Patch for skyeye (BSP csb337)
xi yang hiyangxi at gmail.com
Sun Jun 24 17:12:19 UTC 2007
All:
Ticker of csb337 works well with skyeye now,patch is in attachment.
I will make network test works well with skyeye later.
yangxi at debian:~/work/port_arm$
/home/yangxi/work/skyeye/patch/skyeye_1_2_2_Rel_n/binary/skyeye -c
skyeye.conf -e /home/yangxi/build/build_rtems/arm-rtems/c/csb337/testsuites/samples/ticker/ticker.exe
arch: arm
cpu info: armv4, arm920t, 41009200, ff00fff0, 2
mach info: name at91rm92, mach_init addr 0x8066ff0
uart_mod:0, desc_in:, desc_out:
SKYEYE: use arm920t mmu ops
exec file "/home/yangxi/build/build_rtems/arm-rtems/c/csb337/testsuites/samples/ticker/ticker.exe"'s
format is elf32-little.
not load section .base: addr = 0x00200000  size = 0x00003800 .
load section .init: addr = 0x20100000  size = 0x0000001c.
load section .text: addr = 0x2010001c  size = 0x00012774.
load section .fini: addr = 0x20112790  size = 0x00000018.
load section .data: addr = 0x201127a8  size = 0x00000e24.
load section .eh_frame: addr = 0x201135cc  size = 0x00000004.
load section .rodata: addr = 0x201135d0  size = 0x00000b0c.
not load section .bss: addr = 0x201140e0  size = 0x0000bf20 .
not load section .comment: addr = 0x00000000  size = 0x00001320 .
not load section .debug_aranges: addr = 0x00000000  size = 0x00002000 .
not load section .debug_pubnames: addr = 0x00000000  size = 0x00004687 .
not load section .debug_info: addr = 0x00000000  size = 0x00107d91 .
not load section .debug_abbrev: addr = 0x00000000  size = 0x0001cfcf .
not load section .debug_line: addr = 0x00000000  size = 0x0002708f .
not load section .debug_frame: addr = 0x00000000  size = 0x00003f08 .
not load section .debug_str: addr = 0x00000000  size = 0x0000c544 .
not load section .debug_ranges: addr = 0x00000000  size = 0x00000ec0 .
start addr is set to 0x2010001c by exec file.
irq_num is 1
default_int_handler = 20100F2C
*** CLOCK TICK TEST ***
TA1  - rtems_clock_get - 09:00:00   12/31/1988
TA2  - rtems_clock_get - 09:00:00   12/31/1988
TA3  - rtems_clock_get - 09:00:00   12/31/1988
TA1  - rtems_clock_get - 09:00:05   12/31/1988
TA2  - rtems_clock_get - 09:00:10   12/31/1988
TA1  - rtems_clock_get - 09:00:10   12/31/1988
TA3  - rtems_clock_get - 09:00:15   12/31/1988
TA1  - rtems_clock_get - 09:00:15   12/31/1988
TA2  - rtems_clock_get - 09:00:20   12/31/1988
TA1  - rtems_clock_get - 09:00:20   12/31/1988
TA1  - rtems_clock_get - 09:00:25   12/31/1988
TA3  - rtems_clock_get - 09:00:30   12/31/1988
TA2  - rtems_clock_get - 09:00:30   12/31/1988
TA1  - rtems_clock_get - 09:00:30   12/31/1988
*** END OF CLOCK TICK TEST ***
EXECUTIVE SHUTDOWN! Any key to reboot...
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20070625/ddf6facd/attachment.obj>
