The problem with skyeye and csb337
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Jun 15 20:48:53 UTC 2007
xi yang wrote:
>> joel
>> Are you running hello or ticker?
> I am running ricker.
Then it doesn't make sense that you didn't get a break point
at that code. Try to break at Clock_initialize which is the
device driver initialization function for the clock.
Do you get to the Init task? Do you see 4 lines of output
and then TA1, TA2, and TA3 block and the idle task runs for
a while?
>> The code in
>> c/src/lib/libcpu/arm/at91rm9200/clock has this routine
>> static void clock_isr_on(const rtems_irq_connect_data *unused)
>> /* enable timer interrupt */
>> ST_REG(ST_IER) = ST_SR_PITS;
>> which should be invoked when the interrupt is connected
>> via a call to BSP_install_rtems_irq_handler in the irq directory
>> one level up.
> The problem is BSP_install_rtems_irq_handler with clock handler has
> not been
> invoked.
>> > 2ed.It seems that after disabled all the interrupt sources and
>> > install the
>> > default_int_handler() at all 32 interrupt source vector
>> > registers,rtems
>> > has not enabled the SYS interrupt source(number 1) of AIC
>> > and also has
>> > not installed the CLOCK interrupt handler(I guss rtems
>> > use interrupt
>> > managers to manage the interrupt of 32 lines.Because
>> > there are more
>> > than one devices use the same line,for example,system
>> > clock and DBGU
>> > use the same SYS interrupt source),but i can not find
>> > where is the SYS
>> > interrupt source manger,who can tell me?
>> The code for interrupt management on this CPU should be
>> in c/src/lib/libcpu/arm/at91m9200/irq. I don't see any
>> that is board specific reference in csb337/Makefile.am
>> > Since the interrupt of SYS is disable ,there is not any
>> > clock interupt can be
>> > delivered to CPU ,without the clock interrupt,the system
>> > is hang in idl
>> > task.
>> > So i enable the interrupt of clock and SYS interrupt
>> > source of AIC.Since
>> > default_int_handler() is still in all 32 interrupt source
>> > vector registers ,at
>> > every clock interrupt ,the system traps into
>> > default_int_handler();
>> > So,there are
>> > " raw_idt_notify has been called
>> > 1
>> > 2
>> > ..." on my screen.
>> > Q1,Where is the code installs SYS interrupt handler?
>> > Q2,Where is the code enables the interrupt of clock device and
>> AIC?
>> c/src/lib/libcpu/arm/at91rm9200/irq - look for
>> and look what it does when the interrupt is dynamically installed:
>> * store the new handler
>> AIC_SVR_REG(irq->name * 4) = (uint32_t) irq->hdl;
>> * unmask interrupt
>> AIC_CTL_REG(AIC_IECR) = 1 << irq->name;
>> * Enable interrupt on device
>> if(irq->on) {
>> irq->on(irq);
> Yeah,i know this,and problem is that rtems has not executed
> BSP_install_rtems_irq_handler for clock,i mean the clock interrupt
> handler is not
> installed.
> I think i can resolve it when i am more familar with code of rtems.The
> key
> is to detect why BSP_install_rtems_irq_handler has not been invoked.
>> i think that's all the code you are looking for. irq->on() goes back
>> to the
>> Clock driver "on" callback which I cut and pasted above.
>> > I think code of Q1 contains code of Q2,and some unkonw reasons
>> > result in
>> > system has not executed the code of Q1.
>> I don't know if I helped or not. Even though I maintain RTEMS, I
>> am not an expert on every CPU it supports. I have to struggle
>> through the manuals with the rest of you. :)
> Thank you very much.
> I will resolve it as soon as possible.
> regards.
>> --joel
