Request Help with NFS Client Test
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Mon Jul 16 19:27:02 UTC 2007
Till Straumann wrote:
> How do you use qemu/PPC with RTEMS?
> What BSP do you use and how do you boot it?
I wish we could use qemu/ppc with RTEMS. :(
I recompiled for pc386 and used the regular old Fedora
qemu RPM binary.
qemu -M isapc -m 8 -boot a -fda /home/joel/qemu/pc386_fda \
   -hda fat:/home/joel/qemu/hd -serial stdio \
   -net nic,vlan=0,macaddr=00:80:7F:22:61:77,model=ne2k_isa \
   -net tap,vlan=0
/etc/qemu-ifup is:
#!/bin/sh
   TUN_DEV=$1
   TUN_HOST=10.0.2.2
/sbin/ifconfig $TUN_DEV $TUN_HOST
I am using the same old qemu specific networkconfig.h but I had
to switch the static IP to 10.0.2.5 to make it work.  As best I can
tell, 10.0.2.4 is used by a virtual SMB server now.  I have attached
this file.
I didn't have any luck getting the RTEMS application to use DHCP
inside of qemu.
I can ping, run the netdemo, run httpd and run nfsclient.  But nfsclient
doesn't successfully mount the remote filesystem.  It could easily
be a routing problem on qemu.
I appreciate the help.  Ralf is finishing up merging the NFS client and
I want to have a test of it in the network demos.
--joel
> T.
>>>> In order to make the information provided more useful
>>>> you should:
>>>> a) change your BSP so it produces a stack trace
>>>>     from the exception handler (try
>>>>     libcpu/powerpc/shared/src/stack.c: CPU_print_stack())
>>>> b) post your binary (elf file) along with the register
>>>>     and stack dump.
>>> Wouldn't it be easier to run my test and see if
>>> it works for you with the NFS mounts changed
>>> or is horribly broken?
>>> The back track shows it is a NULL jump in the
>>> network driver.
>>> 0x00053EA8--> 0x0004E080--> 0x0004E164--> 0x00000006--> 0x0004B5D8
>>> 0x0004C2E0--> 0x00069458--> 0x00098A24--> 0x0009899C
>>> 0x00053EA8--> CPU_print_stack
>>> 0x0004E080--> C_exception_handler
>>> 0x0004E164--> push_normalized_frame
>>> 0x00000006--> ?????
>>> 0x0004B5D8--> mpc5200_eth_mii_read
>>> 0x0004C2E0--> mpc5200_fec_txDaemon
>>> 0x00069458--> soconnsleep
>>> 0x00098A24--> _Thread_Handler
>>> 0x0009899C--> _Thread_Handler
>>> Thomas .. can you try this test on your hardware.  I
>>> will commit the NFS client test to the network demos
>>> and hopefully you can track it down.
>> Doesn't crash on qemu.  I can't mount a filesystem
>> on the host OS yet but I suspect that I need to
>> add a route.
>> Till could you try to get this working on qemu and
>> see what magic I am missing?  I have to be close.
>> Please.
>>>> That said -- looking at your source code it seems
>>>> that (at least on the 4.7 branch) using a NULL pointer
>>>> for the first argument to RTEMS 'mount' is illegal.
>>> I saw your comment (gripe?) in the README
>>> and fixed it Friday in CVS.  :)
>>>> You could also use the convenience wrapper 'nfsMount()'
>>>> which does a DNS lookup (non thread-safe gethostbyname!)
>>>> and creates a mount-point (not nested directories, though)
>>>> if necessary:
>>>> nfsMount("server","/export","/home")
>>>> both methods are explained in the rtemsNFS README.
>>> I was trying hard to follow that to create
>>> the example.
>>> I tried the nfsMount call and it didn't even change
>>> the behavior.  Maybe this is just tripping a bug in
>>> the NIC driver. <sigh>
>>> I am going to try this on another BSP and see what happens.
>>> --joel
>>>> HTH
>>>> T.
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
Type: text/x-chdr
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20070716/7ca0c84b/attachment.bin>
