bsp_postdriver_hook is called but no console defined
Joel Sherrill
joel.sherrill at oarcorp.com
Tue Feb 27 12:04:56 UTC 2007
Leon Pollak wrote:
> On Monday 26 February 2007, Joel Sherrill wrote:
>> Leon Pollak wrote:
>>> Hello, again.
>>> In the mails "leon2: cannot boot without the console driver" there was a
>>> discussion of how to solve the problem of the BSP without console.
>>> Have any decision been accepted?
>>> I still fail in this trap...
>> My (temporary) solution was to replace bsp_postdriver_hook with a BSP
>> specific
>> one that did not register a console.
>> --joel
> Thanks Joel,
> I tried to do this, but received linker error - multiply defined symbol
> bsp_postdriver_hook, both in the bsp and application.
> Any other way except editing the shared code?
I tried it also and got the same linked error. Unfortunately, that's
what worked for me.
On the test BSP I was using (a sparc), it has a DEBUG_puts() call in
console.c which is
called from the start path of the BSP. Thus it didn't drop the size
that much. This just
emphasized that size is a BSP issue as well as a general RTEMS issue.
If the BSP
has sticky fingers, it doesn't matter how much restructuring we do.
It might take moving the guts of this function into a subroutine in
another file and
place that file in libcsupport. Then have confdefs.h generate the code
for this function.
I will have to think about this though.
--joel
--joel
> Thanks.
