CANOpen implementation over RTEMS
    Thomas Doerfler
    Thomas.Doerfler at embedded-brains.de
    Tue Jun 19 15:57:38 UTC 2007
Hi,
Wolfram Wadepohl schrieb:
> Joel Sherrill schrieb:
>> I noticed that you mention RTEMS does not have a standard device
>> driver model for CAN.  Do you or Thomas have a proposal for a standard
>> CAN device interface for RTEMS?
> spoken only for me and not for Thomas, there is no time left to do this
> before august.
We have currently implemented a CAN driver interface that is directly
related to the MSCAN capabilities implemented in the MPC5200. We did not
intend to set it as a standard for RTEMS CAN drivers. OTOH, when a
CANOpen implementation is desired, I am sure a proper interface should
be defined that allows the integration of most CAN controllers available.
wkr,
Thomas.
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
