Can't build CVS rtems-4-7-branch
Till Straumann strauman at slac.stanford.edu
Mon Feb 5 23:49:58 UTC 2007
You might want to double-check Ralf's post from
over the week-end.
He probably changed the declaration of _CORE_message_queue_Seize
but you still pick up an old header that's in your build tree
../../cpukit/../../../mvme2100/lib/include/rtems/score/coremsg.h:
HTH
-- Till
Eric Norum wrote:
> I did a CVS update on the rtems-4-7-branch today and then tried
> building for various targets.  The uC5282 and pc386 targets seem to
> build fine, but the mvme2100 target gets:
> powerpc-rtems4.7-gcc --pipe -DHAVE_CONFIG_H   -I.. -I../../
> cpukit/../../../mvme2100/lib/include -D__RTEMS_INSIDE__  -Wall -fasm -
> mcpu=603e -Dmpc603e -Dppc603e -O2 -g -mmultiple -mstring -mstrict-
> align -MT src/libscore_a-coremsgflushsupp.o -MD -MP -MF src/.deps/
> libscore_a-coremsgflushsupp.Tpo -c -o src/libscore_a-
> coremsgflushsupp.o `test -f 'src/coremsgflushsupp.c' || echo '/home/
> phoebus/NORUME/src/RTEMS/cvs/rtems/c/src/../../cpukit/score/'`src/
> coremsgflushsupp.c
> mv -f src/.deps/libscore_a-coremsgflushsupp.Tpo src/.deps/libscore_a-
> coremsgflushsupp.Po
> align -MT src/libscore_a-coremsgseize.o -MD -MP -MF src/.deps/
> libscore_a-coremsgseize.Tpo -c -o src/libscore_a-coremsgseize.o `test
> -f 'src/coremsgseize.c' || echo '/home/phoebus/NORUME/src/RTEMS/cvs/
> rtems/c/src/../../cpukit/score/'`src/coremsgseize.c
> /home/phoebus/NORUME/src/RTEMS/cvs/rtems/c/src/../../cpukit/score/src/
> coremsgseize.c:70: error: conflicting types for
> '_CORE_message_queue_Seize'
> ../../cpukit/../../../mvme2100/lib/include/rtems/score/coremsg.h:395:
> error: previous declaration of '_CORE_message_queue_Seize' was here
> make[6]: *** [src/libscore_a-coremsgseize.o] Error 1
> make[6]: Leaving directory `/usr/local/rtems/Build/powerpc/powerpc-
> rtems4.7/c/mvme2100/cpukit/score'
> make[5]: *** [all-recursive] Error 1
> make[5]: Leaving directory `/usr/local/rtems/Build/powerpc/powerpc-
> make[4]: *** [all-recursive] Error 1
> make[4]: Leaving directory `/usr/local/rtems/Build/powerpc/powerpc-
> rtems4.7/c/mvme2100/cpukit'
> make[3]: *** [all] Error 2
> make[3]: Leaving directory `/usr/local/rtems/Build/powerpc/powerpc-
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory `/usr/local/rtems/Build/powerpc/powerpc-
> rtems4.7/c/mvme2100'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/usr/local/rtems/Build/powerpc/powerpc-
> rtems4.7/c'
> make: *** [all-recursive] Error 1
> make: Leaving directory `/usr/local/rtems/Build/powerpc'
