Request Help with NFS Client Test
Till Straumann strauman at slac.stanford.edu
Mon Jul 16 20:22:46 UTC 2007
Your test program works fine under qemu (0.9.0)
netconfig.h:
  - use bootp
  - driver name "ne1"
  - driver attach rtems_ne_driver_attach
  - *** irqno  9 *** [qemu uses 9 not 5 !! ]
init.c:
mount(
   & dummy,
   & nfs_fs_ops,
   RTEMS_FILESYSTEM_READ_WRITE,
   "10.0.0.2:/remote",  /* use export applicable to you */
   "/home"
I created a iso CD image with grub 0.94 (booting over virtual
network with etherboot 5.4.3 also works) and I use
qemu -cdrom isoimg -net tap -net nic,model=ne2k_isa
/etc/qemu-ifup:
ifconfig tap0 10.0.0.2 netmask 255.255.255.0 up
/etc/dhcpd.conf (note that 'filename' is not applicable here;
we boot using grub. I used this filename for recent etherboot tests)
subnet 10.0.0.0 netmask 255.255.255.0 {
        option routers 10.0.0.2;
        next-server    10.0.0.2;
        option ntp-servers 10.0.0.2;
        option domain-name-servers 0.0.0.0;
        host qemu {
         hardware ethernet 52:54:00:12:34:56;
         fixed-address 10.0.0.15;
         filename "ssrlApps/i386-rtems/pc686/bin/rtems.exe";
         option uarg "HELLO=hello";
After setting up the NFS server to export to 10.0.0.15
and the dhcp server (after launching qemu which creates
the tap0 IF and configures it to 10.0.0.2) I boot
(grub) kernel (cd)/bin/nfsClientTest.exe
(grub) boot
Then the test boots and runs just fine. It lists
the NFS mount and terminates.
HTH
-- Till
Joel Sherrill wrote:
> Till Straumann wrote:
>> How do you use qemu/PPC with RTEMS?
>> What BSP do you use and how do you boot it?
> I wish we could use qemu/ppc with RTEMS. :(
> I recompiled for pc386 and used the regular old Fedora
> qemu RPM binary.
> qemu -M isapc -m 8 -boot a -fda /home/joel/qemu/pc386_fda \
>   -hda fat:/home/joel/qemu/hd -serial stdio \
>   -net nic,vlan=0,macaddr=00:80:7F:22:61:77,model=ne2k_isa \
>   -net tap,vlan=0
> /etc/qemu-ifup is:
> #!/bin/sh
>   TUN_DEV=$1
>   TUN_HOST=10.0.2.2
> /sbin/ifconfig $TUN_DEV $TUN_HOST
> I am using the same old qemu specific networkconfig.h but I had
> to switch the static IP to 10.0.2.5 to make it work.  As best I can
> tell, 10.0.2.4 is used by a virtual SMB server now.  I have attached
> this file.
> I didn't have any luck getting the RTEMS application to use DHCP
> inside of qemu.
> I can ping, run the netdemo, run httpd and run nfsclient.  But nfsclient
> doesn't successfully mount the remote filesystem.  It could easily
> be a routing problem on qemu.
> I appreciate the help.  Ralf is finishing up merging the NFS client and
> I want to have a test of it in the network demos.
> --joel
>> T.
>>>>> In order to make the information provided more useful
>>>>> you should:
>>>>> a) change your BSP so it produces a stack trace
>>>>>     from the exception handler (try
>>>>>     libcpu/powerpc/shared/src/stack.c: CPU_print_stack())
>>>>> b) post your binary (elf file) along with the register
>>>>>     and stack dump.
>>>> Wouldn't it be easier to run my test and see if
>>>> it works for you with the NFS mounts changed
>>>> or is horribly broken?
>>>> The back track shows it is a NULL jump in the
>>>> network driver.
>>>> 0x00053EA8--> 0x0004E080--> 0x0004E164--> 0x00000006--> 0x0004B5D8
>>>> 0x0004C2E0--> 0x00069458--> 0x00098A24--> 0x0009899C
>>>> 0x00053EA8--> CPU_print_stack
>>>> 0x0004E080--> C_exception_handler
>>>> 0x0004E164--> push_normalized_frame
>>>> 0x00000006--> ?????
>>>> 0x0004B5D8--> mpc5200_eth_mii_read
>>>> 0x0004C2E0--> mpc5200_fec_txDaemon
>>>> 0x00069458--> soconnsleep
>>>> 0x00098A24--> _Thread_Handler
>>>> 0x0009899C--> _Thread_Handler
>>>> Thomas .. can you try this test on your hardware.  I
>>>> will commit the NFS client test to the network demos
>>>> and hopefully you can track it down.
>>> Doesn't crash on qemu.  I can't mount a filesystem
>>> on the host OS yet but I suspect that I need to
>>> add a route.
>>> Till could you try to get this working on qemu and
>>> see what magic I am missing?  I have to be close.
>>> Please.
>>>>> That said -- looking at your source code it seems
>>>>> that (at least on the 4.7 branch) using a NULL pointer
>>>>> for the first argument to RTEMS 'mount' is illegal.
>>>> I saw your comment (gripe?) in the README
>>>> and fixed it Friday in CVS.  :)
>>>>> You could also use the convenience wrapper 'nfsMount()'
>>>>> which does a DNS lookup (non thread-safe gethostbyname!)
>>>>> and creates a mount-point (not nested directories, though)
>>>>> if necessary:
>>>>> nfsMount("server","/export","/home")
>>>>> both methods are explained in the rtemsNFS README.
>>>> I was trying hard to follow that to create
>>>> the example.
>>>> I tried the nfsMount call and it didn't even change
>>>> the behavior.  Maybe this is just tripping a bug in
>>>> the NIC driver. <sigh>
>>>> I am going to try this on another BSP and see what happens.
>>>> --joel
>>>>> HTH
>>>>> T.
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.com
>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>  * Network configuration
>  * EDIT THIS FILE TO REFLECT YOUR NETWORK CONFIGURATION     *
>  * BEFORE RUNNING ANY RTEMS PROGRAMS WHICH USE THE NETWORK! *
>  *  networkconfig.h,v 1.8 2001/08/31 18:11:43 joel Exp
> #ifndef _RTEMS_NETWORKCONFIG_H_
> #define _RTEMS_NETWORKCONFIG_H_
>  *  The following will normally be set by the BSP if it supports
>  *  a single network device driver.  In the event, it supports
>  *  multiple network device drivers, then the user's default
>  *  network device driver will have to be selected by a BSP
>  *  specific mechanism.
> #undef RTEMS_BSP_NETWORK_DRIVER_NAME
> #undef RTEMS_BSP_NETWORK_DRIVER_ATTACH
> #define RTEMS_BSP_NETWORK_DRIVER_NAME    "ne1"
> #define RTEMS_BSP_NETWORK_DRIVER_ATTACH  rtems_ne_driver_attach
> #ifndef RTEMS_BSP_NETWORK_DRIVER_NAME
> #warning "RTEMS_BSP_NETWORK_DRIVER_NAME is not defined"
> #define RTEMS_BSP_NETWORK_DRIVER_NAME "ne0"
> #endif
> #ifndef RTEMS_BSP_NETWORK_DRIVER_ATTACH
> #warning "RTEMS_BSP_NETWORK_DRIVER_ATTACH is not defined"
> #define RTEMS_BSP_NETWORK_DRIVER_ATTACH 0
> #endif
> #ifdef RTEMS_USE_BOOTP
> #undef RTEMS_USE_BOOTP
> #endif
> /* #define RTEMS_USE_BOOTP */
> #include <bsp.h>
>  * Define RTEMS_SET_ETHERNET_ADDRESS if you want to specify the
>  * Ethernet address here.  If RTEMS_SET_ETHERNET_ADDRESS is not
>  * defined the driver will choose an address.
> //#define RTEMS_SET_ETHERNET_ADDRESS
> #ifdef RTEMS_SET_ETHERNET_ADDRESS
> #undef RTEMS_SET_ETHERNET_ADDRESS
> #endif
> #if (defined (RTEMS_SET_ETHERNET_ADDRESS))
> /* static char ethernet_address[6] = { 0x08, 0x00, 0x3e, 0x12, 0x28, 0xb1 }; */
> static char ethernet_address[6] = { 0x00, 0x80, 0x7F, 0x22, 0x61, 0x77 };
> #endif
> #ifdef RTEMS_USE_LOOPBACK
>  * Loopback interface
> extern void rtems_bsdnet_loopattach();
> static struct rtems_bsdnet_ifconfig loopback_config = {
> 	"lo0",				/* name */
> 	rtems_bsdnet_loopattach,	/* attach function */
> 	NULL,				/* link to next interface */
> 	"127.0.0.1",			/* IP address */
> 	"255.0.0.0",			/* IP net mask */
> #endif
>  * Default network interface
> static struct rtems_bsdnet_ifconfig netdriver_config = {
> 	RTEMS_BSP_NETWORK_DRIVER_NAME,		/* name */
> 	RTEMS_BSP_NETWORK_DRIVER_ATTACH,	/* attach function */
> 	&loopback_config,		/* link to next interface */
> #else
> 	NULL,				/* No more interfaces */
> #endif
> #if (defined (RTEMS_USE_BOOTP))
> 	NULL,				/* BOOTP supplies IP address */
> 	NULL,				/* BOOTP supplies IP net mask */
> #else
> 	"10.0.2.4",			/* IP address */
> 	"255.255.255.0",		/* IP net mask */
> #endif /* !RTEMS_USE_BOOTP */
> 	ethernet_address,               /* Ethernet hardware address */
> #else
> 	NULL,                           /* Driver supplies hardware address */
> #endif
> 	0,				/* Use default driver parameters */
> 	0, /* mtu */
> 	0, /* rbuf_count */
> 	0, /* xbuf_count */
> 	0, /* port */
> 	9 /* irq */
> struct rtems_bsdnet_config rtems_bsdnet_config = {
> 	&netdriver_config,
> 	rtems_bsdnet_do_bootp,
> #else
> 	NULL,
> #endif
> 	0,			/* Default network task priority */
> 	0,			/* Default mbuf capacity */
> 	0,			/* Default mbuf cluster capacity */
> #if (!defined (RTEMS_USE_BOOTP))
> 	"rtems",		/* Host name */
> 	"",		/* Domain name */
> 	"10.0.2.2",		/* Gateway */
> 	"10.0.0.1",		/* Log host */
> 	{"10.0.2.3" },	/* Name server(s) */
> 	{"" },	/* NTP server(s) */
> 	 *  A real example -- DO NOT USE THIS YOURSELF!!!
> #if 0
> 	"dy4",			/* Host name */
> 	"NOT_oarcorp.com",	/* Domain name */
> 	"192.168.1.2",   	/* Gateway */
> 	"192.168.1.2", 		/* Log host */
> 	{"192.168.1.2" },	/* Name server(s) */
> 	{"192.168.1.2" },	/* NTP server(s) */
> #endif
>  * For TFTP test application
> #define RTEMS_TFTP_TEST_HOST_NAME "BOOTP_HOST"
> #define RTEMS_TFTP_TEST_FILE_NAME "BOOTP_FILE"
> #else
> #define RTEMS_TFTP_TEST_HOST_NAME "XXX.YYY.ZZZ.XYZ"
> #define RTEMS_TFTP_TEST_FILE_NAME "tftptest"
> #endif
> #endif /* _RTEMS_NETWORKCONFIG_H_ */
