rtems 4.6.6 build error in the tests, availability of rtl8139 net driver
Joel Sherrill
joel.sherrill at oarcorp.com
Tue Jan 16 20:49:22 UTC 2007
rtems-users-20070109 at tinkerbox.org wrote:
> Hi,
> I am trying to build rtems 4.6.6 and I get the following error:
> Making all in samples
> gmake[4]: Entering directory
> `/usr/home/bruno/devel/rtems/rtems-4.6.6/build/i386
> -rtems/c/pc386/tests/samples'
> Making all in hello
> gmake[5]: Entering directory
> -rtems/c/pc386/tests/samples/hello'
> mkdir o-optimize
> mkdir -p -- ../../../../../pc386/tests
> i386-rtems-gcc --pipe -B../../../../../lib/ -B../../../../../pc386/lib/ -specs
> b sp_specs -qrtems
> -DPACKAGE_NAME=\"rtems-c-src-tests-samples\" -DPACKAGE_TARNAME=
> \"rtems-c-src-tests-samples\" -DPACKAGE_VERSION=\"4.6.6\"
> -DPACKAGE_STRING=\"rte ms-c-src-tests-samples\ 4.6.6\"
> -DPACKAGE_BUGREPORT=\"rtems-bugs at rtems.com\" -isystem
> ../../../../../pc386/lib/include -O4 -g -Wall -ansi -fasm -o o-o
> ptimize/init.o -c ../../../../../../../c/src/tests/samples/hello/init.c
> b sp_specs -qrtems -O4 -g -Wall -ansi -fasm
> -Wl,-Ttext,0x00100000 -o o-o ptimize/hello.obj o-optimize/init.o
> ../../../../../pc386/lib/no-dpmem.rel ../../ ../../../pc386/lib/no-event.rel
> ../../../../../pc386/lib/no-msg.rel ../../../../ ../pc386/lib/no-mp.rel
> ../../../../../pc386/lib/no-part.rel ../../../../../pc386
> /lib/no-signal.rel ../../../../../pc386/lib/no-timer.rel
> ../../../../../pc386/li b/no-rtmon.rel
> /usr/local/lib/gcc-lib/i386-rtems/3.2.3/../../../../i386-rtems/bin/ld: section
> . bss [0011a1e0 -> 0011cccb] overlaps section
> .jcr [0011a1e0 -> 0011a1e3]
> collect2: ld returned 1 exit status
> Any idea what could be wrong ? I have no idea where to start looking. Any clue
> and suggestions welcome.
What tools are you using? I have the distinct impression that these are
not the versions
provided with the branch. That is usually what leads to weird linker errors.
I just compiled this BSP with the 4.6 tools and it didn't do this.
> I am also looking for the rtl8139 network driver. I see references to a working
> one on the mailinglist, but where is the source code ? How do I enable it ?
> Thanks
> bruno
> rtems-users mailing list
> rtems-users at rtems.com
