RTEMS C++ Issues
Robert S. Grimes
rsg at alum.mit.edu
Tue Jul 10 00:47:56 UTC 2007
Ian Caddy wrote:
> Hi Bob,
> I realise I am coming a bit late into this conversation, which I have
> been loosely following, but...
Better late than never - thanks!
> Have you checked the section on C++ on the wiki:
Yes, and while I understand it in principle, the problem I'm having is
reproducing it in practice, especially wrt the automake/autoconf tools.
> We had to get C++ working for our applications people, and these
> applications run under RTEMS but are not directly linked with RTEMS,
> but linked independantly using the RTEMS compiler, then our main RTEMS
> system starts them up at startup.
> I also had problems with the global CTORS which also causes problems
> with exceptions, as these are lumped in with CTORS.
I haven't even begun to consider exceptions yet! ;-)
> Somewhere in your code (after kernel start, but before init) call a
> function that either the compiler/linker creates or your own one to
> init the CTOR function handlers.
This is what I understand is the process - again, it's the mechanics I'm
unsure of...
> In our case we wrote our own global CTOR init, as it was being run
> outside of RTEMS directly.
> I hope this helps.
While your approach is different from mine, I think the info you've
provided is useful in demonstrating it is not only feasible, but also
perhaps not quite as daunting as I first thought. To be honest, I've
been on vacation for 1.5 weeks, so I'm not exactly sure where I left off
in my quest, but I'll be resuming it tomorrow. While it seems I should
be able to cobble something together that would work for my apps, I'm
hoping to have it all incorporated into the Virtex PowerPC BSP - to make
it easier for others!
Thanks!
-Bob
> regards,
> Ian Caddy
