How can I remove file system
yanmiaobest
yanmiaobest at 163.com
Wed Jun 6 02:00:30 UTC 2007
Hi Jeol, You mean that I have to modify the source code, right? Is there some way that I can skip compiling the file system, or compile but don't link them into exe file through modifying makefile or linkcmd?
2007-06-05,"Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
yanmiaobest wrote: > Hi, > How can I remove file system out of my exe file? > Is there a way to disable it, like --disable-fs? > Or do I have to modify makefile ? This is still an open project. There are some brief notes on it at http://www.rtems.com/wiki/index.php/TinyRTEMS. There are at least two approaches -- one is to have no "section 2" IO support or filesystem. The other is to have a pluggable module that provides the 4.0.0 device name to major/minor mapping similar to what was in old RTEMS versions. You have to start by carving at the mount table and filesystem initialization routines. Having replacement stubs is a first step. --joel > > > ------------------------------------------------------------------------ > 百万 玩 家 同 玩 的 乐 园,人 气 爆 发 的 梦 幻 西 游 > <http://event.mail.163.com/chanel/xyq.htm?from=163_NO5> > ------------------------------------------------------------------------ > > _______________________________________________ > rtems-users mailing list > rtems-users at rtems.com > http://rtems.rtems.org/mailman/listinfo/rtems-users >
URL: <http://lists.rtems.org/pipermail/users/attachments/20070606/27146bce/attachment.html>
