Webserver Woes with mcf5235 (BCC) and rtems 4.7.1
Ian Caddy ianc at goanna.iinet.net.au
Fri Jul 6 13:07:15 UTC 2007
Hi Christopher,
The fact that the checksums are wrong seems to be an indicator that it
might be a caching problem.  Do you have write caching turned on?
I think from memory, you are using a Coldfire processor?
Would it be possible to turn off write caching and see if the problem
goes away?
I hope this helps.
regards,
Ian Caddy
CWolfe at motioncontrol.org wrote:
> Hi All, I recently fixed the network driver for the bsp, and would
> like to use the GoAhead webserver, but I have been having issues with
> serving pages. For some unknown reason, illegal characters are being
> injected into/showing up in the http responses. While I feel
> confident that It is a driver/configuration issue, I am not sure
> where to start. I have attempted changing buffer descriptor
> alignment, MTU size, mbuf and mbuf cluster sizes, Usecs per tick and
> some other random odds and ends. At one poijnt yesterday, for a few
> hours, the problem vanished mysteriously, and the webserver was
> running correctly, though such is not the case now. I have checked
> the contents of the files in flash, and they are correct, so the
> erors are definitely being produced by the network driver/stack, but
> i don't know why. From ethereal, I have noticed that the checksums
> are bad in all of the packets sent out from the board, but I don't
> know how much that helps or not. I would appreciate any advice anyone
> could give. Best Regards, Christopher Wolfe
> _______________________________________________ rtems-users mailing
> list rtems-users at rtems.com
