Webserver Woes++ (coldfire mcf5235 + rtems-4.7.1 + GoAhead)
Ian Caddy ianc at goanna.iinet.net.au
Tue Jul 10 01:36:41 UTC 2007
Hi Christopher,
Do you have enough mbuf and mbuf cluster space allocated?
Can you provide your network configuration parameters
(rtems_bsdnet_config) for your system?
In our systems we allocate 512K for the mbuf_bytecount and 512K for the
mbuf_cluster_bytecount.
regards,
Ian Caddy
CWolfe at motioncontrol.org wrote:
> Hi All,
> 	Last week I had an issue with illegal characters ending up in the http responses from
> GoAhead. After changing some configuration options (thanks Alan), the server works, but
> with one small issue. After it has served about 10 pages or so(varies), It breaks and fails to
> serve anything else, though it acknowledges requests through the console. I assume this is
> related to/caused by buffers not being released by the driver?  What else might I look into for
> this one?
> Could a lack of file descriptors cause the problem?
> one of the variables i changed which seems to bear proportionality to the issue is
> CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS which was changed from 20 to 100,
> and this seems to be aproximately in proportion to how much was serveed before errors
> occurred (pages which would, in theory, cause btwn 5 and 10 files to be accessed).
> Thanks for the help,
> Christopher Wolfe
> Motion Control Systems, Inc.
> rtems-users mailing list
> rtems-users at rtems.com
Ian Caddy
Goanna Technologies Pty Ltd
+61 8 9221 1860
