BSP of csb337 can works well with skyeye
xi yang
hiyangxi at gmail.com
Tue Jun 5 08:19:58 UTC 2007
---------- Forwarded message ----------
Date: 2007-6-5 下午4:18
Subject: BSP of csb337 can works well with skyeye
To: rtems-users at rtems.or
Cc: Joel Sherrill <joel.sherrill at oarcorp.com>
Today,i added dbgu function to skyeye ,so, csb337 works well.I also
added the polling style uart read function ,The patch of skyeye is in
Configures are
cpu: arm920t
mach: at91rm92
mem_bank: map=M, type=RW, addr=0x00000000, size=0x00004000
mem_bank: map=M, type=R, addr=0x00100000, size=0x00010000
mem_bank: map=M, type=RW, addr=0x00200000,size=0x00100000
mem_bank: map=M, type=RW, addr=0x20000000,size=0x00f00000
mem_bank: map=I, type=RW, addr=0xfffa0000, size=0x00060000
yangxi at debian:~/work/port_arm$
/home/yangxi/work/skyeye/skyeye_1_2_2_Rel/binary/skyeye -c skyeye.conf
-e hello.exe
arch: arm
cpu info: armv4, arm920t, 41009200, ff00fff0, 2
mach info: name at91rm92, mach_init addr 0x8066d00
uart_mod:0, desc_in:, desc_out:
SKYEYE: use arm920t mmu ops
exec file "hello.exe"'s format is elf32-little.
not load section .base: addr = 0x00200000 size = 0x00003800 .
load section .init: addr = 0x20100000 size = 0x0000001c.
load section .text: addr = 0x2010001c size = 0x000141d4.
load section .fini: addr = 0x201141f0 size = 0x00000018.
load section .data: addr = 0x20114208 size = 0x00000b70.
load section .eh_frame: addr = 0x20114d78 size = 0x00000004.
load section .rodata: addr = 0x20114d7c size = 0x00001094.
not load section .bss: addr = 0x20115e20 size = 0x0000a1e0 .
not load section .comment: addr = 0x00000000 size = 0x000011dc .
not load section .debug_aranges: addr = 0x00000000 size = 0x00001f40 .
not load section .debug_pubnames: addr = 0x00000000 size = 0x0000528a .
not load section .debug_info: addr = 0x00000000 size = 0x000f3834 .
not load section .debug_abbrev: addr = 0x00000000 size = 0x0001be5a .
not load section .debug_line: addr = 0x00000000 size = 0x00025de4 .
not load section .debug_frame: addr = 0x00000000 size = 0x00004934 .
not load section .debug_str: addr = 0x00000000 size = 0x0000dab7 .
not load section .debug_ranges: addr = 0x00000000 size = 0x00000ee0 .
start addr is set to 0x2010001c by exec file.
*** HELLO WORLD TEST ***
Hello World
*** END OF HELLO WORLD TEST ***
EXECUTIVE SHUTDOWN! Any key to reboot...
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20070605/fbde0719/attachment.obj>
