non-FP tasks
Till Straumann strauman at slac.stanford.edu
Tue Jun 19 17:21:24 UTC 2007
Kate Feng wrote:
> Till Straumann wrote:
>> For a long time I have been patching newlib
>> so that it dynamically switches to vfiprintf
>> when executed by a non-FP task.
>> The patch also addresses setjmp/longjmp
>> (only saves/restores FP regs for FP tasks).
>> Finally, the patch also addresses altivec.
>> However: the patch addresses PPC only ATM.
>> HTH
>> -- Till
>> PS: originally created for newlib-1.13 but I
>> have used it on later versions, too.
> I used newlib-1.15.0 and gcc-4.1.1.
> In newlib/libc/machine/powerpc/configure :
>   case $host in
> +   powerpc*-*rtems*)
> +  extra_objs="vfprintf.o vfscanf.o"
> +  extra_sources="vfprintf.c vfscanf.c"
host seems correct.
> I am not sure about the '$host', which I thought should be
> '$target'.   However,
> it seems that the patch was built under the target of
> my system ( -mcpu=7450) at :
> gcc-4.1.1/build/ppc-rtems/m7400/newlib/libc/machine/powerpc/vfprintf.o
seems OK. Likewise, it should be built for other powerpc multitlib
variants.
> However, it does not seem to be built into the RTEMS image if it's
> linked with cexp, when I examined the object code.  Perhaps, was it
> overwitten by the library  of the cexp ?
>   Is a patch needed for
> cexp as well ?
no
> Or  something elase ?
Try to dump a link map and find out where the linked vfprintf.o comes from
HTH
-- Till
> Thanks,
> Kate
>> Kate Feng wrote:
>>> rtems_bsdnet_newproc() generated tasks are non-FP.  However,
>>> 1) The networkDaemon in cpukit/libnetworking/rtems calls
>>> 'sprintf' for arpint, which eventually will cause FP unavailable
>>> exception if network driver are built with -msoft-float.
>>> Suggestion ?
>>> 2) Network drivers use printk, rtems_panic, and printf,
>>> which are all currently compiled using the FP registers
>>> under all  4.6 and 4.7.  How about having printk compiled
>>> with -msoft-float since it could be called from ISR ?
>>> Can this be implemented in 4.7.x ?
>>> Regards,
>>> Kate
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>  Patch against newlib-1.13.0.
>>  This patch provides the following features:
>>  - let powerpc*-*rtems* targets use powerpc/altivec specific vfprintf/vfscanf implementations.
>>  - enable altivec printf/scanf formats even when not compiled -maltivec. I.e., non-altivec
>>    enabled tasks are guaranteed to not incur an 'altivec not available' exception while
>>    printing vectors from altivec-enabled tasks still works. (Vector data in memory can also
>>    be printed/scanned by non-vector tasks.)
>>  - vfprintf() dynamically switches to vfiprintf() when called from a non-FP task (so that
>>    an integer-only task doesn't implicitely use FP registers).
>>  - setjmp/longjmp save/restore FP and altivec registers only when called from an appropriate
>>    task context. (e.g., an integer-only, altivec-enabled task saves/restores only GPRs and VRs.)
>>  Author: Till Straumann <strauman at slac.stanford.edu>, 2005
>>  To apply this patch, chdir to the newlib-1.13.0 source topdir and issue
>>    patch -p1 < <this_file>
>>  Note that it is always a good idea to try a --dry-run first. YMMV
>> *** newlib-1.13.0/newlib/libc/machine/powerpc/configure.in.orig 2005-11-18 21:30:20.000000000 -0800
>> --- newlib-1.13.0/newlib/libc/machine/powerpc/configure.in      2005-11-18 22:04:32.000000000 -0800
>> *** 12,17 ****
>> --- 12,21 ----
>>   extra_objs=
>>   extra_sources=
>>   case $host in
>> +   powerpc*-*rtems*)
>>     powerpc*-*altivec*)
>>         extra_objs="vfprintf.o vfscanf.o vec_malloc.o vec_calloc.o vec_free.o vec_realloc.o vec_reallocr.o vec_callocr.o"
>>         extra_sources="vfprintf.c vfscanf.c vec_malloc.c vec_calloc.c vec_free.c vec_realloc.c vec_mallocr.c"
>> *** newlib-1.13.0/newlib/libc/machine/powerpc/configure.orig    2005-11-18 21:32:08.000000000 -0800
>> --- newlib-1.13.0/newlib/libc/machine/powerpc/configure 2005-11-18 22:04:43.000000000 -0800
>> *** 1568,1573 ****
>> --- 1568,1577 ----
>>   extra_objs=
>>   extra_sources=
>>   case $host in
>> +   powerpc*-*rtems*)
>>     powerpc*-*altivec*)
>> *** newlib-1.13.0/newlib/libc/machine/powerpc/setjmp.S.orig     2002-04-19 12:16:17.000000000 -0700
>> --- newlib-1.13.0/newlib/libc/machine/powerpc/setjmp.S  2005-11-18 20:53:39.000000000 -0800
>> *** 5,17 ****
>> --- 5,30 ----
>>   #include "ppc-asm.h"
>>   FUNC_START(setjmp)
>> + #ifdef __rtems__
>> +       mfmsr   4
>> +       rlwinm. 4,4,0,6,6       # check MSR_VE
>> +       addi    3,3,7
>> +       rlwinm  3,3,0,0,28  # align to 8 byte boundary
>> +       beq             1f
>> +     addi      3,3,15          # VE is enabled; align to 16 byte bdry
>> +       rlwinm  3,3,0,0,27
>> + 1:
>> + #else /* defined __rtems__ */
>>   #ifdef __ALTIVEC__
>> +       mfmsr   4
>>         addi    3,3,15          # align Altivec to 16 byte boundary
>>         rlwinm  3,3,0,0,27
>>   #else
>>         addi    3,3,7           # align to 8 byte boundary
>>         rlwinm  3,3,0,0,28
>>   #endif
>> + #endif /* defined __rtems__ */
>>         stw     1,0(3)          # offset 0
>>         stwu    2,4(3)          # offset 4
>>         stwu    13,4(3)         # offset 8
>> *** 39,44 ****
>> --- 52,65 ----
>>         stwu    4,4(3)          # offset 88
>>                                 # one word pad to get floating point aligned on 8 byte boundary
>>   #ifndef _SOFT_FLOAT
>> + #ifdef __rtems__
>> +       mfmsr   4
>> +       rlwinm. 4,4,0,18,18
>> +       bne             1f                      # only save FPregs if FPU is enabled
>> +       addi    3,3,18*8        # skip FPregs
>> +       b               2f
>> + 1:
>> + #endif
>>         stfdu   14,8(3)         # offset 96
>>         stfdu   15,8(3)         # offset 104
>>         stfdu   16,8(3)         # offset 112
>> *** 57,68 ****
>>         stfdu   29,8(3)         # offset 216
>>         stfdu   30,8(3)         # offset 224
>>         stfdu   31,8(3)         # offset 232
>>   #endif
>>         /* This requires a total of 21 * 4 + 18 * 8 + 4 + 4 + 4
>>            bytes == 60 * 4 bytes == 240 bytes.  */
>> ! #ifdef __ALTIVEC__
>>         /* save Altivec vrsave and vr20-vr31 registers */
>>         mfspr   4,256           # vrsave register
>>         stwu    4,16(3)         # offset 248
>> --- 78,101 ----
>> + #ifdef __rtems__
>> + 2:
>> + #endif
>>   #endif
>> ! #if defined(__ALTIVEC__) || defined(__rtems__)
>> ! #ifdef __rtems__
>> !       /* could reuse r4 but I reload it just in case the code changes... */
>> !       mfmsr   4
>> !       rlwinm. 4,4,0,6,6       # check MSR_VE
>> !       bne             1f                      # only save vector regs if altivec is enabled
>> !       addi    3,3,(8 + 12*16) # skip vector regs
>> !       b               2f
>> ! 1:
>> ! #endif
>> *** 90,95 ****
>> --- 123,131 ----
>>         stvx    30,0,3          # offset 416
>>         addi    3,3,16
>>         stvx    31,0,3          # offset 432
>> + #ifdef __rtems__
>> + 2:
>> + #endif
>>         /* This requires a total of 240 + 8 + 8 + 12 * 16 == 448 bytes. */
>>   #endif
>> *** 99,104 ****
>> --- 135,150 ----
>>   FUNC_START(longjmp)
>> + #ifdef __rtems__
>> +       mfmsr   4
>> +       addi    3,3,7
>> +       beq             1f
>> +       rlwinm  3,3,0,0,27
>> + 1:
>>   #ifdef __ALTIVEC__
>>         rlwinm  3,3,0,0,27
>> *** 106,111 ****
>> --- 152,158 ----
>>         rlwinm  3,3,0,0,28
>>   #endif
>>         lwz     1,0(3)          # offset 0
>>         lwzu    2,4(3)          # offset 4
>>         lwzu    13,4(3)         # offset 8
>> *** 129,138 ****
>>         lwzu    31,4(3)         # offset 80
>>         lwzu    5,4(3)          # offset 84
>>         mtlr    5
>>         lwzu    5,4(3)          # offset 88
>> -       mtcrf   255,5
>>   #ifndef _SOFT_FLOAT
>>         lfdu    14,8(3)         # offset 96
>>         lfdu    15,8(3)         # offset 104
>>         lfdu    16,8(3)         # offset 112
>> --- 176,194 ----
>>         mtlr    5
>> + #if !defined(_SOFT_FLOAT) && defined(__rtems__)
>> +       mfmsr   5
>> +       rlwinm. 5,5,0,18,18 # is MSR_FP set?
>> + #endif
>>   #ifndef _SOFT_FLOAT
>> + #ifdef __rtems__
>> +       bne             1f
>> +       b               2f
>> + 1:
>> + #endif
>> *** 151,159 ****
>>         lfdu    29,8(3)         # offset 216
>>         lfdu    30,8(3)         # offset 224
>>         lfdu    31,8(3)         # offset 232
>>   #endif
>>         /* restore Altivec vrsave and v20-v31 registers */
>>         lwzu    5,16(3)         # offset 248
>>         mtspr   256,5           # vrsave
>> --- 207,227 ----
>> + #ifdef __rtems__
>> + 2:
>> + #endif
>>   #endif
>> +       mtcrf   255,5
>> ! #ifdef __rtems__
>> !       mfmsr   5
>> !       rlwinm. 5,5,0,6,6       # is MSR_FP set?
>> !       bne             1f
>> !       addi    3,3,(8+12*16)   # skip vector regs
>> !       b               2f
>> ! 1:
>> ! #endif
>> *** 181,186 ****
>> --- 249,257 ----
>>         lvx     30,0,3          # offset 416
>>         addi    3,3,16
>>         lvx     31,0,3          # offset 432
>> + #ifdef __rtems__
>> + 2:
>> + #endif
>>   #endif
>>         mr.     3,4
>> *** newlib-1.13.0/newlib/libc/machine/powerpc/vfprintf.c.orig   2005-10-22 22:47:56.000000000 -0700
>> --- newlib-1.13.0/newlib/libc/machine/powerpc/vfprintf.c        2005-12-07 15:23:31.000000000 -0800
>> *** 191,199 ****
>>   #endif
>>   #ifdef __ALTIVEC__
>>   typedef union
>> !   vector int v;
>>     float f[4];
>>     int   i[16 / sizeof(int)];
>>     long  l[4];
>> --- 191,207 ----
>>   #endif
>>   #ifdef __ALTIVEC__
>> + typedef vector int vector_int;
>> + #elif defined(__rtems__)
>> + typedef int vector_int[4];
>> + #define __ALTIVEC__
>> + #endif
>> + #ifdef __ALTIVEC__
>>   typedef union
>> !   vector_int v;
>>     float f[4];
>>     long  l[4];
>> *** 315,320 ****
>> --- 323,329 ----
>>   #define VECTOR                0x200           /* vector */
>>   #define FIXEDPOINT    0x400           /* fixed-point */
>> + #ifdef VFPRINTF
>>   int
>>   _DEFUN (VFPRINTF, (fp, fmt0, ap),
>>         FILE * fp _AND
>> *** 324,336 ****
>> --- 333,369 ----
>>     CHECK_INIT (_REENT);
>>     return _VFPRINTF_R (_REENT, fp, fmt0, ap);
>> + #endif
>> + #if defined(__rtems__) && !defined(INTEGER_ONLY) && defined(FLOATING_POINT)
>> + static int
>> + _vfprintf_f_r (struct _reent *, FILE *, const char *, va_list)__attribute__((noinline));
>> + int
>> + _DEFUN (_VFPRINTF_R, (data, fp, fmt0, ap),
>> +       struct _reent *data _AND
>> +       FILE * fp _AND
>> +       _CONST char *fmt0 _AND
>> +       va_list ap)
>> + unsigned msr;
>> +       __asm__ __volatile__("mfmsr %0":"=r"(msr));
>> +       if  ( msr & (1<<(31-18)) )
>> +               return _vfprintf_f_r(data,fp,fmt0,ap);
>> +       return _vfiprintf_r(data, fp, fmt0, ap);
>> + static int
>> + _vfprintf_f_r (struct _reent *data, FILE *fp, const char *fmt0, va_list ap)
>> + #else
>>   int
>>         FILE * fp _AND
>>         va_list ap)
>> + #endif
>>         register char *fmt;     /* format string */
>>         register int ch;        /* character from fmt */
>> *** 435,470 ****
>>   #define GET_SHORT(ap) \
>>         (flags&VECTOR ? \
>>             (vec_print_count < 8 ? (short)vec_tmp.s[8 - vec_print_count] : \
>> !               (vec_tmp.v = va_arg(ap, vector int), (short)vec_tmp.s[0])) : \
>>             (short)va_arg(ap, int))
>>   #define GET_USHORT(ap) \
>>         (flags&VECTOR ? \
>>             (vec_print_count < 8 ? (u_short)vec_tmp.s[8 - vec_print_count] : \
>> !               (vec_tmp.v = va_arg(ap, vector int), (u_short)vec_tmp.s[0])) : \
>>             (u_short)va_arg(ap, int))
>>   #define GET_LONG(ap) \
>>         (flags&VECTOR ? \
>>             (vec_print_count < 4 ? (long)vec_tmp.l[4 - vec_print_count] : \
>> !               (vec_tmp.v = va_arg(ap, vector int), vec_tmp.l[0])) : \
>>             va_arg(ap, long int))
>>   #define GET_ULONG(ap) \
>>         (flags&VECTOR ? \
>>             (vec_print_count < 4 ? (u_long)vec_tmp.l[4 - vec_print_count] : \
>> !               (vec_tmp.v = va_arg(ap, vector int), (u_long)vec_tmp.l[0])) : \
>>             (u_long)va_arg(ap, unsigned long int))
>>   #define GET_INT(ap) \
>>         (flags&VECTOR ? \
>>             (vec_print_count < 16 ? \
>>                   vec_tmp.c[16 - vec_print_count] : \
>> !               (vec_tmp.v = va_arg(ap, vector int), (int)vec_tmp.c[0])) : \
>>             va_arg(ap, int))
>>   #define GET_UINT(ap) \
>>         (flags&VECTOR ? \
>>                   (u_int)((unsigned char)vec_tmp.c[16 - vec_print_count]) : \
>> !               (vec_tmp.v = va_arg(ap, vector int), (u_int)((unsigned char)vec_tmp.c[0]))) : \
>>             (u_int)va_arg(ap, unsigned int))
>>   #else /* !__ALTIVEC__ */
>>   #define GET_SHORT(ap) ((short)va_arg(ap, int))
>> --- 468,503 ----
>>         (flags&VECTOR ? \
>> !               (vec_tmp.v = va_arg(ap, vector_int), (short)vec_tmp.s[0])) : \
>>         (flags&VECTOR ? \
>> !               (vec_tmp.v = va_arg(ap, vector_int), (u_short)vec_tmp.s[0])) : \
>>         (flags&VECTOR ? \
>> !               (vec_tmp.v = va_arg(ap, vector_int), vec_tmp.l[0])) : \
>>         (flags&VECTOR ? \
>> !               (vec_tmp.v = va_arg(ap, vector_int), (u_long)vec_tmp.l[0])) : \
>>         (flags&VECTOR ? \
>> !               (vec_tmp.v = va_arg(ap, vector_int), (int)vec_tmp.c[0])) : \
>>             va_arg(ap, int))
>>         (flags&VECTOR ? \
>> !               (vec_tmp.v = va_arg(ap, vector_int), (u_int)((unsigned char)vec_tmp.c[0]))) : \
>> *** 716,722 ****
>>                                 fmt = format_anchor;
>>                                 continue;
>> !                           tmp.v = va_arg(ap, vector int);
>>                             cp = buf;
>>                             for (k = 0; k < 15; ++k)
>> --- 749,755 ----
>>                                 continue;
>> !                           tmp.v = va_arg(ap, vector_int);
>>                             cp = buf;
>> *** 783,789 ****
>>                                 if (vec_print_count >= 4)
>>                                       vec_print_count = 4;
>> !                                   vec_tmp.v = va_arg(ap, vector int);
>>                                 _fpvalue = (double)vec_tmp.f[4 - vec_print_count];
>>                         } else if (vec_sep != ' ') {
>> --- 816,822 ----
>> !                                   vec_tmp.v = va_arg(ap, vector_int);
>> *** 822,828 ****
>>                                 _fpvalue = (_LONG_DOUBLE)k.f[4 - vec_print_count];
>>   #endif /* __ALTIVEC__ */
>> --- 855,861 ----
>> *** newlib-1.13.0/newlib/libc/machine/powerpc/vfscanf.c.orig    2005-11-18 21:54:02.000000000 -0800
>> --- newlib-1.13.0/newlib/libc/machine/powerpc/vfscanf.c 2005-11-18 22:06:40.000000000 -0800
>> *** 249,254 ****
>> --- 249,257 ----
>>     return __svfscanf_r (data, fp, fmt, ap);
>> + #if defined(__rtems__) && defined(FLOATING_POINT)
>> + static int
>> + __svfscanf_f_r (struct _reent *, FILE *, char const *, va_list)__attribute__((noinline));
>>   int
>>   __svfscanf_r (rptr, fp, fmt0, ap)
>> *** 257,262 ****
>> --- 260,282 ----
>>        char _CONST *fmt0;
>>        va_list ap;
>> + unsigned msr;
>> + int      which;
>> +       return (msr & (1<<(31-18))) ? __svfscanf_f_r(rptr, fp, fmt0, ap) : __svfiscanf_r(rptr, fp, fmt0, ap) ;
>> + static int
>> + __svfscanf_f_r (struct _reent *rptr, FILE *fp, char const *fmt0, va_list ap)
>> + #else
>> + int
>> + __svfscanf_r (rptr, fp, fmt0, ap)
>> +      struct _reent *rptr;
>> +      register FILE *fp;
>> +      char _CONST *fmt0;
>> +      va_list ap;
>> + #endif
>>     register u_char *fmt = (u_char *) fmt0;
>>     register int c;             /* character from format, or conversion */
>>     register int type;          /* conversion type */
>> *** 397,403 ****
>>           if (flags & VECTOR)
>>             vec_read_count = 8;
>>           goto again;
>>         case 'v':
>>           flags |= VECTOR;
>>           vec_read_count = (flags & SHORT) ? 8 : ((flags & LONG) ? 4 : 16);
>> --- 417,423 ----
>>           if (flags & VECTOR)
>>             vec_read_count = 8;
>>           goto again;
>>         case 'v':
>>           flags |= VECTOR;
