timer_create problem
Aitor.Viana.Sanchez at esa.int
Wed Jun 13 17:57:36 UTC 2007
Hi all,
i am having a look to the CANFestival v3.0 trying to port it to RTEMS. I
get the code already running over RTEMS but I have a problem with the
timer_create POSIX function.
The main.c source code gets inside the RTEMS configuration which includes:
#define CONFIGURE_MAXIMUM_TIMERS 10
/** RTEMS Configuration */
#define CONFIGURE_MAXIMUM_RTEMS_TIMERS CONFIGURE_MAXIMUM_TIMERS
/** POSIX Configuration */
#define CONFIGURE_MAXIMUM_POSIX_TIMERS CONFIGURE_MAXIMUM_TIMERS
When I try to create a timer calling the timer_create routine:
memset (&sigev, 0, sizeof (struct sigevent));
sigev.sigev_value.sival_int = 0;
sigev.sigev_notify = SIGEV_THREAD;
sigev.sigev_notify_attributes = NULL;
sigev.sigev_notify_function = timer_notify;
status = timer_create (CLOCK_REALTIME, &sigev, &timer);
if (status != 0)
MSG_ERR(errno, strerror(errno), status);
i got an error which is quite weird. I got the errno = 22 which is
"invalid argument", that means that the specified clockid (CLOCK_REALTIME)
is not defined. Nevertheless, i tried to call the function clock_gettime,
which also needs the clockid (CLOCK_REALTIME) as a parameter, and i got no
problem at all.
I am using RTEMS 4.6.5.
Do you have any idea that could help me to solve this problem ?
Cheers
Aitor Viana Sánchez
ESA - European Space Technology Centre (ESTEC)
TEC-EDD - Data Handling and Computing Section
ESA/ESTEC P.O. Box 299 / 2200AG Noordwijk ZH, The Netherlands
Tel (+31) 71 565 6727
Email: aitor.viana.sanchez at esa.int
URL: <http://lists.rtems.org/pipermail/users/attachments/20070613/c456a91a/attachment.html>
