How to Use Interrupts in Applications
Leon Pollak
leonp at plris.com
Wed Jul 25 14:39:54 UTC 2007
On Wednesday 25 July 2007 16:28, Robert S. Grimes wrote:
As everybody is silent, I shall say a few words till others will give more
wide answer.
The new excpetion processing works fine, the routine you found
(CPU_ISR_install...) I remember to be a dumb routine. I have no time now to
dig into the code (preparing a lot of PDR documentation :-)), but if you will
look into any PPC BSP (I used FADS on 860 and 8260 for my BSP as a proto) -
everything is there.
Sorry for been so short...
> > Okay, I'm confused. I'm not at all sure how the concepts of "old
> > exception model", "new exception model", and the RTEMS "Interrupt
> > Manager" are related.
> > One guess I have is that the first two are strictly BSP constructs, and
> > that the Interrupt Manager sits on top of whichever choice a BSP has
> > implemented. Is that correct?
> Well, I guess not, but maybe that is the intent? See below...
> > I'm using the PowerPC/Virtex BSP off the head, which uses the "new
> > exception model". I want to create a relatively simple ISR to handle a
> > peripheral that is custom to one of several processor boards that all
> > use the same BSP. So it seems wise to keep it out of the BSP, and
> > implement it in my application. So do I just use the "Interrupt
> > Manager", and let all the details pertaining to the interrupt controller
> > be handled by the BSP?
> Nope!
> > Is it as simple as this?
> > extern rtems_isr_entry myIsrFunc;
> > #define MY_INT_VECTOR 1
> > // Somewhere in my app init code
> > rtems_isr_entry oldIsrFunc;
> > rtems_interrupt_catch(myIsrFunc, MY_INT_VECTOR, &oldIsrFunc);
> Okay, no, it is not this simple. the rtems_interrupt_catch eventually
> gets to c/src/lib/libcpu/powerpc/new-exceptions/cpu.c, where it
> encounters this code:
> void _CPU_ISR_install_vector(<snip>)
> BSP_panic("_CPU_ISR_install_vector called\n");
> So it is clear to me that the "new exception" model hasn't been fully
> worked out (yet), at least not at the application level. It is safe to
> say that interrupt management is broken here, or the documentation is
> fully out of date.
> So what am I to do now? I'd be happy to help, but I have more unknowns
> right now about what the thinking was behind the switch from old to
> new. I found a discussion in the mailing list archives from a few years
> ago, but it wasn't complete enough to understand. I need this _now_,
> and will cobble something together if forced to (I'm sure the Ethernet
> driver example will help me), but it doesn't seem right to just solve my
> problem in an undocumented, quite possibly wrong-headed,, way, and not
> fix it more generally to help future users! I just need a bit of
> direction...
> Thanks,
> -Bob
> rtems-users mailing list
> rtems-users at rtems.com
Leon
