rtems coverage testing through an open source simulator?
shizheng
neversetsun at ustc.edu
Mon Jul 2 13:57:10 UTC 2007
Ray wrote:
> You can use qemu to test pc586 bsp and score, Skyeye is also a good choice for ARM platform (csb337 for example).
> --enable-tests in configure will help you generate test Makefile. The testsuites (tmtest sptest) cover all/most the API rtems offered
as for this testsuit, I have checked and run it :)
I found $SRC_ROOT/testsuits/sptests/readme says:
This directory contains the RTEMS Single Processor Test Suite.
The tests in this directory provide near complete (98%+) test
coverage of the non-multiprocessor code in RTEMS.
I would like to know how 98%+ is obtained, and what's the 2%- left.
Is there any method to calculate this precisely?
regards, shizheng
