Which patches should I use for binutils, gcc and newlib?
Till Straumann strauman at slac.stanford.edu
Wed Jan 31 03:16:43 UTC 2007
Ralf Corsepius wrote:
> On Tue, 2007-01-30 at 12:22 -0800, Till Straumann wrote:
>>> Amalaye Oyake wrote:
>>>> Hello,
>>>> I am trying to build Binutils Gcc (4.1.1) and Newlib on a 64bit Xeon
>>>> host box running Ubuntu (64bit) ? my target system will be a i386 box.
>>>> What are the correct patches for Binutils, Gcc and Newlib? I see a lot
>>>> of /.diff/ files in http://www.rtems.com/ftp/pub/rtems/SOURCES/ that I
>>>> don?t know if I am to use all of them or just the latest one ?
>>> In general, it is always a single patch and choose the one with the
>>> latest date. That
>>> may NOT be the case for specific CPUs which may not work with the latest
>>> version
>>> of something or require a special patch.
>> Just for the record...
>>> For specific and absolutely correct information, check out
>> I assume you mean to look in CVS. If I browse in cvsweb
>> to [there is no 'rtems-XXX', just 'rtems']
>> rtems/contrib/crossrpms/rtems4.7/<my_cpu>
>> then I end up an the 'Attic'
> Attic, because the rtems4.7 toolchain sources are not on CVS HEAD, but
> on the rtems-4-7-branch, only.
Cool - so it turns out I had them already on my computer
- just didn't know where to look
Thx.
T.
> Ralf
