Can't build CVS rtems-4-7-branch
Wed Feb 7 18:53:04 UTC 2007
Joel pushes reset and goes back to the start.
Ralf Corsepius wrote:
> Have a look at my patch:
> Here is one:
> --- cpukit/score/src/coremsgseize.c     6 Feb 2007 03:50:47 -0000       1.11
> +++ cpukit/score/src/coremsgseize.c     6 Feb 2007 17:16:25 -0000
> @@ -107,7 +107,7 @@
>      the_message->priority  = the_thread->Wait.count;
> -    the_message->Contents.size = (uint32_t  )the_thread->Wait.return_argument_1;
> +    the_message->Contents.size = the_thread->Wait.return_size;
>      _CORE_message_queue_Copy_buffer(
>        the_thread->Wait.return_argument,
>        the_message->Contents.buffer,
> return_argument_1 is a void*, Contents.size is uint32_t => Illegal cast.
This is the unblocking path from a message queue submit that blocked.
The blocking
code is the bottom of coremsgsubmit.c:
    executing->Wait.id                 = id;
    executing->Wait.return_argument    = buffer;
    executing->Wait.return_argument_1  = (void *)size;
So the above is definitely casting a size_t (not size_t *) into a void *.
which requires the code Ralf has above to "undo it".  Rather than adding
return_size, can we switch to using count for message size and use option
from the Wait information for the message priority?
I still believe long term, it would be better to have the various
return_argument
fields be unions so the space is more effectively used while also
properly typed.
But this case clearly forced an integer through a (void *) return
argument field.
> Ralf
