Gdb configuration and compilation
Thomas Doerfler (nt) Thomas.Doerfler at imd-systems.de
Thu Jul 26 18:02:27 UTC 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi,
the gdb configuration you are referring to is outdated. RPC based
debugging has been implemented years ago and unfortunately has not been
maintained.
Try the gdb agent implementation from Till Straumann instead, you may
want to search the rtems mailing list archive for references.
wkr,
Thomas.
Dr Chris Lee schrieb:
> Hi
> I am trying to remotely debug via ethernet. I am using rtems 4.7.1 on a
> i386 target. The gdb version is 6.5 with the rtems-20060713.diff patch
> applied
>>From what I have seen in the mailing list I should configure the gdb
> build with --target=i386-RTEMS which I do, but when I then perform "make
> all" it fails when checking the target system type because it does not
> recognise RTEMS and claims it is an invalid system configuration.
> Could some one give me a hint what I may be doing wrong.
> With best regards
> Chris Lee
> wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
>                     <000><
>      ><00>                                        <OOO><
>                                  ><00>
> Christopher Lee					Tel:  +49-6202-5756-25
> von Hoerner & Sulger GmbH			Fax:  +49-6202-5756-55
> Schlossplatz 8
> Schwetzingen					Email: lee at vh-s.de
> D-68723						Web:   www.vh-s.de
> Germany
> rtems-users mailing list
> rtems-users at rtems.com
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
     http://www.imd-systems.de/pgpkey_en.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.5 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFGqOGywHyg4bDtfjQRApkVAJ4uax4qKt7ktowOwFRAd0jmKqQvEgCgkHwV
ihVHfH1ZnQ8VEyVLNuVwGG0=
=XPAc
-----END PGP SIGNATURE-----
