symbol table functions?
Amalaye Oyake amalaye.oyake at jpl.nasa.gov
Sat Feb 17 00:38:10 UTC 2007
Thank you Till,
I will likely use cexp to test functionality ... and as a way to test code.
It seems to do what the VxWorks wind shell or host shell does ... which is
useful for development-test cycle ...
Regards,
Amalaye Oyake
-----Original Message-----
From: Till Straumann [mailto:strauman at slac.stanford.edu]
Sent: Thursday, February 15, 2007 3:18 PM
To: Amalaye Oyake
Cc: rtems-users at rtems.org
Subject: Re: symbol table functions?
Amalaye Oyake wrote:
> Hello
> are there any RTEMS functions that can find symbols by name and their
> entry point?
Not natively. However, you can use the 'cexp' package for this purpose.
http://www.slac.stanford.edu/~strauman/rtems/cexp/index.html
If you only want symbol access from a statically linked application
then you can strip it down significantly.
-- Till
> rtems-users mailing list
> rtems-users at rtems.com
