RTEMS HDD format options
jennifer at oarcorp.com jennifer at oarcorp.com
Tue Jun 26 11:22:47 UTC 2007
See the wiki page:
  http://www.rtems.com/wiki/index.php/What_is_RTEMS
for a listing of supported file-system formats.
Jennifer
> Dave Erickson wrote:
>> 	Joel/Whomever;
>> I'm a little unclear, (and I did check archives), what file formats are
>> acceptable for hard drive partitions to run RTEMS executables.  Can HDD
>> ext2/3 partitions run executables?  I notice the filesystems guide does
>> not elaborate.   Is there a list somewhere of acceptable formats?
> Yes. Ext2/3 partitions are supported. Basically if your bootloader
> supports it, you may start/boot RTEMS application from whatever
> partition format you like. The other question is what file-systems
> formats supports RTEMS natively to for example save its own data...
> Cheers,
> Karel
> Karel Gardas                  kgardas at objectsecurity.com
> ObjectSecurity Ltd.           http://www.objectsecurity.com
> rtems-users mailing list
> rtems-users at rtems.com
