Can't build CVS rtems-4-7-branch
Wed Feb 7 18:46:10 UTC 2007
Joel Sherrill wrote:
> Ignoring everything except Ralf's initial question, I did this
> analysis.
> These are the "return information" fields available for use in the TCB
> we have to choose from:
>   uint32_t              count;
>   void                 *return_argument;
>   void                 *return_argument_1;
>   uint32_t              option;
>   uint32_t              return_code;
> coremsgseize.c does this when a thread blocks:
>   executing->Wait.return_argument    = buffer;
>   executing->Wait.return_argument_1  = (void *)size;
Grrr... misread the code.. size is passed in as
  size_t                          *size,
so we are converting size from a (size_t *) to a (void *) which is OK.
> size is passed in as a size_t so it is certainly bad to put it
> in return_argument_1.  We  should have used option or count
> and not forced it into return_argument_1.
Wrong Joel. :)
> Which is better to use in your opinion Ralf?  We need to pick
> something instead of return_argument_1 for size and use it
> consistently. return_argument_1 should only hold pointers.
This cast at line 91 of coremsgsubmit.c is wrong in that the LHS side
should say size_t. So this line of code:
      *(uint32_t   *)the_thread->Wait.return_argument_1 = size;
Should be:
      *(size_t *)the_thread->Wait.return_argument_1 = size;
But I am going back to Ralf's original message and starting over. <sigh>
> Do we need to change count or option to another name and
> use size_t instead of uint32_t?
> As  a future improvement, I can see minimizing the fields in
> the Wait_Information structure by having 2-3 instances of
> a multitype union (e.g. a union with a void *, uint32_t, and
> a size_t).
> --joel
>>>>>>>> I think I have fixed all the message queue compilation error
>>>>>>>> issues in 4.7 and 4.8.  I
>>>>>>>> can compile for sparc/leon2 now anyway.
>>>>>>> Shouldn't we fix that ugly    void*  <-> uint32_t cast (by means
>>>>>>> of a union) ?
>>> You didn't get the point: I am having strong doubts this to be necessary
>>> and correct.
>> I do get the point but I believe you are wrong. I provided an
>> analysis of the issue - please reply to that or come up with
>> some sort of proof for your suspicion.
>> T.
>>> I am saying we have a bug somewhere.
>>> Ralf
> rtems-users mailing list
> rtems-users at rtems.com
