake[4]: *** [install-am] Error 2
gmake[4]: Leaving directory
twork'
gmake[3]: *** [install-recursive] Error 1
gmake[3]: Leaving directory
`/home/lopez-cueva_p/rtems465/build-rtems/sparc-rtems/c/leon2/libchip'
gmake[2]: *** [install-recursive] Error 1
gmake[2]: Leaving directory
`/home/lopez-cueva_p/rtems465/build-rtems/sparc-rtems/c/leon2'
gmake[1]: *** [install-recursive] Error 1
gmake[1]: Leaving directory
`/home/lopez-cueva_p/rtems465/build-rtems/sparc-rtems/c'
make: *** [install-recursive] Error 1
I have installed the lastest version of autotools because I read in a
mailing list that It might be that but it didn't work.
I don't know which can be the problem. Can you tell me anything?
URL: <http://lists.rtems.org/pipermail/users/attachments/20070213/a926b5c6/attachment.html>
