Paranoia Results on PowerPC
Ralf Corsepius ralf.corsepius at rtems.org
Tue Jul 24 05:55:48 UTC 2007
On Mon, 2007-07-23 at 14:42 -0500, Joel Sherrill wrote:
> Hi,
> I have been running paranoia on psim and the gen5200
> BSP.  Both report the following as a minor flaw:;;;;
> Does anyone have a PowerPC system to compare against?  I
> am especially interested in results from a PowerPC Mac or
> UNIX based system.
Below are the results on a Fedora 7-ppc system (Once using -O0, once
using -O2)
$ gcc --version
gcc (GCC) 4.1.2 20070502 (Red Hat 4.1.2-12)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is
NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
Without having looked into details, they seem to confirm Eric's
observation.
BTW: Did you check gcc-4.2.1? I pushed new powerpc-rtems4.8-4.2.1 rpms
to "testing" in recent days.
Ralf
paranoia version 1.1 [cygnus]
Lest this program stop prematurely, i.e. before displaying
    `END OF TEST',
try to persuade the computer NOT to terminate execution when an
error like Over/Underflow or Division by Zero occurs, but rather
to persevere with a surrogate value after, perhaps, displaying some
warning.  If persuasion avails naught, don't despair but run this
program anyway to see how many milestones it passes, and then
amend it to make further progress.
Answer questions with Y, y, N or n (unless otherwise indicated).
To continue, press RETURN
Diagnosis resumes after milestone Number 0          Page: 1
Users are invited to help debug and augment this program so it will
cope with unanticipated and newly uncovered arithmetic pathologies.
Please send suggestions and interesting results to
	Richard Karpinski
	Computer Center U-76
	University of California
	San Francisco, CA 94143-0704, USA
In doing so, please include the following information:
	Precision:	double;
	Version:	10 February 1989;
	Computer:
	Compiler:
	Optimization level:
	Other relevant compiler options:
    `END OF TEST',
Diagnosis resumes after milestone Number 1          Page: 2
	Richard Karpinski
	Precision:	double;
	Computer:
	Compiler:
	Optimization level:
Diagnosis resumes after milestone Number 2          Page: 3
Running this program should reveal these characteristics:
     Radix = 1, 2, 4, 8, 10, 16, 100, 256 ...
     Precision = number of significant digits carried.
     U2 = Radix/Radix^Precision = One Ulp
	(OneUlpnit in the Last Place) of 1.000xxx .
     U1 = 1/Radix^Precision = One Ulp of numbers a little less than 1.0 .
     Adequacy of guard digits for Mult., Div. and Subt.
     Whether arithmetic is chopped, correctly rounded, or something else
	for Mult., Div., Add/Subt. and Sqrt.
     Whether a Sticky Bit used correctly for rounding.
     UnderflowThreshold = an underflow threshold.
     E0 and PseudoZero tell whether underflow is abrupt, gradual, or fuzzy.
     V = an overflow threshold, roughly.
     V0  tells, roughly, whether  Infinity  is represented.
     Comparisions are checked for consistency with subtraction
	and for contamination with pseudo-zeros.
     Sqrt is tested.  Y^X is not tested.
     Extra-precise subexpressions are revealed but NOT YET tested.
     Decimal-Binary conversion is NOT YET tested for accuracy.
Diagnosis resumes after milestone Number 3          Page: 4
The program attempts to discriminate among
   FLAWs, like lack of a sticky bit,
   Serious DEFECTs, like lack of a guard digit, and
   FAILUREs, like 2+2 == 5 .
Failures may confound subsequent diagnoses.
The diagnostic capabilities of this program go beyond an earlier
program called `MACHAR', which can be found at the end of the
book  `Software Manual for the Elementary Functions' (1980) by
W. J. Cody and W. Waite. Although both programs try to discover
the Radix, Precision and range (over/underflow thresholds)
of the arithmetic, this program tries to cope with a wider variety
of pathologies, and to say how well the arithmetic is implemented.
The program is based upon a conventional radix representation for
floating-point numbers, but also allows logarithmic encoding
as used by certain early WANG machines.
BASIC version of this program (C) 1983 by Prof. W. M. Kahan;
see source comments for more history.
Diagnosis resumes after milestone Number 4          Page: 5
Program is now RUNNING tests on small integers:
-1, 0, 1/2, 1, 2, 3, 4, 5, 9, 27, 32 & 240 are O.K.
Searching for Radix and Precision.
Radix = 2.000000 .
Closest relative separation found is U1 = 1.1102230e-16 .
Recalculating radix and precision
 confirms closest relative separation U1 .
Radix confirmed.
The number of significant digits of the Radix is 53.000000 .
Diagnosis resumes after milestone Number 30          Page: 6
Subtraction appears to be normalized, as it should be.
Checking for guard digit in *, /, and -.
     *, /, and - appear to have guard digits, as they should.
Diagnosis resumes after milestone Number 40          Page: 7
Checking rounding on multiply, divide and add/subtract.
Multiplication appears to round correctly.
Division appears to round correctly.
Addition/Subtraction appears to round correctly.
Checking for sticky bit.
Sticky bit apparently used correctly.
Does Multiplication commute?  Testing on 20 random pairs.
     No failures found in 20 integer pairs.
Running test of square root(x).
Testing if sqrt(X * X) == X for 20 Integers X.
Test for sqrt monotonicity.
sqrt has passed a test for Monotonicity.
Testing whether sqrt is rounded or chopped.
Square root appears to be correctly rounded.
Diagnosis resumes after milestone Number 90          Page: 8
Testing powers Z^i for small Integers Z and i.
... no discrepancies found.
Seeking Underflow thresholds UfThold and E0.
Smallest strictly positive number found is E0 = 4.94066e-324 .
Since comparison denies Z = 0, evaluating (Z + Z) / Z should be safe.
What the machine gets for (Z + Z) / Z is  2.00000000000000000e+00 .
This is O.K., provided Over/Underflow has NOT just been signaled.
Underflow is gradual; it incurs Absolute Error =
(roundoff in UfThold) < E0.
The Underflow threshold is 2.22507385850720188e-308,  below which
calculation may suffer larger Relative error than merely roundoff.
Since underflow occurs below the threshold
UfThold = (2.00000000000000000e+00) ^ (-1.02200000000000000e+03)
only underflow should afflict the expression
	(2.00000000000000000e+00) ^ (-2.04400000000000000e+03);
actually calculating yields: 0.00000000000000000e+00 .
This computed value is O.K.
Testing X^((X + 1) / (X - 1)) vs. exp(2) = 7.38905609893065218e+00 as X -> 1.
Accuracy seems adequate.
Testing powers Z^Q at four nearly extreme values.
Diagnosis resumes after milestone Number 160          Page: 9
Searching for Overflow threshold:
This may generate an error.
Can `Z = -Y' overflow?
Trying it on Y = -inf .
Seems O.K.
Overflow threshold is V  = 1.79769313486231571e+308 .
Overflow saturates at V0 = inf .
No Overflow should be signaled for V * 1 = 1.79769313486231571e+308
                           nor for V / 1 = 1.79769313486231571e+308 .
Any overflow signal separating this * from the one
above is a DEFECT.
Diagnosis resumes after milestone Number 190          Page: 10
What message and/or values does Division by Zero produce?
This can interupt your program.  You can skip this part if you wish.
Do you wish to compute 1 / 0?     Trying to compute 1 / 0 produces ...  inf .
Do you wish to compute 0 / 0?
    Trying to compute 0 / 0 produces ...  nan .
Diagnosis resumes after milestone Number 220          Page: 2030729482
No failures, defects nor flaws have been discovered.
The arithmetic diagnosed seems Satisfactory.
END OF TEST.
    `END OF TEST',
	Richard Karpinski
	Precision:	double;
	Computer:
	Compiler:
	Optimization level:
    `END OF TEST',
	Richard Karpinski
	Precision:	double;
	Computer:
	Compiler:
	Optimization level:
Radix = 2.000000 .
Radix confirmed.
* is neither chopped nor correctly rounded.
Sticky bit used incorrectly or not at all.
FLAW:  lack(s) of guard digits or failure(s) to correctly round or chop
(noted above) count as one flaw in the final tally below.
Seems O.K.
above is a DEFECT.
The number of  FLAWs  discovered =           1.
The arithmetic diagnosed seems Satisfactory though flawed.
END OF TEST.
