Error compiling mpc8260ads
Leon Pollak leonp at plris.com
Wed Feb 14 11:54:38 UTC 2007
Ralf,
1. Thousands of thanks.
2. No, bootstrap is silent - I rerun it to check. And my version of automake
is 1.9.6.
Again, many thanks.
On Wednesday 14 February 2007 12:21, you wrote:
> On Wed, 2007-02-14 at 10:40 +0200, Leon Pollak wrote:
> > Hello,
> > I have the following error while compiling the mpc8260ads BSP + RTEMS
> > (totally standard, no my changes):
> Well, if I were you, I would want not claim this ;)
> > gmake[3]: Entering directory
> > `/opt/rtems-4.7/rtems-src.4.6.93.3/build/powerpc-rtems/c/mpc8260ads/lib'
> > Making all in libcpu
> > gmake[4]: Entering directory
> > `/opt/rtems-4.7/rtems-src.4.6.93.3/build/powerpc-rtems/c/mpc8260ads/lib/l
> >ibcpu' Making all in powerpc
> > gmake[5]: Entering directory
> >ibcpu/powerpc' powerpc-rtems-gcc --pipe -B../../../../.././lib/
> > -B../../../../.././mpc8260ads/lib/ -specs bsp_specs -qrtems -isystem
> > ../../../../.././mpc8260ads/lib/include  -DASM -mcpu=603e -mstrict-align
> > -Dmpc8260 -O4 -fno-keep-inline-functions  -c
> > /opt/rtems/rtems-src/c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S
> > -B../../../../.././mpc8260ads/lib/ -specs bsp_specs -qrtems -Wall
> > -mcpu=603e -mstrict-align -Dmpc8260 -O4 -fno-keep-inline-functions   -o
> > new-exceptions/rtems-cpu.rel -qnolinkcmds -nostdlib -Wl,-r
> > new-exceptions/new_exceptions_rtems_cpu_rel-cpu.o
> > new-exceptions/cpu_asm.o powerpc-rtems-gcc: new-exceptions/cpu_asm.o: No
> > such file or directory gmake[5]: *** [new-exceptions/rtems-cpu.rel] Error
> > 1
> > As far as I was able to understand, the required file cpu-asm.o resides
> > in the .../c/mpc8260ads/lib/libcpu/powerpc directory (I see it there) and
> > is looked for by compilation process
> > in ...c/mpc8260ads/lib/libcpu/powerpc/new-exceptions/
> > What can be done with this?
> This is an *.S compilation error => Probably you did not use the right
> autotools.
> You must use automake >= 1.10 for rtems-4.7. The *.S compilation rules
> is what makes the difference between this version of automake and all
> previous versions.
> I'd assume you to have seen warning from bootstrap.
> > Please, help.
> Ralf
Leon
