Cannot find entry symbol _start
Feng Wang fengwang.emb at gmail.com
Sat Jun 9 05:18:16 UTC 2007
2007/6/8, Aleix Conchillo Flaqué <aconchillo at ieec.cat>:
> Hi,
> if you want to generate a raw application (without RTEMS) I explained
> it a while ago, you can find the whole thread here:
> http://www.rtems.com/ml/rtems-users/2006/january/msg00007.html
> If you want to build an RTEMS based application, the best way is to
> use the Makefiles provided by RTEMS and to have a look at some RTEMS
> examples.
Aleix, Thank you. My little program is based on RTEMS and works now.
Your explain for raw application makes me more clear.
Best Regards,
Feng Wang
