Paranoia Results on PowerPC
Eric Norum
norume at aps.anl.gov
Mon Jul 23 20:04:59 UTC 2007
Looks like this may be a compiler issue (!)
With no optimizations I see no problems:
norume at ctlstrmvid0 215> gcc /usr/local/rtems/src/4.7.1/www.rtems.org/
ftp/pub/rtems/4.7.1/rtems-4.7.1/testsuites/samples/paranoia/paranoia.c
norume at ctlstrmvid0 216> yes | ./a.out
a.out version 1.1 [cygnus]
Lest this program stop prematurely, i.e. before displaying
`END OF TEST',
try to persuade the computer NOT to terminate execution when an
error like Over/Underflow or Division by Zero occurs, but rather
to persevere with a surrogate value after, perhaps, displaying some
warning. If persuasion avails naught, don't despair but run this
program anyway to see how many milestones it passes, and then
amend it to make further progress.
Answer questions with Y, y, N or n (unless otherwise indicated).
To continue, press RETURN
Diagnosis resumes after milestone Number 0 Page: 1
Users are invited to help debug and augment this program so it will
cope with unanticipated and newly uncovered arithmetic pathologies.
Please send suggestions and interesting results to
Richard Karpinski
Computer Center U-76
University of California
San Francisco, CA 94143-0704, USA
In doing so, please include the following information:
Precision: double;
Version: 10 February 1989;
Computer:
Compiler:
Optimization level:
Other relevant compiler options:
`END OF TEST',
Diagnosis resumes after milestone Number 1 Page: 2
Richard Karpinski
Precision: double;
Computer:
Compiler:
Optimization level:
Diagnosis resumes after milestone Number 2 Page: 3
Running this program should reveal these characteristics:
Radix = 1, 2, 4, 8, 10, 16, 100, 256 ...
Precision = number of significant digits carried.
U2 = Radix/Radix^Precision = One Ulp
(OneUlpnit in the Last Place) of 1.000xxx .
U1 = 1/Radix^Precision = One Ulp of numbers a little less than
1.0 .
Adequacy of guard digits for Mult., Div. and Subt.
Whether arithmetic is chopped, correctly rounded, or something
else
for Mult., Div., Add/Subt. and Sqrt.
Whether a Sticky Bit used correctly for rounding.
UnderflowThreshold = an underflow threshold.
E0 and PseudoZero tell whether underflow is abrupt, gradual, or
fuzzy.
V = an overflow threshold, roughly.
V0 tells, roughly, whether Infinity is represented.
Comparisions are checked for consistency with subtraction
and for contamination with pseudo-zeros.
Sqrt is tested. Y^X is not tested.
Extra-precise subexpressions are revealed but NOT YET tested.
Decimal-Binary conversion is NOT YET tested for accuracy.
Diagnosis resumes after milestone Number 3 Page: 4
The program attempts to discriminate among
FLAWs, like lack of a sticky bit,
Serious DEFECTs, like lack of a guard digit, and
FAILUREs, like 2+2 == 5 .
Failures may confound subsequent diagnoses.
The diagnostic capabilities of this program go beyond an earlier
program called `MACHAR', which can be found at the end of the
book `Software Manual for the Elementary Functions' (1980) by
W. J. Cody and W. Waite. Although both programs try to discover
the Radix, Precision and range (over/underflow thresholds)
of the arithmetic, this program tries to cope with a wider variety
of pathologies, and to say how well the arithmetic is implemented.
The program is based upon a conventional radix representation for
floating-point numbers, but also allows logarithmic encoding
as used by certain early WANG machines.
BASIC version of this program (C) 1983 by Prof. W. M. Kahan;
see source comments for more history.
Diagnosis resumes after milestone Number 4 Page: 5
Program is now RUNNING tests on small integers:
-1, 0, 1/2, 1, 2, 3, 4, 5, 9, 27, 32 & 240 are O.K.
Searching for Radix and Precision.
Radix = 2.000000 .
Closest relative separation found is U1 = 1.1102230e-16 .
Recalculating radix and precision
confirms closest relative separation U1 .
Radix confirmed.
The number of significant digits of the Radix is 53.000000 .
Diagnosis resumes after milestone Number 30 Page: 6
Subtraction appears to be normalized, as it should be.
Checking for guard digit in *, /, and -.
*, /, and - appear to have guard digits, as they should.
Diagnosis resumes after milestone Number 40 Page: 7
Checking rounding on multiply, divide and add/subtract.
Multiplication appears to round correctly.
Division appears to round correctly.
Addition/Subtraction appears to round correctly.
Checking for sticky bit.
Sticky bit apparently used correctly.
Does Multiplication commute? Testing on 20 random pairs.
No failures found in 20 integer pairs.
Running test of square root(x).
Testing if sqrt(X * X) == X for 20 Integers X.
Test for sqrt monotonicity.
sqrt has passed a test for Monotonicity.
Testing whether sqrt is rounded or chopped.
Square root appears to be correctly rounded.
Diagnosis resumes after milestone Number 90 Page: 8
Testing powers Z^i for small Integers Z and i.
... no discrepancies found.
Seeking Underflow thresholds UfThold and E0.
Smallest strictly positive number found is E0 = 4.94066e-324 .
Since comparison denies Z = 0, evaluating (Z + Z) / Z should be safe.
What the machine gets for (Z + Z) / Z is 2.00000000000000000e+00 .
This is O.K., provided Over/Underflow has NOT just been signaled.
Underflow is gradual; it incurs Absolute Error =
(roundoff in UfThold) < E0.
The Underflow threshold is 2.22507385850720188e-308, below which
calculation may suffer larger Relative error than merely roundoff.
Since underflow occurs below the threshold
UfThold = (2.00000000000000000e+00) ^ (-1.02200000000000000e+03)
only underflow should afflict the expression
(2.00000000000000000e+00) ^ (-2.04400000000000000e+03);
actually calculating yields: 0.00000000000000000e+00 .
This computed value is O.K.
Testing X^((X + 1) / (X - 1)) vs. exp(2) = 7.38905609893065218e+00 as
X -> 1.
Accuracy seems adequate.
Testing powers Z^Q at four nearly extreme values.
Diagnosis resumes after milestone Number 160 Page: 9
Searching for Overflow threshold:
This may generate an error.
Can `Z = -Y' overflow?
Trying it on Y = -inf .
Seems O.K.
Overflow threshold is V = 1.79769313486231571e+308 .
Overflow saturates at V0 = inf .
No Overflow should be signaled for V * 1 = 1.79769313486231571e+308
nor for V / 1 = 1.79769313486231571e+308 .
Any overflow signal separating this * from the one
above is a DEFECT.
Diagnosis resumes after milestone Number 190 Page: 10
What message and/or values does Division by Zero produce?
This can interupt your program. You can skip this part if you wish.
Do you wish to compute 1 / 0? Trying to compute 1 / 0
produces ... inf .
Do you wish to compute 0 / 0?
Trying to compute 0 / 0 produces ... nan .
Diagnosis resumes after milestone Number 220 Page: 11
No failures, defects nor flaws have been discovered.
Rounding appears to conform to the proposed IEEE standard P754.
The arithmetic diagnosed appears to be Excellent!
A total of 2030729482 floating point exceptions were registered.
END OF TEST.
norume at ctlstrmvid0 217>
However, with -O2 optimization (sic) I get the FLAW which you reported:
norume at ctlstrmvid0 206> gcc -O2 /usr/local/rtems/src/4.7.1/
www.rtems.org/ftp/pub/rtems/4.7.1/rtems-4.7.1/testsuites/samples/
paranoia/paranoia.c
norume at ctlstrmvid0 207> ./a.out
`END OF TEST',
Richard Karpinski
Precision: double;
Computer:
Compiler:
Optimization level:
`END OF TEST',
Richard Karpinski
Precision: double;
Computer:
Compiler:
Optimization level:
1.0 .
else
fuzzy.
Radix = 2.000000 .
Radix confirmed.
* is neither chopped nor correctly rounded.
Sticky bit used incorrectly or not at all.
FLAW: lack(s) of guard digits or failure(s) to correctly round or chop
(noted above) count as one flaw in the final tally below.
X -> 1.
Seems O.K.
above is a DEFECT.
O.K.
O.K.
The number of FLAWs discovered = 1.
The arithmetic diagnosed seems Satisfactory though flawed.
END OF TEST.
norume at ctlstrmvid0 208>
norume at ctlstrmvid0 208> uname -a
Darwin ctlstrmvid0.aps.anl.gov 8.9.0 Darwin Kernel Version 8.9.0: Thu
Feb 22 20:54:07 PST 2007; root:xnu-792.17.14~1/RELEASE_PPC Power
Macintosh powerpc RackMac1,2 Darwin
norume at ctlstrmvid0 209>
On Jul 23, 2007, at 2:42 PM, Joel Sherrill wrote:
> Hi,
> I have been running paranoia on psim and the gen5200
> BSP. Both report the following as a minor flaw:;;;;
> Addition/Subtraction neither rounds nor chops.
> TEST: lack(s) of guard digits or failure(s) to correctly round or chop
> ERROR: Severity: FLAW: lack(s) of guard digits or failure(s) to
> PASS: lack(s) of guard digits or failure(s) to correctly round or chop
> Is this as good at the PowerPC gets? Is it possible the
> FPSCR isn't initialized such that the results are better?
> I spotted one online result from a non-GCC compiler which
> had the same result on the PowerPC. So I am suspicious this
> is just the way it is.
> Does anyone have a PowerPC system to compare against? I
> am especially interested in results from a PowerPC Mac or
> UNIX based system.
> Thanks.
> --joel
> rtems-users mailing list
> rtems-users at rtems.com
Eric Norum <norume at aps.anl.gov>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
