How do I load hello.exe to my lite5200?
Thu Feb 22 12:20:16 UTC 2007
Nickolay Kolchin wrote:
> Hi,
> I'm loading applications on MPC5200 with u-boot or BDI2000 (hardware
> debugger). DBug, Afaik, can't write applications to vector space, so
> you need to write a custom loader or rewrite default vector code.
Duncan emailed me privately so I know he is in the western US and
not awake yet so I will ask to speed this up. ;)
I know his board also has u-boot on it so if DBug doesn't do it, u-boot
is the answer.
The make-exe rule leaves the file in ELF format so is that what u-boot
can load?  Do you do anything special to the linked image before
downloading it with u-boot?
Is there anyone out there using the Motorola lite5200 or is everyone
using 3rd party or custom boards?
--joel
> On 2/22/07, Duncan Winn <duncan at winnd.sparks.nv.us> wrote:
>> I would like to run RTEMS on a Motorola lite5200 board.  This board uses
>> the MPC5200 processor.  I was able to build RTEMS using the pm520-ze30
>> bsp.  At first, I thought I should be using the gen5200 bsp, but I
>> couldn't get it to build.
>> My question is, is the pm520-ze30 the right bsp?  What part of the bsp
>> would I need to modify in order to get hello.exe running on the
>> lite5200?  How do I go about downloading hello.exe to the board.  When
>> the board boots up, it gives me a dBUG> prompt from the Motorola
>> standard monitor program.  I was able to build and download a version of
>> u-boot to the board if this will make it easier to load RTEMS.  I was
>> also able to build and download ELDK Linux (2.4.25) to the board, but
>> this didn't get me any closer to RTEMS.  Any help would be greatly
>> appreciated.
> Nickolay
> rtems-users mailing list
> rtems-users at rtems.com
