sparc-rtems4.7-gcc versus fpu
Kate Feng feng1 at bnl.gov
Tue Jun 12 14:25:07 UTC 2007
"Peter A. Krauss" wrote:
> Hello,
> I have downloaded sparc-rtems4.7 and would like to use it for a leon2
> target with fpu. I am puzzled on how the compiler inserts fpu
> instructions. My summary is:
> - The compiler does insert fpu instructions, if no fpu command line
> option is given or if "-mhard-quad-float" is used.
> - The compiler does not insert fpu instructions, if "-mfpu" or
> "-mhard-float" is used.
Usually I use -msoft-float if I do not wish to have fpu instruction
in some tasks.
Kate
> Why?
> Peter
> Dr. Peter A. Krauss, peter.a.krauss at astrium.eads.net
> EADS Astrium, Dept ASE231,     81663 Munich, Germany
> Tel: (+49) 89 / 607-21692, Fax: (+49) 89 / 607-35180
> ***** this e-mail can serve as information only ****
> This email (including any attachments) may contain confidential and/or privileged information or
> information otherwise protected from disclosure. If you are not the intended recipient, please notify the
> sender immediately, do not copy this message or any attachments and do not use it for any purpose
> or disclose its content to any person, but delete this message and any attachments from your system.
> Astrium disclaims any and all liability if this email transmission was virus corrupted, altered or falsified.
> Astrium GmbH
> Vorsitzender des Aufsichtsrates: Thomas S. Müller - Geschäftsführung: Evert Dudok (Vorsitzender), Dr. Reinhold Lutz, Pablo Salame Fischer
> Sitz der Gesellschaft: München - Registergericht: Amtsgericht München, HRB Nr. 107 647
> $ sparc-rtems-gcc -v
> Using built-in specs.
> Target: sparc-rtems4.7
> Configured with: ../gcc-4.1.1/configure --prefix=/opt/rtems-4.7 --bindir=/opt/rtems-4.7/bin --includedir=/opt/rtems-4.7/include --libdir=/opt/rtems-4.7/lib --libexecdir=/opt/rtems-4.7/lib --mandir=/opt/rtems-4.7/man --infodir=/opt/rtems-4.7/info --datadir=/opt/rtems-4.7/share --build=i686-suse-linux-gnu --host=i686-suse-linux-gnu --target=sparc-rtems4.7 --with-gnu-as --with-gnu-ld --verbose --with-newlib --with-system-zlib --disable-nls --without-included-gettext --disable-win32-registry --enable-version-specific-runtime-libs --enable-threads --enable-languages=c,c++
> Thread model: rtems
> gcc version 4.1.1 (RTEMS gcc-4.1.1/newlib-1.15.0-9.suse10.2)
> $ cat float.c
> float square(float x)
>   return x * x;
> $ sparc-rtems-gcc -mcpu=cypress -c float.c
> $ sparc-rtems-objdump -d float.o
> float.o:     file format elf32-sparc
> Disassembly of section .text:
> 00000000 <square>:
>    0:   9d e3 bf 98     save  %sp, -104, %sp
>    4:   f0 27 a0 44     st  %i0, [ %fp + 0x44 ]
>    8:   d3 07 a0 44     ld  [ %fp + 0x44 ], %f9
>    c:   d1 07 a0 44     ld  [ %fp + 0x44 ], %f8
>   10:   91 a2 49 28     fmuls  %f9, %f8, %f8
>   14:   81 a0 00 28     fmovs  %f8, %f0
>   18:   81 e8 00 00     restore
>   1c:   81 c3 e0 08     retl
>   20:   01 00 00 00     nop
> $ sparc-rtems-gcc -mcpu=cypress -mfpu -c float.c
> 00000000 <square>:
>    8:   d0 07 a0 44     ld  [ %fp + 0x44 ], %o0
>    c:   d2 07 a0 44     ld  [ %fp + 0x44 ], %o1
>   10:   40 00 00 00     call  10 <square+0x10>
>   14:   01 00 00 00     nop
>   18:   82 10 00 08     mov  %o0, %g1
>   1c:   b0 10 00 01     mov  %g1, %i0
>   20:   81 e8 00 00     restore
>   24:   81 c3 e0 08     retl
>   28:   01 00 00 00     nop
> $ sparc-rtems-gcc -mcpu=cypress -mhard-float -c float.c
> 00000000 <square>:
>   14:   01 00 00 00     nop
>   28:   01 00 00 00     nop
> $ sparc-rtems-gcc -mcpu=cypress -mhard-quad-float -c float.c
> 00000000 <square>:
>   20:   01 00 00 00     nop
> rtems-users mailing list
> rtems-users at rtems.com
