ticker of csp337 works well
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Jun 18 14:16:31 UTC 2007
xi yang wrote:
> 2007/6/18, Ray <xr at trasin.net>:
>> GOOD WORKS !
>> Seems the at91rm9200 support is full functional in terms of samples. When will your codes get into skyeye's release?
>> Btw, is there anyone test the network support£¿
> May be i will submit it this sunday cause i have to prepare for my
> final test of this semester.
> Well,my next work is to get the network works well with skyeye.
Wonderful!! Congratulations!!
While doing yardwork over the weekend, I was thinking of all
this activity and realized that there are probably 4 RTEMS test
executables that should be in Skyeye's test suite for each BSP.
+ hello.exe - no clock interrupt, basic OK it works
+ ticker.exe - hello with interrupts and a clock tick source
+ tm27.exe - benchmarks interrupt handling, uses an
interrupt source other than the clock tick
+ netdemo.exe - simple network application. It can be pinged
and telnet'ed to on two ports where it echos
characters.
There are other network tests but I doubt they prove anything
of interest as a test item for Skyeye. It the stack works at all
on Skyeye, services like DNS, NFS, etc should just work.
--joel
>> Thanks & Best Regards!
>> Ray
>> 2007-06-18
>> From: xi yang
>> Date: 2007-06-17 19:25:46
>> To: RTEMS Users; Skyeyee<, e h d8 g (i .d,6e h!(
>> CC: blackfin.kang at gmail.com
>> Sub: ticker of csp337 works well
>>>> After i implemented the full features of AIC,then ticker works well.
>>> *** CLOCK TICK TEST ***
>>> TA1 - rtems_clock_get - 09:00:00 12/31/1988
>>> TA2 - rtems_clock_get - 09:00:00 12/31/1988
>>> TA3 - rtems_clock_get - 09:00:00 12/31/1988
>>> TA1 - rtems_clock_get - 09:00:05 12/31/1988
>>> TA2 - rtems_clock_get - 09:00:10 12/31/1988
>>> TA1 - rtems_clock_get - 09:00:10 12/31/1988
>>> TA3 - rtems_clock_get - 09:00:15 12/31/1988
>>> TA1 - rtems_clock_get - 09:00:15 12/31/1988
>>> TA2 - rtems_clock_get - 09:00:20 12/31/1988
>>> TA1 - rtems_clock_get - 09:00:20 12/31/1988
>>> TA1 - rtems_clock_get - 09:00:25 12/31/1988
>>> TA3 - rtems_clock_get - 09:00:30 12/31/1988
>>> TA2 - rtems_clock_get - 09:00:30 12/31/1988
>>> TA1 - rtems_clock_get - 09:00:30 12/31/1988
>>> *** END OF CLOCK TICK TEST ***
>>> I will subbmit a patch for skyeye later.There is not any problem with
>>> bsp of 337.
>>> but just cause skyeye has not implemented the function of real
>>> hardware completely.
>>> In at91rm.h ,the macros has not been translated to unsigned number,and
>>> for example #define AIC_SVR AT91RM92_AIC_BASE0+128 .I think it is dangerous.
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
