Request Help with NFS Client Test
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Wed Jul 18 08:59:01 UTC 2007
Joel,
I had a look into the possibly offending function
"mpc5200_eth_mii_read". There is a diagnostic "printf" included, which
is wrapped by a "ETH_DEBUG" condition. I think you have activated
"ETH_DEBUG", so maybe the printf kills your system?
I was busy to restore our server in the last days :-(
so I only found time to look into this today. For convenience, can you
send me your test application source code, so I can try it out on our
hardware.
wkr,
Thomas.
Till Straumann schrieb:
> Your test program works fine under qemu (0.9.0)
> netconfig.h:
>  - use bootp
>  - driver name "ne1"
>  - driver attach rtems_ne_driver_attach
>  - *** irqno  9 *** [qemu uses 9 not 5 !! ]
> init.c:
> mount(
>   & dummy,
>   & nfs_fs_ops,
>   RTEMS_FILESYSTEM_READ_WRITE,
>   "10.0.0.2:/remote",  /* use export applicable to you */
>   "/home"
> I created a iso CD image with grub 0.94 (booting over virtual
> network with etherboot 5.4.3 also works) and I use
> qemu -cdrom isoimg -net tap -net nic,model=ne2k_isa
> /etc/qemu-ifup:
> ifconfig tap0 10.0.0.2 netmask 255.255.255.0 up
> /etc/dhcpd.conf (note that 'filename' is not applicable here;
> we boot using grub. I used this filename for recent etherboot tests)
> subnet 10.0.0.0 netmask 255.255.255.0 {
>        option routers 10.0.0.2;
>        next-server    10.0.0.2;
>        option ntp-servers 10.0.0.2;
>        option domain-name-servers 0.0.0.0;
>        host qemu {
>         hardware ethernet 52:54:00:12:34:56;
>         fixed-address 10.0.0.15;
>         filename "ssrlApps/i386-rtems/pc686/bin/rtems.exe";
>         option uarg "HELLO=hello";
> After setting up the NFS server to export to 10.0.0.15
> and the dhcp server (after launching qemu which creates
> the tap0 IF and configures it to 10.0.0.2) I boot
> (grub) kernel (cd)/bin/nfsClientTest.exe
> (grub) boot
> Then the test boots and runs just fine. It lists
> the NFS mount and terminates.
> HTH
> -- Till
> Joel Sherrill wrote:
>> Till Straumann wrote:
>>> How do you use qemu/PPC with RTEMS?
>>> What BSP do you use and how do you boot it?
>> I wish we could use qemu/ppc with RTEMS. :(
>> I recompiled for pc386 and used the regular old Fedora
>> qemu RPM binary.
>> qemu -M isapc -m 8 -boot a -fda /home/joel/qemu/pc386_fda \
>>   -hda fat:/home/joel/qemu/hd -serial stdio \
>>   -net nic,vlan=0,macaddr=00:80:7F:22:61:77,model=ne2k_isa \
>>   -net tap,vlan=0
>> /etc/qemu-ifup is:
>> #!/bin/sh
>>   TUN_DEV=$1
>>   TUN_HOST=10.0.2.2
>> /sbin/ifconfig $TUN_DEV $TUN_HOST
>> I am using the same old qemu specific networkconfig.h but I had
>> to switch the static IP to 10.0.2.5 to make it work.  As best I can
>> tell, 10.0.2.4 is used by a virtual SMB server now.  I have attached
>> this file.
>> I didn't have any luck getting the RTEMS application to use DHCP
>> inside of qemu.
>> I can ping, run the netdemo, run httpd and run nfsclient.  But nfsclient
>> doesn't successfully mount the remote filesystem.  It could easily
>> be a routing problem on qemu.
>> I appreciate the help.  Ralf is finishing up merging the NFS client and
>> I want to have a test of it in the network demos.
>> --joel
>>> T.
>>>>>> In order to make the information provided more useful
>>>>>> you should:
>>>>>> a) change your BSP so it produces a stack trace
>>>>>>     from the exception handler (try
>>>>>>     libcpu/powerpc/shared/src/stack.c: CPU_print_stack())
>>>>>> b) post your binary (elf file) along with the register
>>>>>>     and stack dump.
>>>>> Wouldn't it be easier to run my test and see if
>>>>> it works for you with the NFS mounts changed
>>>>> or is horribly broken?
>>>>> The back track shows it is a NULL jump in the
>>>>> network driver.
>>>>> 0x00053EA8--> 0x0004E080--> 0x0004E164--> 0x00000006--> 0x0004B5D8
>>>>> 0x0004C2E0--> 0x00069458--> 0x00098A24--> 0x0009899C
>>>>> 0x00053EA8--> CPU_print_stack
>>>>> 0x0004E080--> C_exception_handler
>>>>> 0x0004E164--> push_normalized_frame
>>>>> 0x00000006--> ?????
>>>>> 0x0004B5D8--> mpc5200_eth_mii_read
>>>>> 0x0004C2E0--> mpc5200_fec_txDaemon
>>>>> 0x00069458--> soconnsleep
>>>>> 0x00098A24--> _Thread_Handler
>>>>> 0x0009899C--> _Thread_Handler
>>>>> Thomas .. can you try this test on your hardware.  I
>>>>> will commit the NFS client test to the network demos
>>>>> and hopefully you can track it down.
>>>> Doesn't crash on qemu.  I can't mount a filesystem
>>>> on the host OS yet but I suspect that I need to
>>>> add a route.
>>>> Till could you try to get this working on qemu and
>>>> see what magic I am missing?  I have to be close.
>>>> Please.
>>>>>> That said -- looking at your source code it seems
>>>>>> that (at least on the 4.7 branch) using a NULL pointer
>>>>>> for the first argument to RTEMS 'mount' is illegal.
>>>>> I saw your comment (gripe?) in the README
>>>>> and fixed it Friday in CVS.  :)
>>>>>> You could also use the convenience wrapper 'nfsMount()'
>>>>>> which does a DNS lookup (non thread-safe gethostbyname!)
>>>>>> and creates a mount-point (not nested directories, though)
>>>>>> if necessary:
>>>>>> nfsMount("server","/export","/home")
>>>>>> both methods are explained in the rtemsNFS README.
>>>>> I was trying hard to follow that to create
>>>>> the example.
>>>>> I tried the nfsMount call and it didn't even change
>>>>> the behavior.  Maybe this is just tripping a bug in
>>>>> the NIC driver. <sigh>
>>>>> I am going to try this on another BSP and see what happens.
>>>>> --joel
>>>>>> HTH
>>>>>> T.
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.com
>>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>  * Network configuration
>>  * EDIT THIS FILE TO REFLECT YOUR NETWORK CONFIGURATION     *
>>  * BEFORE RUNNING ANY RTEMS PROGRAMS WHICH USE THE NETWORK! *
>>  *  networkconfig.h,v 1.8 2001/08/31 18:11:43 joel Exp
>> #ifndef _RTEMS_NETWORKCONFIG_H_
>> #define _RTEMS_NETWORKCONFIG_H_
>>  *  The following will normally be set by the BSP if it supports
>>  *  a single network device driver.  In the event, it supports
>>  *  multiple network device drivers, then the user's default
>>  *  network device driver will have to be selected by a BSP
>>  *  specific mechanism.
>> #undef RTEMS_BSP_NETWORK_DRIVER_NAME
>> #undef RTEMS_BSP_NETWORK_DRIVER_ATTACH
>> #define RTEMS_BSP_NETWORK_DRIVER_NAME    "ne1"
>> #define RTEMS_BSP_NETWORK_DRIVER_ATTACH  rtems_ne_driver_attach
>> #ifndef RTEMS_BSP_NETWORK_DRIVER_NAME
>> #warning "RTEMS_BSP_NETWORK_DRIVER_NAME is not defined"
>> #define RTEMS_BSP_NETWORK_DRIVER_NAME "ne0"
>> #endif
>> #ifndef RTEMS_BSP_NETWORK_DRIVER_ATTACH
>> #warning "RTEMS_BSP_NETWORK_DRIVER_ATTACH is not defined"
>> #define RTEMS_BSP_NETWORK_DRIVER_ATTACH 0
>> #endif
>> #ifdef RTEMS_USE_BOOTP
>> #undef RTEMS_USE_BOOTP
>> #endif
>> /* #define RTEMS_USE_BOOTP */
>> #include <bsp.h>
>>  * Define RTEMS_SET_ETHERNET_ADDRESS if you want to specify the
>>  * Ethernet address here.  If RTEMS_SET_ETHERNET_ADDRESS is not
>>  * defined the driver will choose an address.
>> //#define RTEMS_SET_ETHERNET_ADDRESS
>> #ifdef RTEMS_SET_ETHERNET_ADDRESS
>> #undef RTEMS_SET_ETHERNET_ADDRESS
>> #endif
>> #if (defined (RTEMS_SET_ETHERNET_ADDRESS))
>> /* static char ethernet_address[6] = { 0x08, 0x00, 0x3e, 0x12, 0x28,
>> 0xb1 }; */
>> static char ethernet_address[6] = { 0x00, 0x80, 0x7F, 0x22, 0x61, 0x77 };
>> #endif
>> #ifdef RTEMS_USE_LOOPBACK /*
>>  * Loopback interface
>> extern void rtems_bsdnet_loopattach();
>> static struct rtems_bsdnet_ifconfig loopback_config = {
>>     "lo0",                /* name */
>>     rtems_bsdnet_loopattach,    /* attach function */
>>     NULL,                /* link to next interface */
>>     "127.0.0.1",            /* IP address */
>>     "255.0.0.0",            /* IP net mask */
>> #endif
>>  * Default network interface
>> static struct rtems_bsdnet_ifconfig netdriver_config = {
>>     RTEMS_BSP_NETWORK_DRIVER_NAME,        /* name */
>>     RTEMS_BSP_NETWORK_DRIVER_ATTACH,    /* attach function */
>> #ifdef RTEMS_USE_LOOPBACK     &loopback_config,        /* link to next
>> interface */
>> #else
>>     NULL,                /* No more interfaces */
>> #endif
>> #if (defined (RTEMS_USE_BOOTP))
>>     NULL,                /* BOOTP supplies IP address */
>>     NULL,                /* BOOTP supplies IP net mask */
>> #else
>>     "10.0.2.4",            /* IP address */
>>     "255.255.255.0",        /* IP net mask */
>> #endif /* !RTEMS_USE_BOOTP */
>>     ethernet_address,               /* Ethernet hardware address */
>> #else
>>     NULL,                           /* Driver supplies hardware
>> address */
>> #endif
>>     0,                /* Use default driver parameters */
>>     0, /* mtu */
>>     0, /* rbuf_count */
>>     0, /* xbuf_count */
>>     0, /* port */
>>     9 /* irq */
>> struct rtems_bsdnet_config rtems_bsdnet_config = {
>>     &netdriver_config,
>>     rtems_bsdnet_do_bootp,
>> #else
>>     NULL,
>> #endif
>>     0,            /* Default network task priority */
>>     0,            /* Default mbuf capacity */
>>     0,            /* Default mbuf cluster capacity */
>> #if (!defined (RTEMS_USE_BOOTP))
>>     "rtems",        /* Host name */
>>     "",        /* Domain name */
>>     "10.0.2.2",        /* Gateway */
>>     "10.0.0.1",        /* Log host */
>>     {"10.0.2.3" },    /* Name server(s) */
>>     {"" },    /* NTP server(s) */
>>      *  A real example -- DO NOT USE THIS YOURSELF!!!
>> #if 0
>>     "dy4",            /* Host name */
>>     "NOT_oarcorp.com",    /* Domain name */
>>     "192.168.1.2",       /* Gateway */
>>     "192.168.1.2",         /* Log host */
>>     {"192.168.1.2" },    /* Name server(s) */
>>     {"192.168.1.2" },    /* NTP server(s) */
>> #endif
>>  * For TFTP test application
>> #define RTEMS_TFTP_TEST_HOST_NAME "BOOTP_HOST"
>> #define RTEMS_TFTP_TEST_FILE_NAME "BOOTP_FILE"
>> #else
>> #define RTEMS_TFTP_TEST_HOST_NAME "XXX.YYY.ZZZ.XYZ"
>> #define RTEMS_TFTP_TEST_FILE_NAME "tftptest"
>> #endif
>> #endif /* _RTEMS_NETWORKCONFIG_H_ */
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
