Named Pipes in RTEMS (mkfifo type)?
Amalaye Oyake amalaye.oyake at jpl.nasa.gov
Wed Feb 21 23:46:49 UTC 2007
What is the status of named pipes (of the mkfifo flavor) in RTEMS. I see the
mkfifo code, but the RTEMS documentation is loaded with preamble warning
about its current status ... the docs seem to be dated 2003, so I must ask -
What is the current status of mkfifo? Are FIFOs implemented? Can I create
UNIX flavor file system named pipes in RTEMS?
{RTEMS documentation says} RTEMS supports many of the process and user/group
oriented services in a "single user/single process" manner. This means that
although these services may be of limited usefulness or functionality, they
are provided and do work in a coherent manner. This is significant when
porting existing code from UNIX to RTEMS.
-  Implementation
-  The current implementation of dup() is insufficient.
-  FIFOs mkfifo() are not currently implemented. ***
-  Asynchronous IO is not implemented.
-  The flockfile() family is not implemented
-  getc/putc unlocked family is not implemented
-  Shared Memory is not implemented
-  Mapped Memory is not implemented
NOTES:
-  For Shared Memory and Mapped Memory services, it is unclear what
   level of support is appropriate and possible for RTEMS.
-  Functional Testing
-  Tests for unimplemented services
-  Performance Testing
-  There are no POSIX Performance Tests.
-  Documentation
-  Many of the service description pages are not complete in this manual.
These need to be completed and information added to the background and
operations sections.
-  Example programs (not just tests) would be very nice.
5.4.2 Make a FIFO Special File
mkfifo(), Function, Untested Implementation
NOTE: mkfifo() is implemented but no filesystem supports FIFOs.
4.4.17 mkfifo - Makes a FIFO special file . . . . . . . . . . . . . 83
{Source code search says}
~/RTEMS/rtems-4.6.99.3$ find ./ -iname '*.c' -exec grep -i mkfifo {} \;
-print
  puts("mkfifo /c/my_dir" );
  status = mkfifo( "/c/my_dir", S_IRWXU );
./testsuites/psxtests/psxfile01/test.c
 *  mkfifo() - POSIX 1003.1b 5.4.1 - Make a FIFO Special File
 *  $Id: mkfifo.c,v 1.4 2003/09/04 18:54:13 joel Exp $
int mkfifo(
./cpukit/libcsupport/src/mkfifo.c
* Amalaye Oyake                                    *
* Flight Software Applications & Data Product Mgmt */\
* 818.393.7168 work   818.653.4748 cell            *||
* Jet Propulsion Laboratory, Pasadena  CA 91109   */||\
@@@ personal opinions expressed represent only the views of the author @@@
