timer_settime doesn't fill siginfo_t
Patricia Lopez-Cueva Patricia.Lopez-Cueva at scisys.co.uk
Tue Feb 27 16:33:25 UTC 2007
Hi all.
I'm programming an application that uses Posix timers in rtems.  I have
to pass to the signal handler information so I have to use SA_SIGINFO
and put the information in the sigevent structure.
The problem is that when the handler is called and I access to the
siginfo_t parameter and in the si_value.sival_ptr the information I
store is not there.
Following it is included the code:
        struct sigevent t_Evp;
        struct sigaction t_SigAction;
        /* Initialise signal handler */
        sigemptyset(&t_SigAction.sa_mask);
        t_SigAction.sa_flags = SA_SIGINFO;
        t_SigAction.sa_sigaction = &SignalHandler;
        if (0 != sigaction(SIGUSR1, &t_SigAction, NULL))
                ERROR("Failed to install signal handler using
sigaction\n");
                return G_STATUS_FAILURE;
        /* Create timer */
        DEBUG("Creating POSIX timer\n");
        t_Evp.sigev_notify = SIGEV_SIGNAL;
        t_Evp.sigev_signo = SIGUSR1;
        t_Evp.sigev_value.sival_ptr = &pt_Timer;
        if (0 != (i_Status = timer_create(CLOCK_REALTIME, &t_Evp,
&pt_Timer)))
                ERROR("Failed to create timer using timer_create\n");
                switch (errno)
                        case EAGAIN:
                                ERROR("EAGAIN: Lacked necessary
resources or too many timers\n");
                                break;
                        case EINVAL:
                                ERROR("EINVAL: Invalid attributes or
clock id\n");
                                break;
                        default:
                                ERROR1("Unknown error = %d\n", errno);
                errno = 0;
static void SignalHandler(
        int             i_Signo,
        siginfo_t * pt_Info,
        void *          pv_Context);
Is there any error in the code? Someone knows why it happens?
Many thanks
Patricia
URL: <http://lists.rtems.org/pipermail/users/attachments/20070227/35bea03b/attachment.html>
