GameBoy Advance BSP
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Jul 26 21:41:14 UTC 2007
Markku Puro wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all,
> Joel Sherrill wrote:
>> dave madden wrote:
>>>>>>>> "JS" == Joel Sherrill <joel.sherrill at oarcorp.com> writes:
>>> JS> Is there anyone on the list who has used this?
>>> JS> I would like to get setup here to run it and would appreciate
>>> JS> some hints.
>>> Hi Joel. I've compiled the BSP and run the test apps under the
>>> VisualBoy emulator (and, IIRC, I loaded a couple onto a flash cart and
>>> ran them on a real GBA) but I haven't done any RTEMS development. So,
>>> if you're still at a pre-compile/test-environment stage and need help
>>> getting further along, maybe I can be of some use. Otherwise, you'll
>>> have to wait for somebody else to pipe up.
>> I'm not looking to change the BSP, just make sure it works.
>> So it sounds like you can walk me through the process of
>> setting up the simulator and running it.
>> Once I get that working, I need to check if my kids haven't broken
>> or sold their GBA's now that most of them had DS's. If they have
>> one still, I will probably buy a cartridge programming system
>> and try that. It is just too neat to pass up.
>> So where do I get the simulator? If there are multiple ones, do
>> you know how to run it on them?
> Joel, didn't You check RTEMS wiki ;)
I did but the options were so many and I hoped someone
would tell me which simulator they actually used. :)
I am on Fedora 7.
VGBA did not run for me. It would not open a window.
Visual Gameboy Advance 1.7.1 ran OK but I couldn't find
a Linux version newer. It wouldn't exit when I clicked the
X on the terminal box though.
Those were the two simulator options listed. Is there
another someone has used?
> <http://www.rtems.com/wiki/index.php/ToolsForGameBoyAdvance>
> There is some links for emulators, simulators and debuggers etc.
> I just reform some links of gba page, I hope its better now.
> <http://www.rtems.com/wiki/index.php/Gba>
> If somebody knows nice tools, quides, flashlinkers etc
> please update to those gba wiki-pages.
Sounds like Steven has advice and should take a stab
at that. :)
Thanks for any advice. I just want to be able to spot
check this BSP more frequently.
> - -Mp
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.6 (MingW32)
> iQEVAwUBRqj3Dda56rpac4uCAQJg1ggAozcDyWVRkJApT9/HcBm2SIyDsQ0i8//4
> ZRcmz+Bl1Gd6e7XXo/bngy3YwwoDrXQG9D3TnWisY8m/JyGliR1iRjBQzjbHBYBe
> wTBkv165DRj+IwA/3D5rwlsg0CEeES4tH7wOtAm9Uol9yIlqTWXqWRccLmDyceor
> JEFfTNcU/Nh/qhdNb+vjoksqifQ/4gRKWQ+u07CIL61Iw6qlE8Zv9zSfjzuEmRVu
> fwYBn09C6xlFMIfWCs8LGf+LFk2hC2lrsShhs1exsyzv/o191rSypK8xyzvnzkjP
> 384VvbsR9x34PmJaRKaYDpejHmrhueWet1z65AwlGxojjVF00XGT2A==
> =784f
> -----END PGP SIGNATURE-----
