makeinfo
Kirspel, Kevin
kevin.kirspel at optimedical.com
Fri Jun 22 13:40:37 UTC 2007
When compiling binutils-2.17 with patch file patch
binutils-2.17-rtems4.7-20061021.diff on my linux box I get the following
error:
Making info in doc
make[3]: Entering directory `/home/kirspelk/sandbox/b_bin/bfd/doc'
restore=: && backupdir=".am$$" && \
am__cwd=`pwd` && cd ../../../binutils-2.17/bfd/doc && \
rm -rf $backupdir && mkdir $backupdir && \
for f in ../../../binutils-2.17/bfd/doc/bfd.info
../../../binutils-2.17/bfd/doc/bfd.info-[0-9]
../../../binutils-2.17/bfd/doc/bfd.info-[0-9][0-9]
../../../binutils-2.17/bfd/doc/bfd.i[0-9]
../../../binutils-2.17/bfd/doc/bfd.i[0-9][0-9]; do \
if test -f $f; then mv $f $backupdir; restore=mv; else :; fi; \
done; \
cd "$am__cwd"; \
if /home/kirspelk/sandbox/binutils-2.17/missing makeinfo
--split-size=5000000 --split-size=5000000 -I
../../../binutils-2.17/bfd/doc \
-o ../../../binutils-2.17/bfd/doc/bfd.info
../../../binutils-2.17/bfd/doc/bfd.texinfo; \
then \
rc=0; \
cd ../../../binutils-2.17/bfd/doc; \
else \
rc=$?; \
$restore $backupdir/* `echo
"./../../../binutils-2.17/bfd/doc/bfd.info" | sed 's|[^/]*$||'`; \
fi; \
rm -rf $backupdir; exit $rc
WARNING: `makeinfo' is missing on your system. You should only need it if
you modified a `.texi' or `.texinfo' file, or any other file
indirectly affecting the aspect of the manual. The spurious
call might also be the consequence of using a buggy `make' (AIX,
DU, IRIX). You might want to install the `Texinfo' package or
the `GNU make' package. Grab either from any GNU archive site.
make[3]: *** [../../../binutils-2.17/bfd/doc/bfd.info] Error 1
make[3]: Leaving directory `/home/kirspelk/sandbox/b_bin/bfd/doc'
Making info in po
make[3]: Entering directory `/home/kirspelk/sandbox/b_bin/bfd/po'
make[3]: Nothing to be done for `info'.
make[3]: Leaving directory `/home/kirspelk/sandbox/b_bin/bfd/po'
make[3]: Entering directory `/home/kirspelk/sandbox/b_bin/bfd'
make[3]: Nothing to be done for `info-am'.
make[3]: Leaving directory `/home/kirspelk/sandbox/b_bin/bfd'
make[2]: *** [info-recursive] Error 1
make[2]: Leaving directory `/home/kirspelk/sandbox/b_bin/bfd'
make[1]: *** [all-bfd] Error 2
make[1]: Leaving directory `/home/kirspelk/sandbox/b_bin'
make: *** [all] Error 2
It says I don't have makeinfo on my system but when I type "makeinfo
-version" on the command line I the response below.
[kirspelk at localhost b_bin]$ makeinfo --version
makeinfo (GNU texinfo) 4.3
Copyright (C) 2002 Free Software Foundation, Inc.
There is NO warranty. You may redistribute this software
under the terms of the GNU General Public License.
For more information about these matters, see the files named COPYING.
[kirspelk at localhost b_bin]$ /usr/local/bin/makeinfo --version
[kirspelk at localhost b_bin]$ /usr/bin/makeinfo --version
Is there an issue with not being able to find makeinfo?
URL: <http://lists.rtems.org/pipermail/users/attachments/20070622/49dd3eb8/attachment.html>
