Still bootstrap problems
Leon Pollak
leonp at plris.com
Thu Feb 15 13:05:16 UTC 2007
Hello.
I followed the instructins received from Ralf (Thanks!!):
rpm -U \
ftp://ftp.rtems.com/pub/rtems/linux/4.7/fedora/6/i386/rtems-4.7-yum-conf-0.4-1.fc6.noarch.rpm
and installed:
yum install rtems-4.7-automake
yum install rtems-4.7-powerpc-rtems4.7-gcc
yum install rtems-4.7-<cpu>-rtems4.7-gcc-c++
Then I made
cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co -P rtems
and received the last source tree.
Finally, I run bootstrip and received:
./testsuites/psxtests
configure.ac:10: installing `../../config.sub'
configure.ac:12: installing `../../missing'
configure.ac:12: installing `../../install-sh'
configure.ac:10: installing `../../config.guess'
psx01/Makefile.am: installing `../../depcomp'
./c/src/lib/libbsp/mips/rbtx4938
./c/src/lib/libbsp/mips/genmongoosev
./c/src/lib/libbsp/mips/hurricane
acinclude.m4 is unchanged
./c/src/ada-tests
./c/src/make
./c/src/librtems++
./c/src
./c
./cpukit
configure.ac:5: error: Autoconf version 2.61 or higher is required
configure.ac:5: the top level
autom4te: /usr/bin/m4 failed with exit status: 63
aclocal: autom4te failed with exit status: 63
autoheader: '/opt/rtems-4.7/bin/autom4te' failed with exit status: 63
automake: autoconf failed with exit status: 63
grep: Makefile.in: No such file or directory
./tools/build
./tools/cpu/sh
./tools/cpu/nios2
./tools/cpu
./tools/cpu/generic
./doc/tools
./doc
ada_user/Makefile.am:46: installing `../mdate-sh'
ada_user/Makefile.am:46: installing `../texinfo.tex'
