ticker of csp337 works well
xi yang hiyangxi at gmail.com
Mon Jun 18 12:41:40 UTC 2007
2007/6/18, Ray <xr at trasin.net>:
> GOOD WORKS !
> Seems the at91rm9200 support is full functional in terms of samples. When will your codes get into skyeye's release?
> Btw, is there anyone test the network support£¿
May be i will submit it this sunday cause i have to prepare for my
final test of this semester.
Well,my next work is to get the network works well with skyeye.
> Thanks & Best Regards!
> Ray
> 2007-06-18
> From: xi yang
> Date: 2007-06-17 19:25:46
> To:   RTEMS Users; Skyeyee&lt, e h d8 g (i .d,6e h!(
> CC:   blackfin.kang at gmail.com
> Sub:  ticker of csp337 works well
> >>After i implemented the full features of AIC,then ticker works well.
> >*** CLOCK TICK TEST ***
> >TA1  - rtems_clock_get - 09:00:00   12/31/1988
> >TA2  - rtems_clock_get - 09:00:00   12/31/1988
> >TA3  - rtems_clock_get - 09:00:00   12/31/1988
> >TA1  - rtems_clock_get - 09:00:05   12/31/1988
> >TA2  - rtems_clock_get - 09:00:10   12/31/1988
> >TA1  - rtems_clock_get - 09:00:10   12/31/1988
> >TA3  - rtems_clock_get - 09:00:15   12/31/1988
> >TA1  - rtems_clock_get - 09:00:15   12/31/1988
> >TA2  - rtems_clock_get - 09:00:20   12/31/1988
> >TA1  - rtems_clock_get - 09:00:20   12/31/1988
> >TA1  - rtems_clock_get - 09:00:25   12/31/1988
> >TA3  - rtems_clock_get - 09:00:30   12/31/1988
> >TA2  - rtems_clock_get - 09:00:30   12/31/1988
> >TA1  - rtems_clock_get - 09:00:30   12/31/1988
> >*** END OF CLOCK TICK TEST ***
> >I will subbmit a patch for skyeye later.There is not any problem with
> >bsp of 337.
> >but just cause skyeye has not implemented the function of real
> >hardware completely.
> >In at91rm.h ,the macros has not been translated to unsigned number,and
> >for example #define AIC_SVR AT91RM92_AIC_BASE0+128 .I think it is dangerous.
> >_______________________________________________
> >rtems-users mailing list
> >rtems-users at rtems.com
> >http://rtems.rtems.org/mailman/listinfo/rtems-users
