OT - Access to RTEMS CVS from behind firewall
Robert S. Grimes
rsg at alum.mit.edu
Tue Jul 10 19:32:12 UTC 2007
Hi Joel, Thomas,
Joel Sherrill wrote:
> Thomas Doerfler (nt) wrote:
> Robert,
> I did not use these tools (because I manage our firewall :-))))
Lucky you!
> but maybe you should use the follwoing URL instead?
> http://www.rtems.com/cgi-bin/viewcvs.cgi/
Still no joy.
> > I also noticed that the cvsget I just downloaded is 4 years old
> > and that the "checkout" string is "~checkout~" which doesn't
> > match the viewcvs.cgi code. There may be other issues.
On mine, the checkout string is *checkout*. What is it in the
viewcvs.cgi? Though I'm afraid there may be more problems lurking.
> > cvsgrab looks more current but I couldn't make heads or tails
> > of installing it in the little time I looked at it.
I can't get that to work either, and the Python error trace I never
mastered. But it seems that it can't find www.rtems.com _or_ my proxy host.
Not sure what to try next, but thanks for the help anyway!
-Bob
> > --joel
> wkr,
> Thomas.
> Robert S. Grimes schrieb:
> >>> Hi,
> >>> Sorry for the OT, but perhaps I need some information specific to the
> >>> RTEMS CVS setup. I'm behind a nasty firewall, and can't get to
> the CVS
> >>> repository. I've tried cvsgrab (no luck at all) and now cvsget.pl
> >>> (http://savannah.nongnu.org/projects/cvsget/), which seems to almost
> >>> work. But I get an error that suggests I'm not using the correct url
> >>> for it. The script shows an example like this:
> >>> perl -S cvsget.pl
> >>> --baseurl=http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/
> >>> --package=emacs
> >>> I try this:
> >>> perl -S cvsget.pl --baseurl=http://www.rtems.com/cgi-bin/viewcvs
> >>> --package=rtems
> >>> I get error like this:
> >>> Error updating "./cvs/rtems/index.html" from
> >>> "http://www.rtems.com/cgi-bin/viewcvs/rtems//"
> >>> Here's my suspicion - the script states the following in the usage
> >>> section about the baseurl parameter:
> >>> $baseurl must be the base URL for download link, NOT view link
> >>> I think I'm using the "view link" and not the "download link". I
> don't
> >>> know, though I certainly can guess, what these different "links" are,
> >>> but I'm guessing I need a different URL. Does anyone know what I
> should
> >>> use?
> >>> If I can get this to work, I'll update the wiki on how I did it for
> >>> other "firewall dwellers" to use...
> >>> Thanks
> >>> -Bob
> >>> _______________________________________________
> >>> rtems-users mailing list
> >>> rtems-users at rtems.com
> >>> http://rtems.rtems.org/mailman/listinfo/rtems-users
