RTEMS C++ Issues
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Mon Jul  2 17:46:23 UTC 2007
On psim at least, the cdtest sample runs fine except for the
global dtors.
It is a magic combinaton of bsp_specs and the linkcmds.
I don't know if that helps or not.
--joel
Robert S. Grimes wrote:
> Ralf Corsepius wrote:
>>> I have a problem with C++
>> This issue has nothing to do with C++. It's a BSP issue.
> Yes, of course - I should have said "I have a problem getting my BSP to
> support C++", or something to that effect.
>>> I think the answer is probably pretty simple, at least for you guys, but
>>> it's clearly a bit out of reach for me...
>> No. Without having seen your sources it's impossible to answer.
>> Either your BSP's Makefile.am is broken or your bsp_spec is.
> Yes, of course.  I meant to include these files, but I got lost in
> trying to describe the problem.  Attached are the relevant files, and
> sorry for the insufficient info the first go-around.
> -Bob
>> Ralf
>> %rename endfile old_endfile
>> %rename startfile old_startfile
>> %rename link old_link
>> *startfile:
>> %{!qrtems: %(old_startfile)} %{!nostdlib: %{qrtems: ecrti%O%s rtems_crti%O%s crtbegin%O%s \
>> %{!qrtems_debug: } \
>> %{qrtems_debug: }}}
>> *endfile:
>> %{!qrtems: %(old_endfile)} %{qrtems: crtend%O%s ecrtn%O%s}
>> *link:
>> %{!qrtems: %(old_link)} %{qrtems: -dc -dp -u __vectors -u download_entry -N }
>> ## $Id: Makefile.am,v 1.20 2006/01/12 10:12:30 ralf Exp $
>> ACLOCAL_AMFLAGS = -I ../../../../aclocal
>> include $(top_srcdir)/../../../../automake/compile.am
>> include $(top_srcdir)/../../bsp.am
>> dist_project_lib_DATA = bsp_specs
>> include_HEADERS = include/bsp.h
>> include_HEADERS += include/tm27.h
>> nodist_include_HEADERS = include/bspopts.h
>> DISTCLEANFILES = include/bspopts.h
>> noinst_PROGRAMS =
>> include_bspdir = $(includedir)/bsp
>> include_HEADERS += include/coverhd.h
>> dist_project_lib_DATA += startup/linkcmds startup/linkcmds.dl
>> noinst_PROGRAMS += startup.rel
>> startup_rel_SOURCES = startup/bspclean.c ../../shared/bsplibc.c \
>>     ../../shared/bsppost.c startup/bspstart.c ../../shared/bootcard.c \
>>     ../../shared/sbrk.c startup/setvec.c \
>>     ../../shared/gnatinstallhandler.c
>> startup_rel_CPPFLAGS = $(AM_CPPFLAGS)
>> startup_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>> noinst_PROGRAMS += dlentry.rel
>> dlentry_rel_SOURCES = dlentry/dlentry.S
>> dlentry_rel_CPPFLAGS = $(AM_CPPFLAGS)
>> dlentry_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>> noinst_PROGRAMS += bspconsole.rel
>> bspconsole_rel_SOURCES = console/consolelite.c ../../shared/console.c
>> bspconsole_rel_CPPFLAGS = $(AM_CPPFLAGS)
>> bspconsole_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>> include_bsp_HEADERS = include/opbintctrl.h
>> noinst_PROGRAMS += opbintctrl.rel
>> opbintctrl_rel_SOURCES = opbintctrl/opbintctrl.c
>> opbintctrl_rel_CPPFLAGS = $(AM_CPPFLAGS)
>> opbintctrl_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>> include_bsp_HEADERS += irq/irq.h
>> noinst_PROGRAMS += irq.rel
>> irq_rel_SOURCES = irq/irq_init.c ../shared/irq/irq_asm.S
>> irq_rel_CPPFLAGS = $(AM_CPPFLAGS)
>> irq_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>> include_bsp_HEADERS += ../../powerpc/shared/vectors/vectors.h
>> noinst_PROGRAMS += vectors.rel
>> vectors_rel_SOURCES = ../../powerpc/shared/vectors/vectors.h \
>>     ../../powerpc/shared/vectors/vectors_init.c \
>>     ../../powerpc/shared/vectors/vectors.S
>> vectors_rel_CPPFLAGS = $(AM_CPPFLAGS)
>> vectors_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>> if HAS_NETWORKING
>> network_CPPFLAGS = -D__INSIDE_RTEMS_BSD_TCPIP_STACK__
>> network_CPPFLAGS += -D__BSD_VISIBLE
>> noinst_PROGRAMS += network.rel
>> network_rel_SOURCES = network/xiltemac.c
>> network_rel_CPPFLAGS = $(AM_CPPFLAGS)
>> network_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>> endif
>> noinst_LIBRARIES = libbsp.a
>> libbsp_a_SOURCES =
>> libbsp_a_LIBADD = startup.rel dlentry.rel bspconsole.rel opbintctrl.rel \
>> 	vectors.rel irq.rel network.rel
>> libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/@exceptions@/rtems-cpu.rel \
>>     ../../../libcpu/@RTEMS_CPU@/@exceptions@/raw_exception.rel \
>>     ../../../libcpu/@RTEMS_CPU@/shared/cpuIdent.rel \
>>     ../../../libcpu/@RTEMS_CPU@/ppc403/clock.rel \
>>     ../../../libcpu/@RTEMS_CPU@/ppc403/timer.rel \
>>     ../../../libcpu/@RTEMS_CPU@/ppc403/tty_drv.rel
>> EXTRA_DIST = times
>> #RSG Added for C++ support
>> #EXTRA_DIST += dlentry/rtems_crti.S
>> #rtems_crti.$(OBJEXT): dlentry/rtems_crti.S
>> #	$(CPPASCOMPILE) -o $@ -c $<
>> EXTRA_DIST += ../shared/start/rtems_crti.S
>> rtems_crti.$(OBJEXT): ../shared/start/rtems_crti.S
>> project_lib_DATA = rtems_crti.$(OBJEXT)
>> #RSG End
>> include $(srcdir)/preinstall.am
>> include $(top_srcdir)/../../../../automake/local.am
>> # Makefile.in generated by automake 1.10 from Makefile.am.
>> # @configure_input@
>> # Copyright (C) 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002,
>> # 2003, 2004, 2005, 2006  Free Software Foundation, Inc.
>> # This Makefile.in is free software; the Free Software Foundation
>> # gives unlimited permission to copy and/or distribute it,
>> # with or without modifications, as long as this notice is preserved.
>> # This program is distributed in the hope that it will be useful,
>> # but WITHOUT ANY WARRANTY, to the extent permitted by law; without
>> # even the implied warranty of MERCHANTABILITY or FITNESS FOR A
>> # PARTICULAR PURPOSE.
>> @SET_MAKE@
>> VPATH = @srcdir@
>> pkgdatadir = $(datadir)/@PACKAGE@
>> pkglibdir = $(libdir)/@PACKAGE@
>> pkgincludedir = $(includedir)/@PACKAGE@
>> am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd
>> install_sh_DATA = $(install_sh) -c -m 644
>> install_sh_PROGRAM = $(install_sh) -c
>> install_sh_SCRIPT = $(install_sh) -c
>> INSTALL_HEADER = $(INSTALL_DATA)
>> transform = $(program_transform_name)
>> NORMAL_INSTALL = :
>> PRE_INSTALL = :
>> POST_INSTALL = :
>> NORMAL_UNINSTALL = :
>> PRE_UNINSTALL = :
>> POST_UNINSTALL = :
>> build_triplet = @build@
>> host_triplet = @host@
>> DIST_COMMON = README $(am__configure_deps) $(dist_project_lib_DATA) \
>> 	$(include_HEADERS) $(include_bsp_HEADERS) \
>> 	$(srcdir)/../../../../../../config.guess \
>> 	$(srcdir)/../../../../../../config.sub \
>> 	$(srcdir)/../../../../../../depcomp \
>> 	$(srcdir)/../../../../../../install-sh \
>> 	$(srcdir)/../../../../../../missing $(srcdir)/Makefile.am \
>> 	$(srcdir)/Makefile.in $(srcdir)/preinstall.am \
>> 	$(top_srcdir)/../../../../automake/compile.am \
>> 	$(top_srcdir)/../../../../automake/local.am \
>> 	$(top_srcdir)/../../bsp.am $(top_srcdir)/configure \
>> 	$(top_srcdir)/include/bspopts.h.in ../../../../../../COPYING \
>> 	../../../../../../ChangeLog ../../../../../../INSTALL \
>> 	../../../../../../README ../../../../../../compile \
>> 	../../../../../../config.guess ../../../../../../config.sub \
>> 	../../../../../../depcomp ../../../../../../install-sh \
>> 	../../../../../../mdate-sh ../../../../../../missing \
>> 	../../../../../../texinfo.tex ChangeLog
>> noinst_PROGRAMS = startup.rel$(EXEEXT) dlentry.rel$(EXEEXT) \
>> 	bspconsole.rel$(EXEEXT) opbintctrl.rel$(EXEEXT) \
>> 	irq.rel$(EXEEXT) vectors.rel$(EXEEXT) $(am__EXEEXT_1)
>> @HAS_NETWORKING_TRUE at am__append_1 = network.rel
>> subdir = .
>> ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
>> am__aclocal_m4_deps =  \
>> 	$(top_srcdir)/../../../../aclocal/bsp-configure.m4 \
>> 	$(top_srcdir)/../../../../aclocal/bspopts.m4 \
>> 	$(top_srcdir)/../../../../aclocal/canonical-target-name.m4 \
>> 	$(top_srcdir)/../../../../aclocal/canonicalize-tools.m4 \
>> 	$(top_srcdir)/../../../../aclocal/check-custom-bsp.m4 \
>> 	$(top_srcdir)/../../../../aclocal/check-multiprocessing.m4 \
>> 	$(top_srcdir)/../../../../aclocal/check-networking.m4 \
>> 	$(top_srcdir)/../../../../aclocal/check-tool.m4 \
>> 	$(top_srcdir)/../../../../aclocal/enable-multiprocessing.m4 \
>> 	$(top_srcdir)/../../../../aclocal/enable-networking.m4 \
>> 	$(top_srcdir)/../../../../aclocal/env-rtemsbsp.m4 \
>> 	$(top_srcdir)/../../../../aclocal/gcc-isystem.m4 \
>> 	$(top_srcdir)/../../../../aclocal/gcc-pipe.m4 \
>> 	$(top_srcdir)/../../../../aclocal/gcc-specs.m4 \
>> 	$(top_srcdir)/../../../../aclocal/multilib.m4 \
>> 	$(top_srcdir)/../../../../aclocal/ppc.m4 \
>> 	$(top_srcdir)/../../../../aclocal/prog-cc.m4 \
>> 	$(top_srcdir)/../../../../aclocal/prog-ccas.m4 \
>> 	$(top_srcdir)/../../../../aclocal/project-root.m4 \
>> 	$(top_srcdir)/../../../../aclocal/rtems-ampolish.m4 \
>> 	$(top_srcdir)/../../../../aclocal/rtems-top.m4 \
>> 	$(top_srcdir)/../../../../aclocal/version.m4 \
>> 	$(top_srcdir)/configure.ac
>> am__configure_deps = $(am__aclocal_m4_deps) $(CONFIGURE_DEPENDENCIES) \
>> 	$(ACLOCAL_M4)
>> am__CONFIG_DISTCLEAN_FILES = config.status config.cache config.log \
>>  configure.lineno config.status.lineno
>> mkinstalldirs = $(install_sh) -d
>> CONFIG_HEADER = $(top_builddir)/include/bspopts.tmp
>> CONFIG_CLEAN_FILES =
>> LIBRARIES = $(noinst_LIBRARIES)
>> ARFLAGS = cru
>> libbsp_a_AR = $(AR) $(ARFLAGS)
>> libbsp_a_DEPENDENCIES = startup.rel dlentry.rel bspconsole.rel \
>> 	opbintctrl.rel vectors.rel irq.rel network.rel \
>> am_libbsp_a_OBJECTS =
>> libbsp_a_OBJECTS = $(am_libbsp_a_OBJECTS)
>> @HAS_NETWORKING_TRUE at am__EXEEXT_1 = network.rel$(EXEEXT)
>> PROGRAMS = $(noinst_PROGRAMS)
>> am_bspconsole_rel_OBJECTS = bspconsole_rel-consolelite.$(OBJEXT) \
>> 	bspconsole_rel-console.$(OBJEXT)
>> bspconsole_rel_OBJECTS = $(am_bspconsole_rel_OBJECTS)
>> bspconsole_rel_LDADD = $(LDADD)
>> bspconsole_rel_LINK = $(CCLD) $(AM_CFLAGS) $(CFLAGS) \
>> 	$(bspconsole_rel_LDFLAGS) $(LDFLAGS) -o $@
>> am_dlentry_rel_OBJECTS = dlentry_rel-dlentry.$(OBJEXT)
>> dlentry_rel_OBJECTS = $(am_dlentry_rel_OBJECTS)
>> dlentry_rel_LDADD = $(LDADD)
>> dlentry_rel_LINK = $(CCLD) $(AM_CFLAGS) $(CFLAGS) \
>> 	$(dlentry_rel_LDFLAGS) $(LDFLAGS) -o $@
>> am_irq_rel_OBJECTS = irq_rel-irq_init.$(OBJEXT) \
>> 	irq_rel-irq_asm.$(OBJEXT)
>> irq_rel_OBJECTS = $(am_irq_rel_OBJECTS)
>> irq_rel_LDADD = $(LDADD)
>> irq_rel_LINK = $(CCLD) $(AM_CFLAGS) $(CFLAGS) $(irq_rel_LDFLAGS) \
>> 	$(LDFLAGS) -o $@
>> am__network_rel_SOURCES_DIST = network/xiltemac.c
>> @HAS_NETWORKING_TRUE at am_network_rel_OBJECTS =  \
>> @HAS_NETWORKING_TRUE@	network_rel-xiltemac.$(OBJEXT)
>> network_rel_OBJECTS = $(am_network_rel_OBJECTS)
>> network_rel_LDADD = $(LDADD)
>> network_rel_LINK = $(CCLD) $(AM_CFLAGS) $(CFLAGS) \
>> 	$(network_rel_LDFLAGS) $(LDFLAGS) -o $@
>> am_opbintctrl_rel_OBJECTS = opbintctrl_rel-opbintctrl.$(OBJEXT)
>> opbintctrl_rel_OBJECTS = $(am_opbintctrl_rel_OBJECTS)
>> opbintctrl_rel_LDADD = $(LDADD)
>> opbintctrl_rel_LINK = $(CCLD) $(AM_CFLAGS) $(CFLAGS) \
>> 	$(opbintctrl_rel_LDFLAGS) $(LDFLAGS) -o $@
>> am_startup_rel_OBJECTS = startup_rel-bspclean.$(OBJEXT) \
>> 	startup_rel-bsplibc.$(OBJEXT) startup_rel-bsppost.$(OBJEXT) \
>> 	startup_rel-bspstart.$(OBJEXT) startup_rel-bootcard.$(OBJEXT) \
>> 	startup_rel-sbrk.$(OBJEXT) startup_rel-setvec.$(OBJEXT) \
>> 	startup_rel-gnatinstallhandler.$(OBJEXT)
>> startup_rel_OBJECTS = $(am_startup_rel_OBJECTS)
>> startup_rel_LDADD = $(LDADD)
>> startup_rel_LINK = $(CCLD) $(AM_CFLAGS) $(CFLAGS) \
>> 	$(startup_rel_LDFLAGS) $(LDFLAGS) -o $@
>> am_vectors_rel_OBJECTS = vectors_rel-vectors_init.$(OBJEXT) \
>> 	vectors_rel-vectors.$(OBJEXT)
>> vectors_rel_OBJECTS = $(am_vectors_rel_OBJECTS)
>> vectors_rel_LDADD = $(LDADD)
>> vectors_rel_LINK = $(CCLD) $(AM_CFLAGS) $(CFLAGS) \
>> 	$(vectors_rel_LDFLAGS) $(LDFLAGS) -o $@
>> DEFAULT_INCLUDES =
>> depcomp = $(SHELL) $(top_srcdir)/../../../../../../depcomp
>> am__depfiles_maybe = depfiles
>> COMPILE = $(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) \
>> 	$(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS)
>> CCLD = $(CC)
>> LINK = $(CCLD) $(AM_CFLAGS) $(CFLAGS) $(AM_LDFLAGS) $(LDFLAGS) -o $@
>> SOURCES = $(libbsp_a_SOURCES) $(bspconsole_rel_SOURCES) \
>> 	$(dlentry_rel_SOURCES) $(irq_rel_SOURCES) \
>> 	$(network_rel_SOURCES) $(opbintctrl_rel_SOURCES) \
>> 	$(startup_rel_SOURCES) $(vectors_rel_SOURCES)
>> DIST_SOURCES = $(libbsp_a_SOURCES) $(bspconsole_rel_SOURCES) \
>> 	$(am__network_rel_SOURCES_DIST) $(opbintctrl_rel_SOURCES) \
>> am__vpath_adj_setup = srcdirstrip=`echo "$(srcdir)" | sed 's|.|.|g'`;
>> am__vpath_adj = case $$p in \
>>     $(srcdir)/*) f=`echo "$$p" | sed "s|^$$srcdirstrip/||"`;; \
>>     *) f=$$p;; \
>>   esac;
>> am__strip_dir = `echo $$p | sed -e 's|^.*/||'`;
>> am__installdirs = "$(DESTDIR)$(project_libdir)" \
>> 	"$(DESTDIR)$(project_libdir)" "$(DESTDIR)$(includedir)" \
>> 	"$(DESTDIR)$(include_bspdir)" "$(DESTDIR)$(includedir)"
>> dist_project_libDATA_INSTALL = $(INSTALL_DATA)
>> DATA = $(dist_project_lib_DATA) $(project_lib_DATA)
>> includeHEADERS_INSTALL = $(INSTALL_HEADER)
>> include_bspHEADERS_INSTALL = $(INSTALL_HEADER)
>> nodist_includeHEADERS_INSTALL = $(INSTALL_HEADER)
>> HEADERS = $(include_HEADERS) $(include_bsp_HEADERS) \
>> 	$(nodist_include_HEADERS)
>> ETAGS = etags
>> CTAGS = ctags
>> DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST)
>> distdir = $(PACKAGE)-$(VERSION)
>> top_distdir = $(distdir)
>> am__remove_distdir = \
>>   { test ! -d $(distdir) \
>>     || { find $(distdir) -type d ! -perm -200 -exec chmod u+w {} ';' \
>>          && rm -fr $(distdir); }; }
>> DIST_ARCHIVES = $(distdir).tar.gz
>> GZIP_ENV = --best
>> distuninstallcheck_listfiles = find . -type f -print
>> distcleancheck_listfiles = find . -type f -print
>> ACLOCAL = @ACLOCAL@
>> AMPOLISH3 = @AMPOLISH3@
>> AMTAR = @AMTAR@
>> AR = @AR@
>> AS = @AS@
>> AUTOCONF = @AUTOCONF@
>> AUTOHEADER = @AUTOHEADER@
>> AUTOMAKE = @AUTOMAKE@
>> AWK = @AWK@
>> CC = @CC@ $(GCCSPECS)
>> CCAS = @CCAS@ $(GCCSPECS)
>> CCASDEPMODE = @CCASDEPMODE@
>> CCASFLAGS = @CCASFLAGS@
>> CCDEPMODE = @CCDEPMODE@
>> CFLAGS = @CFLAGS@
>> CPP = @CPP@ $(GCCSPECS)
>> CPPFLAGS = @CPPFLAGS@
>> CYGPATH_W = @CYGPATH_W@
>> DEFS = @DEFS@
>> DEPDIR = @DEPDIR@
>> ECHO_C = @ECHO_C@
>> ECHO_N = @ECHO_N@
>> ECHO_T = @ECHO_T@
>> EXEEXT = @EXEEXT@
>> GCCSPECS = @GCCSPECS@
>> HAS_NETWORKING = @HAS_NETWORKING@
>> INSTALL = @INSTALL@
>> INSTALL_DATA = @INSTALL_DATA@
>> INSTALL_PROGRAM = @INSTALL_PROGRAM@
>> INSTALL_SCRIPT = @INSTALL_SCRIPT@
>> INSTALL_STRIP_PROGRAM = @INSTALL_STRIP_PROGRAM@
>> LD = @LD@
>> LDFLAGS = @LDFLAGS@
>> LIBOBJS = @LIBOBJS@
>> LIBS = @LIBS@
>> LTLIBOBJS = @LTLIBOBJS@
>> MAINT = @MAINT@
>> MAKE = @MAKE@
>> MAKEINFO = @MAKEINFO@
>> MKDIR_P = @MKDIR_P@
>> OBJEXT = @OBJEXT@
>> PACKAGE = @PACKAGE@
>> PACKAGE_BUGREPORT = @PACKAGE_BUGREPORT@
>> PACKAGE_NAME = @PACKAGE_NAME@
>> PACKAGE_STRING = @PACKAGE_STRING@
>> PACKAGE_TARNAME = @PACKAGE_TARNAME@
>> PACKAGE_VERSION = @PACKAGE_VERSION@
>> PATH_SEPARATOR = @PATH_SEPARATOR@
>> PERL = @PERL@
>> PROJECT_INCLUDE = @PROJECT_INCLUDE@
>> PROJECT_LIB = @PROJECT_LIB@
>> PROJECT_RELEASE = @PROJECT_RELEASE@
>> PROJECT_ROOT = @PROJECT_ROOT@
>> PROJECT_TOPdir = @PROJECT_TOPdir@
>> RANLIB = @RANLIB@
>> RTEMS_BSP = @RTEMS_BSP@
>> RTEMS_BSP_FAMILY = @RTEMS_BSP_FAMILY@
>> RTEMS_CCASFLAGS = @RTEMS_CCASFLAGS@
>> RTEMS_CFLAGS = @RTEMS_CFLAGS@
>> RTEMS_CPPFLAGS = @RTEMS_CPPFLAGS@
>> RTEMS_CPU = @RTEMS_CPU@
>> RTEMS_CPU_MODEL = @RTEMS_CPU_MODEL@
>> RTEMS_HAS_NETWORKING = @RTEMS_HAS_NETWORKING@
>> RTEMS_HOST = @RTEMS_HOST@
>> RTEMS_RELLDFLAGS = @RTEMS_RELLDFLAGS@
>> RTEMS_TOPdir = @RTEMS_TOPdir@
>> SET_MAKE = @SET_MAKE@
>> SHELL = @SHELL@
>> STRIP = @STRIP@
>> VERSION = @VERSION@
>> abs_builddir = @abs_builddir@
>> abs_srcdir = @abs_srcdir@
>> abs_top_builddir = @abs_top_builddir@
>> abs_top_srcdir = @abs_top_srcdir@
>> ac_ct_CC = @ac_ct_CC@
>> am__include = @am__include@
>> am__leading_dot = @am__leading_dot@
>> am__quote = @am__quote@
>> am__tar = @am__tar@
>> am__untar = @am__untar@
>> bindir = @bindir@
>> build = @build@
>> build_alias = @build_alias@
>> build_cpu = @build_cpu@
>> build_os = @build_os@
>> build_vendor = @build_vendor@
>> builddir = @builddir@
>> datadir = @datadir@
>> datarootdir = @datarootdir@
>> dirstamp = @dirstamp@
>> docdir = @docdir@
>> dvidir = @dvidir@
>> exceptions = @exceptions@
>> exec_prefix = @exec_prefix@
>> host = @host@
>> host_alias = @host_alias@
>> host_cpu = @host_cpu@
>> host_os = @host_os@
>> host_vendor = @host_vendor@
>> htmldir = @htmldir@
>> includedir = @includedir@
>> infodir = @infodir@
>> install_sh = @install_sh@
>> libdir = @libdir@
>> libexecdir = @libexecdir@
>> localedir = @localedir@
>> localstatedir = @localstatedir@
>> mandir = @mandir@
>> mkdir_p = @mkdir_p@
>> oldincludedir = @oldincludedir@
>> pdfdir = @pdfdir@
>> prefix = @prefix@
>> program_transform_name = @program_transform_name@
>> project_includedir = @project_includedir@
>> project_libdir = @project_libdir@
>> psdir = @psdir@
>> sbindir = @sbindir@
>> sharedstatedir = @sharedstatedir@
>> srcdir = @srcdir@
>> sysconfdir = @sysconfdir@
>> target_alias = @target_alias@
>> top_builddir = @top_builddir@
>> top_srcdir = @top_srcdir@
>> CXX = @CXX@ $(GCCSPECS)
>> AM_CPPFLAGS = @RTEMS_CPPFLAGS@
>> AM_CFLAGS = @RTEMS_CFLAGS@
>> AM_CXXFLAGS = @RTEMS_CFLAGS@
>> AM_CCASFLAGS = @RTEMS_CCASFLAGS@
>> # to be able to use it for compilation of *.S even if automake
>> # doesn't generate this variable. (automake-1.8.2+ only generates
>> # this rule if *_SOURCES contain *.S.)
>> CPPASCOMPILE = $(CCAS) $(AM_CPPFLAGS) $(CPPFLAGS) $(AM_CCASFLAGS) $(CCASFLAGS)
>> dist_project_lib_DATA = bsp_specs startup/linkcmds startup/linkcmds.dl
>> include_HEADERS = include/bsp.h include/tm27.h include/coverhd.h
>> DISTCLEANFILES = include/bspopts.h $(PREINSTALL_DIRS)
>> include_bsp_HEADERS = include/opbintctrl.h irq/irq.h \
>> @HAS_NETWORKING_TRUE at network_CPPFLAGS =  \
>> @HAS_NETWORKING_TRUE@	-D__INSIDE_RTEMS_BSD_TCPIP_STACK__ \
>> @HAS_NETWORKING_TRUE@	-D__BSD_VISIBLE
>> @HAS_NETWORKING_TRUE at network_rel_SOURCES = network/xiltemac.c
>> @HAS_NETWORKING_TRUE at network_rel_CPPFLAGS = $(AM_CPPFLAGS)
>> @HAS_NETWORKING_TRUE at network_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>> libbsp_a_SOURCES =
>> libbsp_a_LIBADD = startup.rel dlentry.rel bspconsole.rel \
>> #EXTRA_DIST = times dlentry/rtems_crti.S
>> EXTRA_DIST = times ../shared/start/rtems_crti.S
>> PREINSTALL_DIRS = $(PROJECT_LIB)/$(dirstamp) \
>> 	$(PROJECT_INCLUDE)/$(dirstamp) \
>> 	$(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> PREINSTALL_FILES = $(PROJECT_LIB)/bsp_specs $(PROJECT_INCLUDE)/bsp.h \
>> 	$(PROJECT_INCLUDE)/bsp/opbintctrl.h \
>> 	$(PROJECT_INCLUDE)/bsp/irq.h $(PROJECT_INCLUDE)/bsp/vectors.h \
>> 	$(PROJECT_INCLUDE)/xiltemac.h \
>> 	$(PROJECT_INCLUDE)/xparameters_dflt.h \
>> 	$(PROJECT_INCLUDE)/tm27.h $(PROJECT_INCLUDE)/bspopts.h \
>> 	$(PROJECT_INCLUDE)/coverhd.h $(PROJECT_LIB)/linkcmds \
>> 	$(PROJECT_LIB)/linkcmds.dl
>> CLEANFILES = $(PREINSTALL_FILES)
>> TMPINSTALL_FILES = $(PROJECT_LIB)/rtems_crti.$(OBJEXT)
>> PROJECT_TOOLS = $(PROJECT_RELEASE)/build-tools
>> all: all-am
>> .SUFFIXES:
>> .SUFFIXES: .S .c .o .obj
>> am--refresh:
>> $(srcdir)/Makefile.in: @MAINTAINER_MODE_TRUE@ $(srcdir)/Makefile.am $(top_srcdir)/../../../../automake/compile.am $(top_srcdir)/../../bsp.am $(srcdir)/preinstall.am $(top_srcdir)/../../../../automake/local.am $(am__configure_deps)
>> 	@for dep in $?; do \
>> 	  case '$(am__configure_deps)' in \
>> 	    *$$dep*) \
>> 	      echo ' cd $(srcdir) && $(AUTOMAKE) --foreign '; \
>> 	      cd $(srcdir) && $(AUTOMAKE) --foreign  \
>> 		&& exit 0; \
>> 	      exit 1;; \
>> 	  esac; \
>> 	done; \
>> 	echo ' cd $(top_srcdir) && $(AUTOMAKE) --foreign  Makefile'; \
>> 	cd $(top_srcdir) && \
>> .PRECIOUS: Makefile
>> Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status
>> 	@case '$?' in \
>> 	  *config.status*) \
>> 	    echo ' $(SHELL) ./config.status'; \
>> 	    $(SHELL) ./config.status;; \
>> 	    echo ' cd $(top_builddir) && $(SHELL) ./config.status $@ $(am__depfiles_maybe)'; \
>> 	    cd $(top_builddir) && $(SHELL) ./config.status $@ $(am__depfiles_maybe);; \
>> 	esac;
>> $(top_builddir)/config.status: $(top_srcdir)/configure $(CONFIG_STATUS_DEPENDENCIES)
>> 	$(SHELL) ./config.status --recheck
>> $(top_srcdir)/configure: @MAINTAINER_MODE_TRUE@ $(am__configure_deps)
>> 	cd $(srcdir) && $(AUTOCONF)
>> $(ACLOCAL_M4): @MAINTAINER_MODE_TRUE@ $(am__aclocal_m4_deps)
>> 	cd $(srcdir) && $(ACLOCAL) $(ACLOCAL_AMFLAGS)
>> include/bspopts.tmp: include/stamp-h1
>> 	@if test ! -f $@; then \
>> 	  rm -f include/stamp-h1; \
>> 	  $(MAKE) $(AM_MAKEFLAGS) include/stamp-h1; \
>> 	else :; fi
>> include/stamp-h1: $(top_srcdir)/include/bspopts.h.in $(top_builddir)/config.status
>> 	@rm -f include/stamp-h1
>> 	cd $(top_builddir) && $(SHELL) ./config.status include/bspopts.tmp
>> $(top_srcdir)/include/bspopts.h.in: @MAINTAINER_MODE_TRUE@ $(am__configure_deps)
>> 	cd $(top_srcdir) && $(AUTOHEADER)
>> 	touch $@
>> distclean-hdr:
>> 	-rm -f include/bspopts.tmp include/stamp-h1
>> clean-noinstLIBRARIES:
>> 	-test -z "$(noinst_LIBRARIES)" || rm -f $(noinst_LIBRARIES)
>> libbsp.a: $(libbsp_a_OBJECTS) $(libbsp_a_DEPENDENCIES)
>> 	-rm -f libbsp.a
>> 	$(libbsp_a_AR) libbsp.a $(libbsp_a_OBJECTS) $(libbsp_a_LIBADD)
>> 	$(RANLIB) libbsp.a
>> clean-noinstPROGRAMS:
>> 	-test -z "$(noinst_PROGRAMS)" || rm -f $(noinst_PROGRAMS)
>> bspconsole.rel$(EXEEXT): $(bspconsole_rel_OBJECTS) $(bspconsole_rel_DEPENDENCIES)
>> 	@rm -f bspconsole.rel$(EXEEXT)
>> 	$(bspconsole_rel_LINK) $(bspconsole_rel_OBJECTS) $(bspconsole_rel_LDADD) $(LIBS)
>> dlentry.rel$(EXEEXT): $(dlentry_rel_OBJECTS) $(dlentry_rel_DEPENDENCIES)
>> 	@rm -f dlentry.rel$(EXEEXT)
>> 	$(dlentry_rel_LINK) $(dlentry_rel_OBJECTS) $(dlentry_rel_LDADD) $(LIBS)
>> irq.rel$(EXEEXT): $(irq_rel_OBJECTS) $(irq_rel_DEPENDENCIES)
>> 	@rm -f irq.rel$(EXEEXT)
>> 	$(irq_rel_LINK) $(irq_rel_OBJECTS) $(irq_rel_LDADD) $(LIBS)
>> network.rel$(EXEEXT): $(network_rel_OBJECTS) $(network_rel_DEPENDENCIES)
>> 	@rm -f network.rel$(EXEEXT)
>> 	$(network_rel_LINK) $(network_rel_OBJECTS) $(network_rel_LDADD) $(LIBS)
>> opbintctrl.rel$(EXEEXT): $(opbintctrl_rel_OBJECTS) $(opbintctrl_rel_DEPENDENCIES)
>> 	@rm -f opbintctrl.rel$(EXEEXT)
>> 	$(opbintctrl_rel_LINK) $(opbintctrl_rel_OBJECTS) $(opbintctrl_rel_LDADD) $(LIBS)
>> startup.rel$(EXEEXT): $(startup_rel_OBJECTS) $(startup_rel_DEPENDENCIES)
>> 	@rm -f startup.rel$(EXEEXT)
>> 	$(startup_rel_LINK) $(startup_rel_OBJECTS) $(startup_rel_LDADD) $(LIBS)
>> vectors.rel$(EXEEXT): $(vectors_rel_OBJECTS) $(vectors_rel_DEPENDENCIES)
>> 	@rm -f vectors.rel$(EXEEXT)
>> 	$(vectors_rel_LINK) $(vectors_rel_OBJECTS) $(vectors_rel_LDADD) $(LIBS)
>> mostlyclean-compile:
>> 	-rm -f *.$(OBJEXT)
>> distclean-compile:
>> 	-rm -f *.tab.c
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/bspconsole_rel-console.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/bspconsole_rel-consolelite.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/dlentry_rel-dlentry.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/irq_rel-irq_asm.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/irq_rel-irq_init.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/network_rel-xiltemac.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/opbintctrl_rel-opbintctrl.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/startup_rel-bootcard.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/startup_rel-bspclean.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/startup_rel-bsplibc.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/startup_rel-bsppost.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/startup_rel-bspstart.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/startup_rel-gnatinstallhandler.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/startup_rel-sbrk.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/startup_rel-setvec.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/vectors_rel-vectors.Po at am__quote@
>> @AMDEP_TRUE@@am__include@ @am__quote at ./$(DEPDIR)/vectors_rel-vectors_init.Po at am__quote@
>> .S.o:
>> @am__fastdepCCAS_TRUE@	$(CPPASCOMPILE) -MT $@ -MD -MP -MF $(DEPDIR)/$*.Tpo -c -o $@ $<
>> @am__fastdepCCAS_TRUE@	mv -f $(DEPDIR)/$*.Tpo $(DEPDIR)/$*.Po
>> @AMDEP_TRUE@@am__fastdepCCAS_FALSE@	source='$<' object='$@' libtool=no @AMDEPBACKSLASH@
>> @AMDEP_TRUE@@am__fastdepCCAS_FALSE@	DEPDIR=$(DEPDIR) $(CCASDEPMODE) $(depcomp) @AMDEPBACKSLASH@
>> @am__fastdepCCAS_FALSE@	$(CPPASCOMPILE) -c -o $@ $<
>> .S.obj:
>> @am__fastdepCCAS_TRUE@	$(CPPASCOMPILE) -MT $@ -MD -MP -MF $(DEPDIR)/$*.Tpo -c -o $@ `$(CYGPATH_W) '$<'`
>> @am__fastdepCCAS_FALSE@	$(CPPASCOMPILE) -c -o $@ `$(CYGPATH_W) '$<'`
>> dlentry_rel-dlentry.o: dlentry/dlentry.S
>> @am__fastdepCCAS_TRUE@	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(dlentry_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CCASFLAGS) $(CCASFLAGS) -MT dlentry_rel-dlentry.o -MD -MP -MF $(DEPDIR)/dlentry_rel-dlentry.Tpo -c -o dlentry_rel-dlentry.o `test -f 'dlentry/dlentry.S' || echo '$(srcdir)/'`dlentry/dlentry.S
>> @am__fastdepCCAS_TRUE@	mv -f $(DEPDIR)/dlentry_rel-dlentry.Tpo $(DEPDIR)/dlentry_rel-dlentry.Po
>> @AMDEP_TRUE@@am__fastdepCCAS_FALSE@	source='dlentry/dlentry.S' object='dlentry_rel-dlentry.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCCAS_FALSE@	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(dlentry_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CCASFLAGS) $(CCASFLAGS) -c -o dlentry_rel-dlentry.o `test -f 'dlentry/dlentry.S' || echo '$(srcdir)/'`dlentry/dlentry.S
>> dlentry_rel-dlentry.obj: dlentry/dlentry.S
>> @am__fastdepCCAS_TRUE@	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(dlentry_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CCASFLAGS) $(CCASFLAGS) -MT dlentry_rel-dlentry.obj -MD -MP -MF $(DEPDIR)/dlentry_rel-dlentry.Tpo -c -o dlentry_rel-dlentry.obj `if test -f 'dlentry/dlentry.S'; then $(CYGPATH_W) 'dlentry/dlentry.S'; else $(CYGPATH_W) '$(srcdir)/dlentry/dlentry.S'; fi`
>> @AMDEP_TRUE@@am__fastdepCCAS_FALSE@	source='dlentry/dlentry.S' object='dlentry_rel-dlentry.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCCAS_FALSE@	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(dlentry_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CCASFLAGS) $(CCASFLAGS) -c -o dlentry_rel-dlentry.obj `if test -f 'dlentry/dlentry.S'; then $(CYGPATH_W) 'dlentry/dlentry.S'; else $(CYGPATH_W) '$(srcdir)/dlentry/dlentry.S'; fi`
>> irq_rel-irq_asm.o: ../shared/irq/irq_asm.S
>> @am__fastdepCCAS_TRUE@	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(irq_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CCASFLAGS) $(CCASFLAGS) -MT irq_rel-irq_asm.o -MD -MP -MF $(DEPDIR)/irq_rel-irq_asm.Tpo -c -o irq_rel-irq_asm.o `test -f '../shared/irq/irq_asm.S' || echo '$(srcdir)/'`../shared/irq/irq_asm.S
>> @am__fastdepCCAS_TRUE@	mv -f $(DEPDIR)/irq_rel-irq_asm.Tpo $(DEPDIR)/irq_rel-irq_asm.Po
>> @AMDEP_TRUE@@am__fastdepCCAS_FALSE@	source='../shared/irq/irq_asm.S' object='irq_rel-irq_asm.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCCAS_FALSE@	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(irq_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CCASFLAGS) $(CCASFLAGS) -c -o irq_rel-irq_asm.o `test -f '../shared/irq/irq_asm.S' || echo '$(srcdir)/'`../shared/irq/irq_asm.S
>> irq_rel-irq_asm.obj: ../shared/irq/irq_asm.S
>> @am__fastdepCCAS_TRUE@	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(irq_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CCASFLAGS) $(CCASFLAGS) -MT irq_rel-irq_asm.obj -MD -MP -MF $(DEPDIR)/irq_rel-irq_asm.Tpo -c -o irq_rel-irq_asm.obj `if test -f '../shared/irq/irq_asm.S'; then $(CYGPATH_W) '../shared/irq/irq_asm.S'; else $(CYGPATH_W) '$(srcdir)/../shared/irq/irq_asm.S'; fi`
>> @AMDEP_TRUE@@am__fastdepCCAS_FALSE@	source='../shared/irq/irq_asm.S' object='irq_rel-irq_asm.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCCAS_FALSE@	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(irq_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CCASFLAGS) $(CCASFLAGS) -c -o irq_rel-irq_asm.obj `if test -f '../shared/irq/irq_asm.S'; then $(CYGPATH_W) '../shared/irq/irq_asm.S'; else $(CYGPATH_W) '$(srcdir)/../shared/irq/irq_asm.S'; fi`
>> vectors_rel-vectors.o: ../../powerpc/shared/vectors/vectors.S
>> @am__fastdepCCAS_TRUE@	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(vectors_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CCASFLAGS) $(CCASFLAGS) -MT vectors_rel-vectors.o -MD -MP -MF $(DEPDIR)/vectors_rel-vectors.Tpo -c -o vectors_rel-vectors.o `test -f '../../powerpc/shared/vectors/vectors.S' || echo '$(srcdir)/'`../../powerpc/shared/vectors/vectors.S
>> @am__fastdepCCAS_TRUE@	mv -f $(DEPDIR)/vectors_rel-vectors.Tpo $(DEPDIR)/vectors_rel-vectors.Po
>> @AMDEP_TRUE@@am__fastdepCCAS_FALSE@	source='../../powerpc/shared/vectors/vectors.S' object='vectors_rel-vectors.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCCAS_FALSE@	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(vectors_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CCASFLAGS) $(CCASFLAGS) -c -o vectors_rel-vectors.o `test -f '../../powerpc/shared/vectors/vectors.S' || echo '$(srcdir)/'`../../powerpc/shared/vectors/vectors.S
>> vectors_rel-vectors.obj: ../../powerpc/shared/vectors/vectors.S
>> @am__fastdepCCAS_TRUE@	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(vectors_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CCASFLAGS) $(CCASFLAGS) -MT vectors_rel-vectors.obj -MD -MP -MF $(DEPDIR)/vectors_rel-vectors.Tpo -c -o vectors_rel-vectors.obj `if test -f '../../powerpc/shared/vectors/vectors.S'; then $(CYGPATH_W) '../../powerpc/shared/vectors/vectors.S'; else $(CYGPATH_W) '$(srcdir)/../../powerpc/shared/vectors/vectors.S'; fi`
>> @AMDEP_TRUE@@am__fastdepCCAS_FALSE@	source='../../powerpc/shared/vectors/vectors.S' object='vectors_rel-vectors.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCCAS_FALSE@	$(CCAS) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(vectors_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CCASFLAGS) $(CCASFLAGS) -c -o vectors_rel-vectors.obj `if test -f '../../powerpc/shared/vectors/vectors.S'; then $(CYGPATH_W) '../../powerpc/shared/vectors/vectors.S'; else $(CYGPATH_W) '$(srcdir)/../../powerpc/shared/vectors/vectors.S'; fi`
>> .c.o:
>> @am__fastdepCC_TRUE@	$(COMPILE) -MT $@ -MD -MP -MF $(DEPDIR)/$*.Tpo -c -o $@ $<
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/$*.Tpo $(DEPDIR)/$*.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='$<' object='$@' libtool=no @AMDEPBACKSLASH@
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	DEPDIR=$(DEPDIR) $(CCDEPMODE) $(depcomp) @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(COMPILE) -c $<
>> .c.obj:
>> @am__fastdepCC_TRUE@	$(COMPILE) -MT $@ -MD -MP -MF $(DEPDIR)/$*.Tpo -c -o $@ `$(CYGPATH_W) '$<'`
>> @am__fastdepCC_FALSE@	$(COMPILE) -c `$(CYGPATH_W) '$<'`
>> bspconsole_rel-consolelite.o: console/consolelite.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(bspconsole_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT bspconsole_rel-consolelite.o -MD -MP -MF $(DEPDIR)/bspconsole_rel-consolelite.Tpo -c -o bspconsole_rel-consolelite.o `test -f 'console/consolelite.c' || echo '$(srcdir)/'`console/consolelite.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/bspconsole_rel-consolelite.Tpo $(DEPDIR)/bspconsole_rel-consolelite.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='console/consolelite.c' object='bspconsole_rel-consolelite.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(bspconsole_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o bspconsole_rel-consolelite.o `test -f 'console/consolelite.c' || echo '$(srcdir)/'`console/consolelite.c
>> bspconsole_rel-consolelite.obj: console/consolelite.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(bspconsole_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT bspconsole_rel-consolelite.obj -MD -MP -MF $(DEPDIR)/bspconsole_rel-consolelite.Tpo -c -o bspconsole_rel-consolelite.obj `if test -f 'console/consolelite.c'; then $(CYGPATH_W) 'console/consolelite.c'; else $(CYGPATH_W) '$(srcdir)/console/consolelite.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='console/consolelite.c' object='bspconsole_rel-consolelite.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(bspconsole_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o bspconsole_rel-consolelite.obj `if test -f 'console/consolelite.c'; then $(CYGPATH_W) 'console/consolelite.c'; else $(CYGPATH_W) '$(srcdir)/console/consolelite.c'; fi`
>> bspconsole_rel-console.o: ../../shared/console.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(bspconsole_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT bspconsole_rel-console.o -MD -MP -MF $(DEPDIR)/bspconsole_rel-console.Tpo -c -o bspconsole_rel-console.o `test -f '../../shared/console.c' || echo '$(srcdir)/'`../../shared/console.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/bspconsole_rel-console.Tpo $(DEPDIR)/bspconsole_rel-console.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../shared/console.c' object='bspconsole_rel-console.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(bspconsole_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o bspconsole_rel-console.o `test -f '../../shared/console.c' || echo '$(srcdir)/'`../../shared/console.c
>> bspconsole_rel-console.obj: ../../shared/console.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(bspconsole_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT bspconsole_rel-console.obj -MD -MP -MF $(DEPDIR)/bspconsole_rel-console.Tpo -c -o bspconsole_rel-console.obj `if test -f '../../shared/console.c'; then $(CYGPATH_W) '../../shared/console.c'; else $(CYGPATH_W) '$(srcdir)/../../shared/console.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../shared/console.c' object='bspconsole_rel-console.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(bspconsole_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o bspconsole_rel-console.obj `if test -f '../../shared/console.c'; then $(CYGPATH_W) '../../shared/console.c'; else $(CYGPATH_W) '$(srcdir)/../../shared/console.c'; fi`
>> irq_rel-irq_init.o: irq/irq_init.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(irq_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT irq_rel-irq_init.o -MD -MP -MF $(DEPDIR)/irq_rel-irq_init.Tpo -c -o irq_rel-irq_init.o `test -f 'irq/irq_init.c' || echo '$(srcdir)/'`irq/irq_init.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/irq_rel-irq_init.Tpo $(DEPDIR)/irq_rel-irq_init.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='irq/irq_init.c' object='irq_rel-irq_init.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(irq_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o irq_rel-irq_init.o `test -f 'irq/irq_init.c' || echo '$(srcdir)/'`irq/irq_init.c
>> irq_rel-irq_init.obj: irq/irq_init.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(irq_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT irq_rel-irq_init.obj -MD -MP -MF $(DEPDIR)/irq_rel-irq_init.Tpo -c -o irq_rel-irq_init.obj `if test -f 'irq/irq_init.c'; then $(CYGPATH_W) 'irq/irq_init.c'; else $(CYGPATH_W) '$(srcdir)/irq/irq_init.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='irq/irq_init.c' object='irq_rel-irq_init.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(irq_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o irq_rel-irq_init.obj `if test -f 'irq/irq_init.c'; then $(CYGPATH_W) 'irq/irq_init.c'; else $(CYGPATH_W) '$(srcdir)/irq/irq_init.c'; fi`
>> network_rel-xiltemac.o: network/xiltemac.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(network_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT network_rel-xiltemac.o -MD -MP -MF $(DEPDIR)/network_rel-xiltemac.Tpo -c -o network_rel-xiltemac.o `test -f 'network/xiltemac.c' || echo '$(srcdir)/'`network/xiltemac.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/network_rel-xiltemac.Tpo $(DEPDIR)/network_rel-xiltemac.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='network/xiltemac.c' object='network_rel-xiltemac.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(network_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o network_rel-xiltemac.o `test -f 'network/xiltemac.c' || echo '$(srcdir)/'`network/xiltemac.c
>> network_rel-xiltemac.obj: network/xiltemac.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(network_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT network_rel-xiltemac.obj -MD -MP -MF $(DEPDIR)/network_rel-xiltemac.Tpo -c -o network_rel-xiltemac.obj `if test -f 'network/xiltemac.c'; then $(CYGPATH_W) 'network/xiltemac.c'; else $(CYGPATH_W) '$(srcdir)/network/xiltemac.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='network/xiltemac.c' object='network_rel-xiltemac.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(network_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o network_rel-xiltemac.obj `if test -f 'network/xiltemac.c'; then $(CYGPATH_W) 'network/xiltemac.c'; else $(CYGPATH_W) '$(srcdir)/network/xiltemac.c'; fi`
>> opbintctrl_rel-opbintctrl.o: opbintctrl/opbintctrl.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(opbintctrl_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT opbintctrl_rel-opbintctrl.o -MD -MP -MF $(DEPDIR)/opbintctrl_rel-opbintctrl.Tpo -c -o opbintctrl_rel-opbintctrl.o `test -f 'opbintctrl/opbintctrl.c' || echo '$(srcdir)/'`opbintctrl/opbintctrl.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/opbintctrl_rel-opbintctrl.Tpo $(DEPDIR)/opbintctrl_rel-opbintctrl.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='opbintctrl/opbintctrl.c' object='opbintctrl_rel-opbintctrl.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(opbintctrl_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o opbintctrl_rel-opbintctrl.o `test -f 'opbintctrl/opbintctrl.c' || echo '$(srcdir)/'`opbintctrl/opbintctrl.c
>> opbintctrl_rel-opbintctrl.obj: opbintctrl/opbintctrl.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(opbintctrl_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT opbintctrl_rel-opbintctrl.obj -MD -MP -MF $(DEPDIR)/opbintctrl_rel-opbintctrl.Tpo -c -o opbintctrl_rel-opbintctrl.obj `if test -f 'opbintctrl/opbintctrl.c'; then $(CYGPATH_W) 'opbintctrl/opbintctrl.c'; else $(CYGPATH_W) '$(srcdir)/opbintctrl/opbintctrl.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='opbintctrl/opbintctrl.c' object='opbintctrl_rel-opbintctrl.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(opbintctrl_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o opbintctrl_rel-opbintctrl.obj `if test -f 'opbintctrl/opbintctrl.c'; then $(CYGPATH_W) 'opbintctrl/opbintctrl.c'; else $(CYGPATH_W) '$(srcdir)/opbintctrl/opbintctrl.c'; fi`
>> startup_rel-bspclean.o: startup/bspclean.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-bspclean.o -MD -MP -MF $(DEPDIR)/startup_rel-bspclean.Tpo -c -o startup_rel-bspclean.o `test -f 'startup/bspclean.c' || echo '$(srcdir)/'`startup/bspclean.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/startup_rel-bspclean.Tpo $(DEPDIR)/startup_rel-bspclean.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='startup/bspclean.c' object='startup_rel-bspclean.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-bspclean.o `test -f 'startup/bspclean.c' || echo '$(srcdir)/'`startup/bspclean.c
>> startup_rel-bspclean.obj: startup/bspclean.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-bspclean.obj -MD -MP -MF $(DEPDIR)/startup_rel-bspclean.Tpo -c -o startup_rel-bspclean.obj `if test -f 'startup/bspclean.c'; then $(CYGPATH_W) 'startup/bspclean.c'; else $(CYGPATH_W) '$(srcdir)/startup/bspclean.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='startup/bspclean.c' object='startup_rel-bspclean.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-bspclean.obj `if test -f 'startup/bspclean.c'; then $(CYGPATH_W) 'startup/bspclean.c'; else $(CYGPATH_W) '$(srcdir)/startup/bspclean.c'; fi`
>> startup_rel-bsplibc.o: ../../shared/bsplibc.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-bsplibc.o -MD -MP -MF $(DEPDIR)/startup_rel-bsplibc.Tpo -c -o startup_rel-bsplibc.o `test -f '../../shared/bsplibc.c' || echo '$(srcdir)/'`../../shared/bsplibc.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/startup_rel-bsplibc.Tpo $(DEPDIR)/startup_rel-bsplibc.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../shared/bsplibc.c' object='startup_rel-bsplibc.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-bsplibc.o `test -f '../../shared/bsplibc.c' || echo '$(srcdir)/'`../../shared/bsplibc.c
>> startup_rel-bsplibc.obj: ../../shared/bsplibc.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-bsplibc.obj -MD -MP -MF $(DEPDIR)/startup_rel-bsplibc.Tpo -c -o startup_rel-bsplibc.obj `if test -f '../../shared/bsplibc.c'; then $(CYGPATH_W) '../../shared/bsplibc.c'; else $(CYGPATH_W) '$(srcdir)/../../shared/bsplibc.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../shared/bsplibc.c' object='startup_rel-bsplibc.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-bsplibc.obj `if test -f '../../shared/bsplibc.c'; then $(CYGPATH_W) '../../shared/bsplibc.c'; else $(CYGPATH_W) '$(srcdir)/../../shared/bsplibc.c'; fi`
>> startup_rel-bsppost.o: ../../shared/bsppost.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-bsppost.o -MD -MP -MF $(DEPDIR)/startup_rel-bsppost.Tpo -c -o startup_rel-bsppost.o `test -f '../../shared/bsppost.c' || echo '$(srcdir)/'`../../shared/bsppost.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/startup_rel-bsppost.Tpo $(DEPDIR)/startup_rel-bsppost.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../shared/bsppost.c' object='startup_rel-bsppost.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-bsppost.o `test -f '../../shared/bsppost.c' || echo '$(srcdir)/'`../../shared/bsppost.c
>> startup_rel-bsppost.obj: ../../shared/bsppost.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-bsppost.obj -MD -MP -MF $(DEPDIR)/startup_rel-bsppost.Tpo -c -o startup_rel-bsppost.obj `if test -f '../../shared/bsppost.c'; then $(CYGPATH_W) '../../shared/bsppost.c'; else $(CYGPATH_W) '$(srcdir)/../../shared/bsppost.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../shared/bsppost.c' object='startup_rel-bsppost.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-bsppost.obj `if test -f '../../shared/bsppost.c'; then $(CYGPATH_W) '../../shared/bsppost.c'; else $(CYGPATH_W) '$(srcdir)/../../shared/bsppost.c'; fi`
>> startup_rel-bspstart.o: startup/bspstart.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-bspstart.o -MD -MP -MF $(DEPDIR)/startup_rel-bspstart.Tpo -c -o startup_rel-bspstart.o `test -f 'startup/bspstart.c' || echo '$(srcdir)/'`startup/bspstart.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/startup_rel-bspstart.Tpo $(DEPDIR)/startup_rel-bspstart.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='startup/bspstart.c' object='startup_rel-bspstart.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-bspstart.o `test -f 'startup/bspstart.c' || echo '$(srcdir)/'`startup/bspstart.c
>> startup_rel-bspstart.obj: startup/bspstart.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-bspstart.obj -MD -MP -MF $(DEPDIR)/startup_rel-bspstart.Tpo -c -o startup_rel-bspstart.obj `if test -f 'startup/bspstart.c'; then $(CYGPATH_W) 'startup/bspstart.c'; else $(CYGPATH_W) '$(srcdir)/startup/bspstart.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='startup/bspstart.c' object='startup_rel-bspstart.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-bspstart.obj `if test -f 'startup/bspstart.c'; then $(CYGPATH_W) 'startup/bspstart.c'; else $(CYGPATH_W) '$(srcdir)/startup/bspstart.c'; fi`
>> startup_rel-bootcard.o: ../../shared/bootcard.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-bootcard.o -MD -MP -MF $(DEPDIR)/startup_rel-bootcard.Tpo -c -o startup_rel-bootcard.o `test -f '../../shared/bootcard.c' || echo '$(srcdir)/'`../../shared/bootcard.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/startup_rel-bootcard.Tpo $(DEPDIR)/startup_rel-bootcard.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../shared/bootcard.c' object='startup_rel-bootcard.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-bootcard.o `test -f '../../shared/bootcard.c' || echo '$(srcdir)/'`../../shared/bootcard.c
>> startup_rel-bootcard.obj: ../../shared/bootcard.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-bootcard.obj -MD -MP -MF $(DEPDIR)/startup_rel-bootcard.Tpo -c -o startup_rel-bootcard.obj `if test -f '../../shared/bootcard.c'; then $(CYGPATH_W) '../../shared/bootcard.c'; else $(CYGPATH_W) '$(srcdir)/../../shared/bootcard.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../shared/bootcard.c' object='startup_rel-bootcard.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-bootcard.obj `if test -f '../../shared/bootcard.c'; then $(CYGPATH_W) '../../shared/bootcard.c'; else $(CYGPATH_W) '$(srcdir)/../../shared/bootcard.c'; fi`
>> startup_rel-sbrk.o: ../../shared/sbrk.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-sbrk.o -MD -MP -MF $(DEPDIR)/startup_rel-sbrk.Tpo -c -o startup_rel-sbrk.o `test -f '../../shared/sbrk.c' || echo '$(srcdir)/'`../../shared/sbrk.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/startup_rel-sbrk.Tpo $(DEPDIR)/startup_rel-sbrk.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../shared/sbrk.c' object='startup_rel-sbrk.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-sbrk.o `test -f '../../shared/sbrk.c' || echo '$(srcdir)/'`../../shared/sbrk.c
>> startup_rel-sbrk.obj: ../../shared/sbrk.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-sbrk.obj -MD -MP -MF $(DEPDIR)/startup_rel-sbrk.Tpo -c -o startup_rel-sbrk.obj `if test -f '../../shared/sbrk.c'; then $(CYGPATH_W) '../../shared/sbrk.c'; else $(CYGPATH_W) '$(srcdir)/../../shared/sbrk.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../shared/sbrk.c' object='startup_rel-sbrk.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-sbrk.obj `if test -f '../../shared/sbrk.c'; then $(CYGPATH_W) '../../shared/sbrk.c'; else $(CYGPATH_W) '$(srcdir)/../../shared/sbrk.c'; fi`
>> startup_rel-setvec.o: startup/setvec.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-setvec.o -MD -MP -MF $(DEPDIR)/startup_rel-setvec.Tpo -c -o startup_rel-setvec.o `test -f 'startup/setvec.c' || echo '$(srcdir)/'`startup/setvec.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/startup_rel-setvec.Tpo $(DEPDIR)/startup_rel-setvec.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='startup/setvec.c' object='startup_rel-setvec.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-setvec.o `test -f 'startup/setvec.c' || echo '$(srcdir)/'`startup/setvec.c
>> startup_rel-setvec.obj: startup/setvec.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-setvec.obj -MD -MP -MF $(DEPDIR)/startup_rel-setvec.Tpo -c -o startup_rel-setvec.obj `if test -f 'startup/setvec.c'; then $(CYGPATH_W) 'startup/setvec.c'; else $(CYGPATH_W) '$(srcdir)/startup/setvec.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='startup/setvec.c' object='startup_rel-setvec.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-setvec.obj `if test -f 'startup/setvec.c'; then $(CYGPATH_W) 'startup/setvec.c'; else $(CYGPATH_W) '$(srcdir)/startup/setvec.c'; fi`
>> startup_rel-gnatinstallhandler.o: ../../shared/gnatinstallhandler.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-gnatinstallhandler.o -MD -MP -MF $(DEPDIR)/startup_rel-gnatinstallhandler.Tpo -c -o startup_rel-gnatinstallhandler.o `test -f '../../shared/gnatinstallhandler.c' || echo '$(srcdir)/'`../../shared/gnatinstallhandler.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/startup_rel-gnatinstallhandler.Tpo $(DEPDIR)/startup_rel-gnatinstallhandler.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../shared/gnatinstallhandler.c' object='startup_rel-gnatinstallhandler.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-gnatinstallhandler.o `test -f '../../shared/gnatinstallhandler.c' || echo '$(srcdir)/'`../../shared/gnatinstallhandler.c
>> startup_rel-gnatinstallhandler.obj: ../../shared/gnatinstallhandler.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT startup_rel-gnatinstallhandler.obj -MD -MP -MF $(DEPDIR)/startup_rel-gnatinstallhandler.Tpo -c -o startup_rel-gnatinstallhandler.obj `if test -f '../../shared/gnatinstallhandler.c'; then $(CYGPATH_W) '../../shared/gnatinstallhandler.c'; else $(CYGPATH_W) '$(srcdir)/../../shared/gnatinstallhandler.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../shared/gnatinstallhandler.c' object='startup_rel-gnatinstallhandler.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(startup_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o startup_rel-gnatinstallhandler.obj `if test -f '../../shared/gnatinstallhandler.c'; then $(CYGPATH_W) '../../shared/gnatinstallhandler.c'; else $(CYGPATH_W) '$(srcdir)/../../shared/gnatinstallhandler.c'; fi`
>> vectors_rel-vectors_init.o: ../../powerpc/shared/vectors/vectors_init.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(vectors_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT vectors_rel-vectors_init.o -MD -MP -MF $(DEPDIR)/vectors_rel-vectors_init.Tpo -c -o vectors_rel-vectors_init.o `test -f '../../powerpc/shared/vectors/vectors_init.c' || echo '$(srcdir)/'`../../powerpc/shared/vectors/vectors_init.c
>> @am__fastdepCC_TRUE@	mv -f $(DEPDIR)/vectors_rel-vectors_init.Tpo $(DEPDIR)/vectors_rel-vectors_init.Po
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../powerpc/shared/vectors/vectors_init.c' object='vectors_rel-vectors_init.o' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(vectors_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o vectors_rel-vectors_init.o `test -f '../../powerpc/shared/vectors/vectors_init.c' || echo '$(srcdir)/'`../../powerpc/shared/vectors/vectors_init.c
>> vectors_rel-vectors_init.obj: ../../powerpc/shared/vectors/vectors_init.c
>> @am__fastdepCC_TRUE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(vectors_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -MT vectors_rel-vectors_init.obj -MD -MP -MF $(DEPDIR)/vectors_rel-vectors_init.Tpo -c -o vectors_rel-vectors_init.obj `if test -f '../../powerpc/shared/vectors/vectors_init.c'; then $(CYGPATH_W) '../../powerpc/shared/vectors/vectors_init.c'; else $(CYGPATH_W) '$(srcdir)/../../powerpc/shared/vectors/vectors_init.c'; fi`
>> @AMDEP_TRUE@@am__fastdepCC_FALSE@	source='../../powerpc/shared/vectors/vectors_init.c' object='vectors_rel-vectors_init.obj' libtool=no @AMDEPBACKSLASH@
>> @am__fastdepCC_FALSE@	$(CC) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) $(vectors_rel_CPPFLAGS) $(CPPFLAGS) $(AM_CFLAGS) $(CFLAGS) -c -o vectors_rel-vectors_init.obj `if test -f '../../powerpc/shared/vectors/vectors_init.c'; then $(CYGPATH_W) '../../powerpc/shared/vectors/vectors_init.c'; else $(CYGPATH_W) '$(srcdir)/../../powerpc/shared/vectors/vectors_init.c'; fi`
>> install-dist_project_libDATA: $(dist_project_lib_DATA)
>> 	@$(NORMAL_INSTALL)
>> 	test -z "$(project_libdir)" || $(MKDIR_P) "$(DESTDIR)$(project_libdir)"
>> 	@list='$(dist_project_lib_DATA)'; for p in $$list; do \
>> 	  if test -f "$$p"; then d=; else d="$(srcdir)/"; fi; \
>> 	  f=$(am__strip_dir) \
>> 	  echo " $(dist_project_libDATA_INSTALL) '$$d$$p' '$(DESTDIR)$(project_libdir)/$$f'"; \
>> 	  $(dist_project_libDATA_INSTALL) "$$d$$p" "$(DESTDIR)$(project_libdir)/$$f"; \
>> 	done
>> uninstall-dist_project_libDATA:
>> 	@$(NORMAL_UNINSTALL)
>> 	  echo " rm -f '$(DESTDIR)$(project_libdir)/$$f'"; \
>> 	  rm -f "$(DESTDIR)$(project_libdir)/$$f"; \
>> 	done
>> install-project_libDATA: $(project_lib_DATA)
>> 	@$(NORMAL_INSTALL)
>> 	@list='$(project_lib_DATA)'; for p in $$list; do \
>> 	  echo " $(project_libDATA_INSTALL) '$$d$$p' '$(DESTDIR)$(project_libdir)/$$f'"; \
>> 	  $(project_libDATA_INSTALL) "$$d$$p" "$(DESTDIR)$(project_libdir)/$$f"; \
>> 	done
>> uninstall-project_libDATA:
>> 	done
>> install-includeHEADERS: $(include_HEADERS)
>> 	@$(NORMAL_INSTALL)
>> 	test -z "$(includedir)" || $(MKDIR_P) "$(DESTDIR)$(includedir)"
>> 	@list='$(include_HEADERS)'; for p in $$list; do \
>> 	  echo " $(includeHEADERS_INSTALL) '$$d$$p' '$(DESTDIR)$(includedir)/$$f'"; \
>> 	  $(includeHEADERS_INSTALL) "$$d$$p" "$(DESTDIR)$(includedir)/$$f"; \
>> 	done
>> uninstall-includeHEADERS:
>> 	  echo " rm -f '$(DESTDIR)$(includedir)/$$f'"; \
>> 	  rm -f "$(DESTDIR)$(includedir)/$$f"; \
>> 	done
>> install-include_bspHEADERS: $(include_bsp_HEADERS)
>> 	@$(NORMAL_INSTALL)
>> 	test -z "$(include_bspdir)" || $(MKDIR_P) "$(DESTDIR)$(include_bspdir)"
>> 	@list='$(include_bsp_HEADERS)'; for p in $$list; do \
>> 	  echo " $(include_bspHEADERS_INSTALL) '$$d$$p' '$(DESTDIR)$(include_bspdir)/$$f'"; \
>> 	  $(include_bspHEADERS_INSTALL) "$$d$$p" "$(DESTDIR)$(include_bspdir)/$$f"; \
>> 	done
>> uninstall-include_bspHEADERS:
>> 	  echo " rm -f '$(DESTDIR)$(include_bspdir)/$$f'"; \
>> 	  rm -f "$(DESTDIR)$(include_bspdir)/$$f"; \
>> 	done
>> install-nodist_includeHEADERS: $(nodist_include_HEADERS)
>> 	@$(NORMAL_INSTALL)
>> 	@list='$(nodist_include_HEADERS)'; for p in $$list; do \
>> 	  echo " $(nodist_includeHEADERS_INSTALL) '$$d$$p' '$(DESTDIR)$(includedir)/$$f'"; \
>> 	  $(nodist_includeHEADERS_INSTALL) "$$d$$p" "$(DESTDIR)$(includedir)/$$f"; \
>> 	done
>> uninstall-nodist_includeHEADERS:
>> 	done
>> ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES)
>> 	list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \
>> 	unique=`for i in $$list; do \
>> 	    if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \
>> 	  done | \
>> 	  $(AWK) '    { files[$$0] = 1; } \
>> 	       END { for (i in files) print i; }'`; \
>> 	mkid -fID $$unique
>> tags: TAGS
>> TAGS:  $(HEADERS) $(SOURCES)  $(TAGS_DEPENDENCIES) \
>> 		$(TAGS_FILES) $(LISP)
>> 	tags=; \
>> 	here=`pwd`; \
>> 	  done | \
>> 	if test -z "$(ETAGS_ARGS)$$tags$$unique"; then :; else \
>> 	  test -n "$$unique" || unique=$$empty_fix; \
>> 	  $(ETAGS) $(ETAGSFLAGS) $(AM_ETAGSFLAGS) $(ETAGS_ARGS) \
>> 	    $$tags $$unique; \
>> 	fi
>> ctags: CTAGS
>> CTAGS:  $(HEADERS) $(SOURCES)  $(TAGS_DEPENDENCIES) \
>> 	tags=; \
>> 	here=`pwd`; \
>> 	  done | \
>> 	test -z "$(CTAGS_ARGS)$$tags$$unique" \
>> 	  || $(CTAGS) $(CTAGSFLAGS) $(AM_CTAGSFLAGS) $(CTAGS_ARGS) \
>> 	     $$tags $$unique
>> GTAGS:
>> 	here=`$(am__cd) $(top_builddir) && pwd` \
>> 	  && cd $(top_srcdir) \
>> 	  && gtags -i $(GTAGS_ARGS) $$here
>> distclean-tags:
>> 	-rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
>> distdir: $(DISTFILES)
>> 	$(am__remove_distdir)
>> 	test -d $(distdir) || mkdir $(distdir)
>> 	@srcdirstrip=`echo "$(srcdir)" | sed 's/[].[^$$\\*]/\\\\&/g'`; \
>> 	topsrcdirstrip=`echo "$(top_srcdir)" | sed 's/[].[^$$\\*]/\\\\&/g'`; \
>> 	list='$(DISTFILES)'; \
>> 	  dist_files=`for file in $$list; do echo $$file; done | \
>> 	  sed -e "s|^$$srcdirstrip/||;t" \
>> 	      -e "s|^$$topsrcdirstrip/|$(top_builddir)/|;t"`; \
>> 	case $$dist_files in \
>> 	  */*) $(MKDIR_P) `echo "$$dist_files" | \
>> 			   sed '/\//!d;s|^|$(distdir)/|;s,/[^/]*$$,,' | \
>> 			   sort -u` ;; \
>> 	esac; \
>> 	for file in $$dist_files; do \
>> 	  if test -f $$file || test -d $$file; then d=.; else d=$(srcdir); fi; \
>> 	  if test -d $$d/$$file; then \
>> 	    dir=`echo "/$$file" | sed -e 's,/[^/]*$$,,'`; \
>> 	    if test -d $(srcdir)/$$file && test $$d != $(srcdir); then \
>> 	      cp -pR $(srcdir)/$$file $(distdir)$$dir || exit 1; \
>> 	    fi; \
>> 	    cp -pR $$d/$$file $(distdir)$$dir || exit 1; \
>> 	  else \
>> 	    test -f $(distdir)/$$file \
>> 	    || cp -p $$d/$$file $(distdir)/$$file \
>> 	    || exit 1; \
>> 	  fi; \
>> 	done
>> 	-find $(distdir) -type d ! -perm -777 -exec chmod a+rwx {} \; -o \
>> 	  ! -type d ! -perm -444 -links 1 -exec chmod a+r {} \; -o \
>> 	  ! -type d ! -perm -400 -exec chmod a+r {} \; -o \
>> 	  ! -type d ! -perm -444 -exec $(install_sh) -c -m a+r {} {} \; \
>> 	|| chmod -R a+r $(distdir)
>> dist-gzip: distdir
>> 	tardir=$(distdir) && $(am__tar) | GZIP=$(GZIP_ENV) gzip -c >$(distdir).tar.gz
>> dist-bzip2: distdir
>> 	tardir=$(distdir) && $(am__tar) | bzip2 -9 -c >$(distdir).tar.bz2
>> dist-tarZ: distdir
>> 	tardir=$(distdir) && $(am__tar) | compress -c >$(distdir).tar.Z
>> dist-shar: distdir
>> 	shar $(distdir) | GZIP=$(GZIP_ENV) gzip -c >$(distdir).shar.gz
>> dist-zip: distdir
>> 	-rm -f $(distdir).zip
>> 	zip -rq $(distdir).zip $(distdir)
>> dist dist-all: distdir
>> # This target untars the dist file and tries a VPATH configuration.  Then
>> # it guarantees that the distribution is self-contained by making another
>> # tarfile.
>> distcheck: dist
>> 	case '$(DIST_ARCHIVES)' in \
>> 	*.tar.gz*) \
>> 	  GZIP=$(GZIP_ENV) gunzip -c $(distdir).tar.gz | $(am__untar) ;;\
>> 	*.tar.bz2*) \
>> 	  bunzip2 -c $(distdir).tar.bz2 | $(am__untar) ;;\
>> 	*.tar.Z*) \
>> 	  uncompress -c $(distdir).tar.Z | $(am__untar) ;;\
>> 	*.shar.gz*) \
>> 	  GZIP=$(GZIP_ENV) gunzip -c $(distdir).shar.gz | unshar ;;\
>> 	*.zip*) \
>> 	  unzip $(distdir).zip ;;\
>> 	esac
>> 	chmod -R a-w $(distdir); chmod a+w $(distdir)
>> 	mkdir $(distdir)/_build
>> 	mkdir $(distdir)/_inst
>> 	chmod a-w $(distdir)
>> 	dc_install_base=`$(am__cd) $(distdir)/_inst && pwd | sed -e 's,^[^:\\/]:[\\/],/,'` \
>> 	  && dc_destdir="$${TMPDIR-/tmp}/am-dc-$$$$/" \
>> 	  && cd $(distdir)/_build \
>> 	  && ../configure --srcdir=.. --prefix="$$dc_install_base" \
>> 	    $(DISTCHECK_CONFIGURE_FLAGS) \
>> 	  && $(MAKE) $(AM_MAKEFLAGS) \
>> 	  && $(MAKE) $(AM_MAKEFLAGS) dvi \
>> 	  && $(MAKE) $(AM_MAKEFLAGS) check \
>> 	  && $(MAKE) $(AM_MAKEFLAGS) install \
>> 	  && $(MAKE) $(AM_MAKEFLAGS) installcheck \
>> 	  && $(MAKE) $(AM_MAKEFLAGS) uninstall \
>> 	  && $(MAKE) $(AM_MAKEFLAGS) distuninstallcheck_dir="$$dc_install_base" \
>> 	        distuninstallcheck \
>> 	  && chmod -R a-w "$$dc_install_base" \
>> 	       (cd ../.. && umask 077 && mkdir "$$dc_destdir") \
>> 	       && $(MAKE) $(AM_MAKEFLAGS) DESTDIR="$$dc_destdir" install \
>> 	       && $(MAKE) $(AM_MAKEFLAGS) DESTDIR="$$dc_destdir" uninstall \
>> 	       && $(MAKE) $(AM_MAKEFLAGS) DESTDIR="$$dc_destdir" \
>> 	            distuninstallcheck_dir="$$dc_destdir" distuninstallcheck; \
>> 	      } || { rm -rf "$$dc_destdir"; exit 1; }) \
>> 	  && rm -rf "$$dc_destdir" \
>> 	  && $(MAKE) $(AM_MAKEFLAGS) dist \
>> 	  && rm -rf $(DIST_ARCHIVES) \
>> 	  && $(MAKE) $(AM_MAKEFLAGS) distcleancheck
>> 	@(echo "$(distdir) archives ready for distribution: "; \
>> 	  list='$(DIST_ARCHIVES)'; for i in $$list; do echo $$i; done) | \
>> 	  sed -e 1h -e 1s/./=/g -e 1p -e 1x -e '$$p' -e '$$x'
>> distuninstallcheck:
>> 	@cd $(distuninstallcheck_dir) \
>> 	&& test `$(distuninstallcheck_listfiles) | wc -l` -le 1 \
>> 	   || { echo "ERROR: files left after uninstall:" ; \
>> 	        if test -n "$(DESTDIR)"; then \
>> 	          echo "  (check DESTDIR support)"; \
>> 	        fi ; \
>> 	        $(distuninstallcheck_listfiles) ; \
>> 	        exit 1; } >&2
>> distcleancheck: distclean
>> 	@if test '$(srcdir)' = . ; then \
>> 	  echo "ERROR: distcleancheck can only run from a VPATH build" ; \
>> 	  exit 1 ; \
>> 	fi
>> 	@test `$(distcleancheck_listfiles) | wc -l` -eq 0 \
>> 	  || { echo "ERROR: files left in build directory after distclean:" ; \
>> 	       $(distcleancheck_listfiles) ; \
>> 	       exit 1; } >&2
>> check-am: all-am
>> check: check-am
>> all-am: Makefile $(LIBRARIES) $(PROGRAMS) $(DATA) $(HEADERS)
>> installdirs:
>> 	for dir in "$(DESTDIR)$(project_libdir)" "$(DESTDIR)$(project_libdir)" "$(DESTDIR)$(includedir)" "$(DESTDIR)$(include_bspdir)" "$(DESTDIR)$(includedir)"; do \
>> 	  test -z "$$dir" || $(MKDIR_P) "$$dir"; \
>> 	done
>> install: install-am
>> install-exec: install-exec-am
>> install-data: install-data-am
>> uninstall: uninstall-am
>> install-am: all-am
>> 	@$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am
>> installcheck: installcheck-am
>> install-strip:
>> 	$(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \
>> 	  install_sh_PROGRAM="$(INSTALL_STRIP_PROGRAM)" INSTALL_STRIP_FLAG=-s \
>> 	  `test -z '$(STRIP)' || \
>> 	    echo "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'"` install
>> mostlyclean-generic:
>> clean-generic:
>> 	-test -z "$(CLEANFILES)" || rm -f $(CLEANFILES)
>> distclean-generic:
>> 	-test -z "$(CONFIG_CLEAN_FILES)" || rm -f $(CONFIG_CLEAN_FILES)
>> 	-test -z "$(DISTCLEANFILES)" || rm -f $(DISTCLEANFILES)
>> maintainer-clean-generic:
>> 	@echo "This command is intended for maintainers to use"
>> 	@echo "it deletes files that may require special tools to rebuild."
>> clean: clean-am
>> clean-am: clean-generic clean-noinstLIBRARIES clean-noinstPROGRAMS \
>> 	mostlyclean-am
>> distclean: distclean-am
>> 	-rm -f $(am__CONFIG_DISTCLEAN_FILES)
>> 	-rm -rf ./$(DEPDIR)
>> 	-rm -f Makefile
>> distclean-am: clean-am distclean-compile distclean-generic \
>> 	distclean-hdr distclean-tags
>> dvi: dvi-am
>> dvi-am:
>> html: html-am
>> info: info-am
>> info-am:
>> install-data-am: install-dist_project_libDATA install-includeHEADERS \
>> 	install-include_bspHEADERS install-nodist_includeHEADERS \
>> install-dvi: install-dvi-am
>> install-exec-am:
>> install-html: install-html-am
>> install-info: install-info-am
>> install-man:
>> install-pdf: install-pdf-am
>> install-ps: install-ps-am
>> installcheck-am:
>> maintainer-clean: maintainer-clean-am
>> 	-rm -rf $(top_srcdir)/autom4te.cache
>> 	-rm -rf ./$(DEPDIR)
>> 	-rm -f Makefile
>> maintainer-clean-am: distclean-am maintainer-clean-generic
>> mostlyclean: mostlyclean-am
>> mostlyclean-am: mostlyclean-compile mostlyclean-generic
>> pdf: pdf-am
>> pdf-am:
>> ps: ps-am
>> ps-am:
>> uninstall-am: uninstall-dist_project_libDATA uninstall-includeHEADERS \
>> 	uninstall-include_bspHEADERS uninstall-nodist_includeHEADERS \
>> .MAKE: install-am install-strip
>> .PHONY: CTAGS GTAGS all all-am am--refresh check check-am clean \
>> 	clean-generic clean-noinstLIBRARIES clean-noinstPROGRAMS ctags \
>> 	dist dist-all dist-bzip2 dist-gzip dist-shar dist-tarZ \
>> 	dist-zip distcheck distclean distclean-compile \
>> 	distclean-generic distclean-hdr distclean-tags distcleancheck \
>> 	distdir distuninstallcheck dvi dvi-am html html-am info \
>> 	info-am install install-am install-data install-data-am \
>> 	install-dist_project_libDATA install-dvi install-dvi-am \
>> 	install-exec install-exec-am install-html install-html-am \
>> 	install-includeHEADERS install-include_bspHEADERS install-info \
>> 	install-info-am install-man install-nodist_includeHEADERS \
>> 	install-pdf install-pdf-am install-project_libDATA install-ps \
>> 	install-ps-am install-strip installcheck installcheck-am \
>> 	installdirs maintainer-clean maintainer-clean-generic \
>> 	mostlyclean mostlyclean-compile mostlyclean-generic pdf pdf-am \
>> 	ps ps-am tags uninstall uninstall-am \
>> @AMPOLISH3_TRUE@$(srcdir)/preinstall.am: Makefile.am
>> @AMPOLISH3_TRUE@	$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
>> all-am: $(PREINSTALL_FILES)
>> $(PROJECT_LIB)/$(dirstamp):
>> 	@$(mkdir_p) $(PROJECT_LIB)
>> 	@: > $(PROJECT_LIB)/$(dirstamp)
>> $(PROJECT_INCLUDE)/$(dirstamp):
>> 	@$(mkdir_p) $(PROJECT_INCLUDE)
>> 	@: > $(PROJECT_INCLUDE)/$(dirstamp)
>> $(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
>> 	$(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
>> $(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
>> 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
>> $(PROJECT_INCLUDE)/bsp/opbintctrl.h: include/opbintctrl.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/opbintctrl.h
>> $(PROJECT_INCLUDE)/bsp/irq.h: irq/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
>> $(PROJECT_INCLUDE)/bsp/vectors.h: ../../powerpc/shared/vectors/vectors.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/vectors.h
>> $(PROJECT_INCLUDE)/xiltemac.h: network/xiltemac.h $(PROJECT_INCLUDE)/$(dirstamp)
>> 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/xiltemac.h
>> $(PROJECT_INCLUDE)/xparameters_dflt.h: include/xparameters_dflt.h $(PROJECT_INCLUDE)/$(dirstamp)
>> 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/xparameters_dflt.h
>> $(PROJECT_INCLUDE)/tm27.h: include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
>> 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
>> $(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h $(PROJECT_INCLUDE)/$(dirstamp)
>> 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
>> $(PROJECT_INCLUDE)/coverhd.h: include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
>> 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
>> $(PROJECT_INCLUDE)/bsp/$(dirstamp):
>> 	@$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
>> 	@: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> $(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
>> 	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
>> $(PROJECT_LIB)/linkcmds.dl: startup/linkcmds.dl $(PROJECT_LIB)/$(dirstamp)
>> 	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.dl
>> #RSG - Added for C++ support
>> $(PROJECT_LIB)/rtems_crti.$(OBJEXT): rtems_crti.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
>> 	$(INSTALL_DATA) $< $(PROJECT_LIB)/rtems_crti.$(OBJEXT)
>> preinstall-am: $(PREINSTALL_FILES)
>> preinstall: preinstall-am
>> .PHONY: preinstall preinstall-am
>> #RSG End
>> # Tell versions [3.59,3.63) of GNU make to not export all variables.
>> # Otherwise a system limit (for SysV at least) may be exceeded.
>> .NOEXPORT:
>> ## Automatically generated by ampolish3 - Do not edit
>> if AMPOLISH3
>> endif
>> PREINSTALL_DIRS =
>> DISTCLEANFILES += $(PREINSTALL_DIRS)
>> PREINSTALL_FILES =
>> PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
>> PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
>> PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/opbintctrl.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/vectors.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/xiltemac.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/xparameters_dflt.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
>> PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds
>> PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.dl
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
