OT - Access to RTEMS CVS from behind firewall -RESOLVED (tentatively)
Robert S. Grimes
rsg at alum.mit.edu
Thu Jul 12 21:34:52 UTC 2007
Joel Sherrill wrote:
> Can you provide a list of those 33?
Yes, here it is:
CVSGrab - -U rtems/make/custom/c3xsim.cfg
CVSGrab - -U rtems/make/custom/c4xsim.cfg
CVSGrab - -U rtems/cpukit/score/cpu/c4x/Makefile.am
CVSGrab - -U rtems/cpukit/score/cpu/c4x/cpu.c
CVSGrab - -U rtems/cpukit/score/cpu/c4x/cpu_asm.S
CVSGrab - -U rtems/cpukit/score/cpu/c4x/irq.c
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/Makefile.am
CVSGrab - -U rtems/cpukit/score/cpu/c4x/rtems/asm.h
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/Makefile.am
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/README
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/bsp_specs
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/shared/bspspuriousinit.c
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/shared/c3xspurious.c
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/shared/c4xspurious.c
CVSGrab - -U rtems/cpukit/score/cpu/c4x/rtems/score/c4x.h
CVSGrab - -U rtems/cpukit/score/cpu/c4x/rtems/score/cpu.h
CVSGrab - -U rtems/cpukit/score/cpu/c4x/rtems/score/cpu_asm.h
CVSGrab - -U rtems/cpukit/score/cpu/c4x/rtems/score/types.h
CVSGrab - -U rtems/cpukit/score/cpu/c4x/rtems/tic4x/c4xio.h
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/clock/clock.c
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/console/console.c
CVSGrab - -U
rtems/c/src/lib/libbsp/c4x/c4xsim/console/consolereserveresources.c
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/console/debugio.c
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/console/simio.c
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/include/bsp.h
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/include/simio.h
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/start/start.S
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/startup/bspstart.c
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/startup/linkcmds
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/startup/spurious.c
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/timer/timer.c
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/tools/Makefile.am
CVSGrab - -U rtems/c/src/lib/libbsp/c4x/c4xsim/tools/runtest.in
> Is the cvsweb page for each file browseable by hand?
Are you crazy? You want me to check 'em all? ;-)
Seriously, I checked a few, and they were marked "FILE REMOVED" by Ralf
seven months ago. I suspect you know, or can figure it out now. Turns
out you were very wise asking for the list, and I'm glad I did it!
> And a single random user isn't likely to look at those files.
Especially if they don't care about c4x, right?! :-P
Cheers,
-Bob
