Problems initializing Network driver on MCF5235 Coldfire
Wed Jun 27 14:09:51 UTC 2007
CWolfe at motioncontrol.org wrote:
> i don't have a handy way to do this directly. since I am using a parallel port that is not
> integrated with bios, I haven't been able to get cygwin/gdb/bdm to connect to the device
The BDM support directly accesses the hardware and does not access the BIOS.
You need to install the GiveIO driver for BDM to work. Do you have the GiveIO
driver installed ?
What sort of parallel port do you have ?
Regards
