About --disable-cxx
Joel Sherrill
joel.sherrill at oarcorp.com
Tue Jun 5 14:21:31 UTC 2007
Fabricio de Novaes Kucinskis wrote:
> What exactly does --disable-cxx do?
> 1) Disable C++ support or
> 2) Disable just librtems++?
Just #2.
As I recall, the only other C++ support code in
RTEMS is the init/fini code which I guess could be
disabled by this but is not disabled at the current time.
[FWIW the "Ada self" support is not disabled
by --disable-ada either. That just gets the Ada95 binding.]
Beyond that, it is up to the BSP linkcmds/bsp_specs
to do the right thing for the C++ sections.
--joel
> Thanks,
> Fabricio.
> rtems-users mailing list
> rtems-users at rtems.com
