New M68K target for GCC
Kirspel, Kevin {Engineering - Osmetech CCD} kevin.kirspel at osmetech.com
Tue Jan 16 15:57:54 UTC 2007
It does have the same core but has the A instruction set architecture
and the normal MAC vs. the A+ instruction set architecture and the
enhanced MAC for the MCF5329. The 528x processor has a version 2 core
but supports the A+ instruction set architecture and the enhanced MAC.
I wanted to combine these to use the version 3 core, the A+ instruction
set architecture, and the enhanced MAC.
I can get started with the -m5307 but I would like to get the other
features as well.
Kevin Kirspel
Research Engineer
Osmetech
(ph)  770-510-4444 x4568
(fax) 770-510-4445
-----Original Message-----
From: Thomas Doerfler [mailto:Thomas.Doerfler at embedded-brains.de]
Sent: Tuesday, January 16, 2007 10:38 AM
To: Kirspel, Kevin {Engineering - Osmetech CCD}
Cc: rtems-users at rtems.org
Subject: Re: New M68K target for GCC
Kevin,
I would assume that the MCF5329 has the same CORE as the MCF5307, which
should be supported by GCC. Try option "-m5307"
wkr,
Thomas Doerfler
Kirspel, Kevin {Engineering - Osmetech CCD} schrieb:
> I want to patch GCC 4.1.1 to add the MCF532x CoreV3 Coldfire
processors.
> I have the MCF5329EVB evaluation board and I want to get it running
with
> RTEMS.  I have checkout the rtems-4.7-branch from CVS and have patched
> it with a MCF5329EVB BSP.  To my dismay, GCC does not recognize the
> -m5329 target option.  I have never tried to update GCC to support a
new
> target processor, but since similar m68k coldfire processors are
> supported I didn't think it would take to much work to get it to
> recognize the -m5329 option.  Does anyone know the steps necessary to
> patch GCC to recognize the MCF5329 processor?
> Kevin Kirspel
> Research Engineer
> Osmetech
> (fax) 770-510-4445
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
