(Fwd) Re: Problems initializing Network driver on MCF5235 Cold
CWolfe at motioncontrol.org CWolfe at motioncontrol.org
Wed Jun 20 19:48:59 UTC 2007
------- Forwarded message follows -------
CWolfe at motioncontrol.org wrote:
>>> On 20 Jun 2007 at 9:36, Joel Sherrill wrote:
>>>> I actually don't have a 5235 so I have cc'ed Chris Johns since
>>>> I think he is way more familiar with the Coldfire BSPs.
>>>> This type of question is usually best asked on the list.  There
>>>> are many people out there who and more eyes is good.
>>> what is the address to send to?
>> You have to be subscribed... see
>> http://www.rtems.org/wiki/index.php/RTEMSMailingLists
>> for instructions.
> Done. Should I move this conversation  to that address...????
Yeah.. it would give you more eyes.
>> If you spot something wrong in the Wiki, feel free
>> to create an account and fix it.
>>>> My usual first questions are:
>>>> + Can you run ticker?
ticker now tested and output is correct...
>>> haven't tried yet, will do so now.
>> If the clock tick interrupt isn't working, then
>> things aren't in good shape.
> since rtems tree was built without the testsuites, i am rebuilding with testsuites so i can build
> ticker sample...
>>>> + Can you run netdemo?
>>> no, same issue with crashing on driver init (after releasing semaphore)
>> Maybe you are dying in the interrupt handler.
>> Do you have some type of exception handler of debugger
>> that can point you to an address.  If not, do you have
>> an LED you could blink or some other bread crumb
>> you could post to note you entered the ISR.
> To my knowledge there is no dedicated LED on the board, but I could
> throw one on somewhere, I'm sure....
> My debugging SW loses the execution at that point.... because i don't have an address to tell
> it to go to, and whatever it is doing is jumping around a lot, The debugger is approximately
> useless. All the same, where should I be blinking the light from code-wise? My problem is
> that I don't see where the execution is going in the crack between the end of one function
> and the statement following the call thereunto....
It could be going to the IDLE task.  But my gut feeling is that the first
NIC interrupt is killing you.  Do you get an exception backtrace printed?
I get no output after it outputs the MAC addy.
Is Mike Bertosh still around?
He is the fellow who wrote the BSP originally
Unfortunately, he is not available...
mbertosh at motioncontrol.org
>>>> + Are you using RPMs or your own tool builds.
>>> using cygwin so....
>>> own build tools. versions and patches are as follows
>>> <excerpted from our in-house toolchain build script>......
>>> 	GCC=gcc-4.1.1
>>> 	BINUTILS=binutils-2.17
>>> 	NEWLIB=newlib-1.14.0
>>> 	BDM=m68k-bdm-1.3.0
>>> 	GDB=gdb-6.0
>>> 	INSIGHT=insight-6.0
>>> 	AUTOCONF=autoconf-2.61
>>> 	AUTOMAKE=automake-1.10
>>> i'm actually not sure which patches have been appplied as the script automatically
applies
>>> them. if necessary, i can dig into them and figure out which ones are actually applied, but
>>> assume they are the most recent...
>> Are you sure about newlib 1.14?  The 4.7 branch
>> should be built against 1.15.
> Yes, i am using 1.15. there was a typo in the file...
>> This isn't likely to be your problem but normally
>> RTEMS versions are carefully matched against
>> a specific newlib version and patch.
>>>>> Dear Joel,
>>>>> 	My name is Christopher Wolfe, and I am an Intern working for Motion Control
>>>>> Systems. Currently, I am working on an embedded management project with the
coldfire
>>>>> 5235BCC eval board. I am having trouble with getting the webserver up and running,
and I
>>>>> was wondering if you might know what I could do next to find the problem. I have
based my
>>>>> code off of the http example, but I have had to make a few minor modifications to
allow it to
>>>>> compile, as directories and whatnot are moved, etc. Anyway, when I upload the code
and run
>>>>> it, it crashes in the network driver initialization. I have traced the execution as far into
the
>>>>> code as I am able, but I lose track at specific point.
>>>>> execution makes it thru:
>>>>> http.c::init()
>>>>>  |--rtems_glue.c::rtems_bsdnet_initialize_network()
>>>>>     |--rtems_glue.c::rtems_bsdnet_initialize()
>>>>>     |    |--rtems_glue.c::bsd_init()
>>>>>     |        |--blah blah blah <makes it past all of this>
>>>>>     |--rtems_glue.c::rtems_bsdnet_attach(ifp)
>>>>>     |    |-- blah blah blah <makes it past all of this>
>>>>>     |--rtems_glue.c::rtems_bsdnet_setup()
>>>>>         |--rtems_bsdnet_ifconfig()
>>>>>             |---rtems_glue.c::rtems_bsdnet_semaphore_obtain()
>>>>>             |--blah blah blah <makes it past call to ioctl which I believe "UP"s the
interface...???>
>>>>>             |---rtems_glue.c::rtems_bsdnet_semaphore_release() <here it dies>
>>>>> as soon as the semaphore is released, i lose track of the execution of the code.
where it
>>>>> should return to rtems_bsdnet_ifconfig(), it is not. debugging printf statements were
placed
>>>>> as the very last statement inside the semaphore release code, and the first statement
in
>>>>> rtems_bsdnet_ifconfig() after the call to release the semaphore.
>>>>> of the the two statements which should be executed, only the first is executed.
afterwards,
>>>>> execution progresses into the rtems_bsdnet_semaphore_release's exit code.... never
to
>>>>> return to the calling function .... and hence it is lost and i can't trace it   with the tools i
have.....
>>>>> At this point in the initialization, what is going on? Are there other rtems processes
which are
>>>>> taking control? where does the execution go after releasing that semaphore? what
>>>>> configuration issues could cause this symptom set?<<<i assume this to be the
problem, but i
>>>>> just don't know enough about rtems yet>>>
>>>>> I include the configuration options/code i am using below.....
>>>>> <<changes to makefile>>
>>>>> 	LDFLAGS += -qnolinkcmds -T linkcmdsflash
>>>>> 	LD_LIBS   += -lhttpd -lftpd
>>>>> <<changes to init.c>>
>>>>> 	#include <rtems/confdefs.h>
>>>>> 	#include <rtems/ftpd.h>
>>>>>             << some printf()'s for debugging>>
>>>>> <<changes to system.h>>
>>>>> 	#include "tmacros"
>>>>>               (file was not in include directory, but I copied it from the testsuites build
directory)
>>>>> otherwise, everything is the same as the example source.
>>>>> I am using rtems 4.7.1. Thank you for your time, and I would greatly appreciate any
help you
>>>>> could give.
>>>>> 					Best Regards,
>>>>> 					Christopher Wolfe
>>>>> 					Motion Control Systems, Inc.
------- End of forwarded message -------
