C++ Usage Issues - Problems, Solutions, and Suggestions
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Jun 21 14:34:54 UTC 2007
So you don't have to page to the bottom..
+ I think the CONFIGURE_TEST_XXX uses should be
fixed now. Or at least confdefs.h will give an error that
they are obsolete. I got bit by this one on some code myself.
+ Please send a patch for everything you changed. I don't
care about the .c->.cc changes but the ones that improve
the correctness of the code are VERY important.
+ I obviously need to add the network demos to the automated
build sweep. When networking is configured, I should at least
compile all demos with the loopback driver configured.
--joel
Robert S. Grimes wrote:
> Hello,
> I'm using RTEMS to develop a three processor system, and I'd like to use
> C++ for my application development; not trying to get too fancy, but I
> do like some of the "better C" type features of C++. Anyway, I decided
> to see what needs to be changed to make a simple C application compile,
> link, and of course, run when built as a C++ application.
> <WARNING>This email is rather long and tedious, and does not represent a
> pressing problem. For those too busy, feel free to exit now. Or if you
> just want the summary, skip ahead to SUMMARY, as there are two
> conclusions that I (finally) make!</WARNING>
> So, I simply copied the netdemo program from the networking demos,
> renamed the .c files to .cc, and changed the C_PIECES to CC_PIECES in th
> Makefile. Next, of course, I modified the networkconfig.h
> appropriately. Here is what I found.
> 1. First attempt at make:
> $ make
> powerpc-rtems-g++ -B/usr/rtems/4.8/powerpc-rtems/virtex/lib/ -specs
> bsp_specs -qrtems -g -Wall -g -mcpu=403 -Dppc4
> 05 -Dvirtex -c -o o-optimize/init.o init.cc
> init.cc:42:22: error: confdefs.h: No such file or directory
> init.cc: In function 'rtems_task Init(rtems_task_argument)':
> init.cc:59: error: 'exit' was not declared in this scope
> make: *** [o-optimize/init.o] Error 1
> The first error is a bug from the original init.c, and seems to exist in
> many places in the network demos. This line
> #include <confdefs.h>
> needs to be changed to this:
> #include <rtems/confdefs.h>
> The second error is fixed most appropriately by adding to init.cc:
> #include <stdlib.h>
> 2. Second attempt at make:
> $ make
> 05 -Dvirtex -c -o o-optimize/test.o test.cc
> test.cc: In function 'void showbroad(int)':
> test.cc:39: error: invalid conversion from 'int*' to 'socklen_t*'
> test.cc:39: error: initializing argument 5 of 'int getsockopt(int,
> int, int, void*, socklen_t*)'
> test.cc: In function 'void echoServer(short unsigned int)':
> test.cc:227: error: invalid conversion from 'int*' to 'socklen_t*'
> test.cc:227: error: initializing argument 3 of 'int accept(int,
> sockaddr*, socklen_t*)'
> make: *** [o-optimize/test.o] Error 1
> This is fixed by changing the definitions of optlen and addrlen from int
> to socklen_t, and a few typecasts when they are used as integers.
> 3. Third attempt at make:
> $ make
> powerpc-rtems-gcc --pipe -B/usr/rtems/4.8/powerpc-rtems/virtex/lib/
> -specs bsp_specs -qrtems -g -Wall -O4 -fno-keep-i
> nline-functions -g -g -mcpu=403 -Dppc405 -Dvirtex -o
> o-optimize/netdemo.exe o-optimize/init.o o-optimize/
> test.o /usr/rtems/4.8/powerpc-rtems/virtex/lib/no-dpmem.rel
> /usr/rtems/4.8/powerpc-rtems/virtex/lib/no-msg.rel /usr/rte
> ms/4.8/powerpc-rtems/virtex/lib/no-mp.rel
> /usr/rtems/4.8/powerpc-rtems/virtex/lib/no-part.rel
> ms/virtex/lib/no-signal.rel
> /usr/rtems/4.8/powerpc-rtems/virtex/lib/no-timer.rel
> /no-rtmon.rel
> o-optimize/init.o:(.eh_frame+0x11): undefined reference to
> `__gxx_personality_v0'
> o-optimize/test.o: In function `showStatistics':
> /cygdrive/c/Home/ll/etill/development/apps/experiments/network-demos-4.7.99.1/netdemo-cc/test.cc:49:
> undefined reference
> to `rtems_bsdnet_show_inet_routes()'
> /cygdrive/c/Home/ll/etill/development/apps/experiments/network-demos-4.7.99.1/netdemo-cc/test.cc:50:
> undefined reference
> to `rtems_bsdnet_show_mbuf_stats()'
> /cygdrive/c/Home/ll/etill/development/apps/experiments/network-demos-4.7.99.1/netdemo-cc/test.cc:51:
> undefined reference
> to `rtems_bsdnet_show_if_stats()'
> /cygdrive/c/Home/ll/etill/development/apps/experiments/network-demos-4.7.99.1/netdemo-cc/test.cc:52:
> undefined reference
> to `rtems_bsdnet_show_ip_stats()'
> /cygdrive/c/Home/ll/etill/development/apps/experiments/network-demos-4.7.99.1/netdemo-cc/test.cc:53:
> undefined reference
> to `rtems_bsdnet_show_icmp_stats()'
> /cygdrive/c/Home/ll/etill/development/apps/experiments/network-demos-4.7.99.1/netdemo-cc/test.cc:54:
> undefined reference
> to `rtems_bsdnet_show_udp_stats()'
> /cygdrive/c/Home/ll/etill/development/apps/experiments/network-demos-4.7.99.1/netdemo-cc/test.cc:55:
> undefined reference
> to `rtems_bsdnet_show_tcp_stats()'
> o-optimize/test.o:(.eh_frame+0x11): undefined reference to
> collect2: ld returned 1 exit status
> make: *** [o-optimize/netdemo.exe] Error 1
> There are really only two problems here. First, the
> __gxx_personality_v0 error (apparently) comes from a missing C++
> library, and is fixed by adding -lstdc++ to LD_LIBS in the Makefile:
> LD_LIBS += -lstdc++
> The other errors are due to the rtems/rtems_bsdnet.h header file, and
> can be eliminated by changing the inclusion of this file like this:
> extern "C" {
> #include <rtems/rtems_bsdnet.h>
> 4. Fourth attempt at make - success!
> $ make
> /no-rtmon.rel -lstdc++
> powerpc-rtems-objcopy -O srec o-optimize/netdemo.exe
> o-optimize/netdemo.srec
> powerpc-rtems-nm -g -n o-optimize/netdemo.exe > o-optimize/netdemo.num
> powerpc-rtems-size o-optimize/netdemo.exe
> text data bss dec hex filename
> 413052 12048 61308 486408 76c08 o-optimize/netdemo.exe
> However, this application doesn't work! Here is the output on the console:
> Exception handling initialization done
> opb_intc_init: mask = 0x7
> rtems_glue: Waiting for time
> This is because, in init.cc, there are these obsolete lines:
> #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
> Changing them to this fixes the problem:
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> Note - the fact that we got any output at all without the console driver
> is just a happy accident with the virtex BSP.
> 5. Fifth attempt - working application!!! Clean make output:
> $ make
> test -d o-optimize || mkdir o-optimize
> 415228 12100 61292 488620 774ac o-optimize/netdemo.exe
> Console output:
> rtems_glue: Done waiting for time
> xiltemac: Creating shared RX/TX threads
> xiltemac: Initializing driver for 'eth0'
> xiltemac: base address 0x81200000, intnum 0x00,
> xiltemacStart, default linkspeed: 84000000
> xiltemacStart, new linkspeed: 44000000
> xiltemac: xiltemacStart, ipier: 00007F0E
> Destination Gateway/Mask/Hw Flags Refs Use Expire
> Interface
> default 192.168.0.27 UGS 0 0 0 eth0
> 192.168.0.0 255.255.255.0 U 0 0 1 eth0
> 192.168.0.27 UHL 1 0 1 eth0
> Create socket.
> Bind socket.
> Listen.
> Accept.
> Create socket.
> Bind socket.
> Listen.
> Accept.
> u
> Create socket.
> Bind socket.
> Opt:0 Optlen:4
> Opt:32 Optlen:4
> SUMMARY:
> Two main problems have been encountered that should definitely be addressed.
> 1. The network-demos-4.7.99.1 are horribly out of date, though the good
> news is that the fixes are all minor. Specifically, there are the easy
> ones (change all "CONFIGURE_TEST_xxx" macros to
> "CONFIGURE_APPLICATION_xxx" and all "#include <confdefs.h>" to "#include
> <rtems/confdefs.h>"), and a few slightly more tedious ones (change some
> int variables to socklen_t). There may be other issues in the other
> demo applications that exhibit similar problems.
> 2. Some header files are not quite ready for C++ compatibility.
> Specifically, this exercise found one, rtems/rtems_bsdnet.h, that does
> not include appropriate measures. Having to type this:
> extern "C" {
> is ugly and just plain wrong. This header, and others like it, should
> be modified to use the _BEGIN_STD_C and _END_STD_C appropriately to
> encapsulate definitions that the C++ compiler will otherwise mangle.
> Using these macros are better then simply extern "C" { } approach too,
> because they seem to handle the std namespace correctly.
> I'm willing to help in whatever way seems appropriate. I certainly
> don't mind reporting other issues as my work progresses. Please advise
> me as to the best approach to balance being helpful against being a PITA.
> Thanks,
> -Bob
> rtems-users mailing list
> rtems-users at rtems.com
