RTEMS C++ Issues
Robert S. Grimes
rsg at alum.mit.edu
Wed Jun 27 15:23:24 UTC 2007
Ralf Corsepius wrote:
>> I have a problem with C++
> This issue has nothing to do with C++. It's a BSP issue.
Yes, of course - I should have said "I have a problem getting my BSP to
support C++", or something to that effect.
>> I think the answer is probably pretty simple, at least for you guys, but
>> it's clearly a bit out of reach for me...
> No. Without having seen your sources it's impossible to answer.
> Either your BSP's Makefile.am is broken or your bsp_spec is.
Yes, of course. I meant to include these files, but I got lost in
trying to describe the problem. Attached are the relevant files, and
sorry for the insufficient info the first go-around.
-Bob
> Ralf
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20070627/a79cf4d9/attachment.ksh>
URL: <http://lists.rtems.org/pipermail/users/attachments/20070627/a79cf4d9/attachment-0001.ksh>
URL: <http://lists.rtems.org/pipermail/users/attachments/20070627/a79cf4d9/attachment-0002.ksh>
URL: <http://lists.rtems.org/pipermail/users/attachments/20070627/a79cf4d9/attachment-0003.ksh>
