GameBoy Advance BSP
dave madden
dhm at mersenne.com
Thu Jul 26 00:05:32 UTC 2007
>>>>> "JS" == Joel Sherrill <joel.sherrill at oarcorp.com> writes:
JS> Is there anyone on the list who has used this?
JS> I would like to get setup here to run it and would appreciate
JS> some hints.
Hi Joel. I've compiled the BSP and run the test apps under the
VisualBoy emulator (and, IIRC, I loaded a couple onto a flash cart and
ran them on a real GBA) but I haven't done any RTEMS development. So,
if you're still at a pre-compile/test-environment stage and need help
getting further along, maybe I can be of some use. Otherwise, you'll
have to wait for somebody else to pipe up.
Regards,
d.
