RTEMS HDD format options
Karel Gardas
kgardas at objectsecurity.com
Mon Jun 25 19:20:37 UTC 2007
Dave Erickson wrote:
> Joel/Whomever;
> I'm a little unclear, (and I did check archives), what file formats are
> acceptable for hard drive partitions to run RTEMS executables. Can HDD
> ext2/3 partitions run executables? I notice the filesystems guide does
> not elaborate. Is there a list somewhere of acceptable formats?
Yes. Ext2/3 partitions are supported. Basically if your bootloader
supports it, you may start/boot RTEMS application from whatever
partition format you like. The other question is what file-systems
formats supports RTEMS natively to for example save its own data...
Cheers,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
