Can't build CVS rtems-4-7-branch
Till Straumann strauman at slac.stanford.edu
Tue Feb 6 22:20:09 UTC 2007
Joel Sherrill wrote:
> I think I have fixed all the message queue compilation error issues in
> 4.7 and 4.8.  I
> can compile for sparc/leon2 now anyway.
Shouldn't we fix that ugly    void*  <-> uint32_t cast (by means
of a union) ?
T.
> There is still a warning on the posix message queue code about losing a
> const.
> Probably the core message queue insert prototype should take a constant
> pointer
> but I haven't checked that yet.
> --joel
>> Ralf Corsepius wrote:
>>> On Mon, 2007-02-05 at 15:49 -0800, Till Straumann wrote:
>>>> You might want to double-check Ralf's post from
>>>> over the week-end.
>>> Yes, it's related to it. I've started to commit changes related to
>>> declarations, to provoke the bug I am suspecting and plan to commit more
>>> similar changes in near future (probably today).
>>>> He probably changed the declaration of _CORE_message_queue_Seize
>>>> but you still pick up an old header that's in your build tree
>>>> ../../cpukit/../../../mvme2100/lib/include/rtems/score/coremsg.h:
>>> May-be, may-be I missed something. I thought, I was carefully checking
>>> not to break something, but ... may-be I did - To be investigated.
>> It also looks like librtems++ does not compile.  I just committed changes
>> to get that to compile but it looks like the librtems++ test needs tweaking
>> also.
>> I will try to compile some more and see if I can fix that.
>> --joel
>>> Ralf
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
